Question about Canon Office Equipment & Supplies
I have a Canon MP700 Printer. The message "waste tank nearly full" appeared. As I couldn't find any help in the manual I removed the ink cartridges to look for a "waste tank". Couldn't find one; so tried to return the inks, but the thing the inks sit in won't return to the middle. How do I correct that and the waste tank problem. Thank you
    Guru:
  • Canon Expert
  • 183 Answers
Dear miggsy,
Waste ink absorber capacity of your printer has rise to about 90-95 %. Tentatively, you can continue printing by pressing STOP/RESET button. When ink absorber capacity reach about 100%, the printer stop working and message 'Waste Ink Tank is Full' appears.
To fix this problem, you need to reset waste ink counter. It strongly recommended that you replace waste ink absorber after resetting waste ink counter.
Here are steps resetting waste ink counter of this printer:
  • With the machine power off, while pressing STOP/RESET button, press and hold the ON/OFF button. (Do not release the buttons).
  • While holding ON/OFF button, release the STOP/RESET button. (Do not release the ON/OFF button).
  • While holding the ON/OFF button, press the STOP/RESET 2 times and then release all buttons. (Each time STOP/RESET is pressed, the alarm LED and COPY lights alternately starting with alarm LED).
  • When the COPY button lights in green, press STOP/RESET button 4 times. (Each time STOP/RESET is pressed, the alarm LED and COPY lights alternately starting with alarm LED).
  • Turn off the printer.
Your printer should work normally now.
Regards,
Source:
Canon Inkjet Printer Forum
Posted on Dec 05, 2008
Printer says"waste ink near full"
The waste ink is a set of sponges inside the ink jet that absorb ink during the printhead cleaning.
For now you can keep printing by pressing and holding the printer's On/Off button for one second. Then wait 10 seconds and press the On/Off button again. Wait until the printer finishes cycling before trying to print again. See Canon's support page for details: http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/multipass_series/multipass_mp700#ServiceAndSupport . Search for Waste Ink Full.
When the waste ink tank is full, then you will not be able to print until the unit is serviced. Canon will service this for you. (Free except for shipping if the printer is under warranty, standard $$ otherwise) However under normal use, the waste ink full counter should be reached its limit near the expected end of life of the printer. Additional failures may occur soon.
This is a messy job and may be a lot more work than you want to do. Have plenty of newspaper to absorb the ink if you try this. You need to disassemble the printer to reach them. One set is under the area where the printhead sits when the printer is idle. The other is further down in the center. You will need to remove a few small screws to access the bottom set. Once you get them out, blot off most of the ink and then run under water until the ink is completely out of the pads. Blot the areas where the pads sit of the excess ink as well. Then dry the pads (you can use a blow dryer to speed this step). Then reassemble the printer. (Alternatively, order replacement pads from Canon)
See http://www.fixyourownprinter.com/forums/inkjet/45693 for additional comments from others who have tried this.
Next you can reset the counter. (Do not do this reset before cleaning or replacing the ink pads; waste ink will smear everywhere.)
Resetting the Waste Ink Volume Counter
1) Enter SERVICE MODE.---
By pressing [Menu] then [Copy] then [#]
2) Select TEST MODE. (using + or - keys)
3) Press the [OK] key.
3) Press the [8] key. (TEST MODE)
4) Press the [3] key.
5) Press the [0] key. (INK COUNT).
6) Press the [OK] key.
7) Press the [Stop/Reset] key
9) Press the [ON/OFF]
I hope this helps.
Feb 20, 2011 | Canon MultiPASS MP700 All-In-One InkJet...
Message on printer "Waste Ink near full"............. Where is the waste ink tank?
Right under the resting place of the cassettes. However just emptying will not fix it you need to find the reset software for your model
It covers the whole of the bottom. Remove it carefully noting how it fitted. Make a solution of teaspoon of bleach to 1 cup water dunk in a few times to remove ink. Pat dry and finish carefully with a hair dryer on medium. Then replace and follow these instructions
Canon MP780 Waste Ink FULL Reset (Should work with MP700/730/750)
This reset should be used once waste ink counter reaches full and lock-out occurs.
- To select something... Use the '-' and '+' buttons and then the "OK" button.
- To go back... Use the "Stop/Reset" button
- To reset... Use the "On/Off" button (only after you've gone back as far as possible it seems)
  1. Service menu: Menu -> Scan -> Copy -> Scan (one at a time in sequence)
  2. Select "TEST MODE"
  3. Select "[8] ETC.."
  4. Select "[4] EEPROM CLEAR"
  5. Select "[1] INK COUNT"
  6. Press the [OK] button.
  7. Press the [Stop/Reset] button (Exits Service Mode)
  8. press the [ON/OFF] button (which resets the printer)
Reboot and enjoy
please rate my help++++Thanks for using FIXYA
Jun 25, 2010 | Canon PIXMA MP780 All-In-One InkJet...
Waste ink near full message??
The replacement of the waste tank requires the disassembly of the printer and the replacement of the tank with a replacement kit. Typically the kit will cost around $25 and the labor at a service dealer about $75. Get a couple of quotes before taking the printer in. Your other option is to go to a newer printer since you can find one for about the same price as repairing your current one.
Mar 05, 2010 | Canon MultiPASS F80 All-In-One InkJet...
I have a Canonmp390 printer & a message keeps
Error "Waste Ink Near Full"
Cause : The waste ink tank (which holds the ink used for print head cleaning) is nearly full.
Action : Contact the Canon Customer Care - Center.
Have a good day.
Dec 03, 2009 | Canon MultiPASS MP390 All-In-One InkJet...
I have a smart base MP700 canon printer with waste tank near full message can this be changed?
Hi you can try this.
MP730.
1. Hit the "menu": Key
2. Hit "Copy" Key
3. Hit "#" Key
4. Scroll thru the menu headings until you come to "Test Mode" - 12th heading
5. Hit the "3" button- this will bring up Eprom Clear
6. Hit "0" button
7. Hit the "Stop" button
Can only try then your printer go on longer but some time the other you need to clean out the waste ink it inside the printer go to open up all.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Oct 07, 2009 | Canon MultiPASS MP730 All-In-One InkJet...
MP700 waste ink near full
waist ink tank near full
cannot clear by pushing resume
what's the next step to get the printer fix
Rey
Apr 12, 2009 | Canon MultiPASS MP700 All-In-One InkJet...
Canon mp780 -waste ink near full??
Dear mr perfect,
Few days ago I have answered the same question about this for Canon MP700. Here is my answer:
Regards,
Source:
Canon IJ Forum
Dec 06, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Canon Multi pass F60 (waste tank near full)
Power off and on at button. If message continues it needs service.
Sep 19, 2008 | Canon MultiPASS F60 All-In-One InkJet...
Waste tank almost full on Canon i320 printer
waste toner must removed after a period of time open up your printer and you can see a small container inside. dispose properly the toner inside and clean the container with vacuum, do not use water, gently reinstall again into your printer and reset.
if you cannot find the location of the waste box consult your manual for proper location.
Jul 25, 2008 | Canon MultiPASS MP700 All-In-One InkJet...
Waste Ink in a Printer
u will have to lose the printer then bring out ink waste bin and then flush it manually n insert it back.
Dec 02, 2007 | Canon SmartBase MP730 All-In-One InkJet...
723 people viewed this question
old marine
old marine
