Question about Optimus STA-795 Receiver
HI: Can help me with a optimus sta-795 Digital synthesized am/fm stereo receiver, the problem is that,, one speaker doesnt function,, i checked the conections Ok,am/fm is ok, i checked the transistor is ok, ill require the manual to trace the problem, Woul you help me whit thaT? Il apreciate a lot your help Thank you very much
3 Suggested Answers
  • 336 Answers
SOURCE: Mt optimus sta-795 will not hold the station
You probably need to replace the memory capacitor. .047f 5v
off hand I don't remember the model # if you send me the catalog # on the rear of it (31-XXXX) it would help.
Posted on Dec 04, 2009
pgh_pa_guy
  • 2992 Answers
SOURCE: I need a service manual
I've tried unsuccessfully to find a copy you can download. The part number for the service manual is MS3102101. You can try your local RS store or call 1-800-843-7422 to see if you can order a copy.
Posted on Dec 19, 2010
dunnbiker
  • 8546 Answers
SOURCE: I have an Optimus STA-3500
It won't have "iPod" functionality but it can be played through the receiver.
Any audio device that has a headphone output can be adapted to feed an RCA cable pair for standard stereo to any audio device with a standard RCA input (except one labeled "PHONO"). Get a cable like the one described here: http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10218&cs_id=1021804&p_id=665&seq=1&format=2
and connect it into any available analog input EXCEPT one labeled "Phono".
Posted on Jul 25, 2011
Testimonial: "Thank you. I will give this a try."
No sound on left channel on home stereo optimus sta-795 will changing fuse out restore sound
Not likely! Suggest swapping input connection, red RCA connector to white and white to red and see if problem swaps speakers.
If still left channel bad swap speakers left to right see if problem follows speaker.
Check balance adjustment and confirm that it is set to the middle!
Check all other inputs and confirm always no left output.
The goal is to confirm that the left channel is defective!
The service manual is MS3102101 would normally be available from Radio Shack.
Check for defective capacitors or failed solder joints on the PC board. These units are repairable even by DIY however replacement recievers are relatively inexpensive.
Hope this helps?
Nov 20, 2016 | Optimus Audio Players & Recorders
Optimus sta 795 manual
I need service manual for STA-795
May 17, 2012 | Optimus STA-795 Receiver
I have an Optimus STA-3500 Digital Synthesized AM/FM Stereo Receiver. If I buy an i-pod is there a place on the back of the receiver that it can be plugged into? If so, what kind of i-pod wire/cable...
Jul 25, 2011 | Optimus STA-3500 Receiver
I need to know what model of a Motorola DVR is compatible with my receiver. What model can connect DIRECTLY from it's audio output to the audio input of my STA-795 Optimus Digital receiver (not through the...
Do you really have TV Audio OUT to a DVD (last sentence)?
Most DVR's have digital and analog audio outputs. Since every device they are intended to feed would have its own volume control a DVR output volume control might be redundant. Treat a DVR like any other audio device. Connect it to any available input on the receiver EXCEPT PHONO.
If you run the audio from the DVR (and EVERY video source) directly to the STA-795 you can bypass the TV and its questionable audio electronics (yuk). You can split the analog output of the DVR with y-cables and run it from the DVR to TO the TV for casual viewing and listening through the TV sound system (news, Oprah, etc).
Apr 21, 2011 | Optimus STA-795 Receiver
I need a service manual for my STA 795.
Dec 19, 2010 | Optimus STA-795 Receiver
Mt optimus sta-795 will not hold the station presets for more than a day. I don't see where there is a cms battery of some sort to replace. Any ideas?
Dec 04, 2009 | Optimus STA-795 Receiver
43 people viewed this question
Top Optimus Audio Players & Recorders Experts
Larry Stiles
Larry Stiles
Are you an Optimus Audio Player and Recorder Expert? Answer questions, earn points and help others
