Question about Xerox Phaser 7750DN Laser Printer
7700 starts but hangs at logo screen and red light is on
This printer will not come to a ready state.  It boots to the splash screen, then the red light comes on and it stops. I go into service mode, and there are no faults listed, and I can print all diagnostic pages.  All motor/clutch/solenoid tests pass.
I have done everything on page 3-93 from the 7700 service manual, to no avail.
The only thing I can think of is, I did not order a Xerox hard drive, and used a new one out of the box. Is there some sort of programing I need to put on the hard drive before installing?
If not, then is there anything else I can try on this unit?
    Problem Solver:
  • 6 Answers
If its a new hard drive then it definately dint and doesnt have software for it,i also have the same problem then i confirmed i dint have the hard im purchasing anew one and clone my spare 7760 hdd.
NB:clone a working phaser 7760 hdd..
this should work
Posted on Mar 27, 2009
  • Walter Shafer Mar 15, 2013
    I bought a 7760 without a hard drive. Would you be willing to sell me a clone of yours? Walter 865-932-0848
  • Santosh Pattnaik Aug 04, 2015
    i want image runner 3030 software for new hard disk same problem
What's your problem?i have a dell optiplex 755 (tower).. it was working fine.. but one day when switched it on,, it doesnt behave normal.. and no screen was showing on the monitor.. the pc was sho
Welcome to the world of Windows 7. Don't you miss Windows XP? LOL, Windows 7 is a nightmare just like Vista.
Anyway I think it's your Memory. You mentioned moving the memory chips around, but you didn't mention trying one at a time. I think one of them is bad.
Memory ChipRemove the Power Cord, Open the Case and remove one of thememory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x onit with an ink pen. If it fails to boot then move the chip to the nextmemory slot and try rebooting. If it fails take the chip out and set itaside, then put the other chip in and try booting it in both slots. If itboots, just to verify that the chip set aside is bad, mark an x on it and putit into the open memory chip slot and try booting.Try just working with one of them in Slot 1 and swap them out in just Slot 1.
Oh, I just thought of something else, Maybe you have bad Capacitors on the motherboard. Remove the Power Cord, Remove the Case. Take a flash light and look inside the computer at the capacitors. They look like little Battery Towers. If any of them are spewing corrosion out of them, they can cause the computer to go crazy just like yours is doing.
Apr 22, 2012 | Dell Computers & Internet
Quit the Registry Editor and log off
Automate the above task using this utility
This tiny utility provides you the option to choose a color from the Color Picker dialog and can reset the logon Wallpaper if you want. Choose your preferred Color and click Apply Background color. Remove Logon Screen wallpaper option clears the logon
How to disable the Windows XP Splash Screen / logo at startup ?
To disable the Windows XP splash screen (logo) at startup, and to see the list of drivers loading at startup, follow these steps:
Click Start, Run and type MSCONFIG
Click the Boot.ini tab
Under Operating Systems section, select the appropriate entry and then enable the /SOS switch in the Boot Options section below
Click OK and close MSCONFIG utility.
The corresponding entry in the Boot.ini file is automatically added. Example given below:
multi(0)disk(0)rdisk(0)partition(5)\WINDOWS="XP Professional" /noexecute=optin /fastdetect
multi(0)disk(0)rdisk(0)partition(5)\WINDOWS="XP Professional" /noexecute=optin /fastdetect /sos
The /sos parameter displays the names of the drivers as they load during the boot process. Use when startup fails (while loading drivers) to determine which driver is failing to load. See Boot Parameter Reference for more information.
Also see /noguiboot parameter, which can also disable the splash screen.
on Mar 24, 2008 | Microsoft Windows Vista Ultimate Edition
I changed my os from windows xp to windows 7...and i am using amd sempron (tm) processor 3400+ 1.80ghz..and 40 g hard disk..then the windows start up wont start normally. pls help!
Try hitting F8 just after your bios splash screen, before it would show the windows logo.
Select, boot in safe mode with networking.
Once you are in windows 7 safe mode, you can install any required drivers. This might prevent it from hanging on the next normal boot.
You can type in the run dialog CMD. This will open a command terminal. Type "SFC /scannow" without the quotes. This will tell windows to verify it's files. Let it complete, then reboot normally. Hopefully the problem will be resolved!
Mar 25, 2011 | Computers & Internet
Window 7 every 20 minutes hang
Many things could be causing this, the first thing I would do is boot into safe mode and see if the issue continues.
Safe Mode
Just before the Windows 7 splash screen (black with windows logo) appears, press the F8 key to enterAdvanced Boot Options.
You should now see the Advanced Boot Options screen. If not, you may have missed the short window of opportunity to press F8 in the previous step and Windows 7 is probably now continuing to boot normally assuming it's able to. If this is the case, just restart your computer and try pressing F8 again.
Here you are presented with three variations of Windows 7 Safe Mode you may enter:
  • Safe Mode - This is the default option and is usually the best choice. This mode will load only the absolute minimum processes necessary to start Windows 7.
Mar 15, 2011 | Toshiba Satellite L305D-S5935 15.4-Inch...
When i start up my dell inspirion 6000 laptop the logo comes up and then screen goes black
When you see the Dell logo, it means the system is booting and you see the splash screen that is generated on the motherboard.
Apparently this is where it is stopping.
Here's what I would do: First when you boot the computer, press F12 to get the boot options. Choose the diagnostics and run the system diagnostics.
You can also try to press F8 to get the computer into safe mode, but I'm thinking if you see nothing other than the splash screen, that may not work. If you are presented with Windows boot options, choose safe mode and do a system restore.
The last thing you can do if you have the Dell system recovery disk is try to do a repair from that CD if it allows you to do so.
Nov 06, 2009 | Dell Inspiron 6000 Notebook
Will not boot up. Screen displays Window XP
Use your original Windows XP CD and run the recovery console when starting up the pc. Thats should repair any files which are hanging the pc at the XP logo
Oct 13, 2009 | HP vs17
Xerox 7700 won't get past the startup screen
Make sure the image control board is not missing anything.
and maybe try replacing it with a diffrent image control board.
Feb 25, 2009 | Xerox Phaser 7750DN Laser Printer
How do you change the packard bell splash screen @ the bootup process. can you edit your own pic
i dont think that you can edit you own pics it depens on what os you are running . is the splash screen your screen saver or what more info on the spash screen
Aug 18, 2008 | Packard Bell Computers & Internet
Phaser 7700 not booting up
a yellow line is comming on both sides of the printout when i print using my phaser 7700
Mar 20, 2008 | Xerox Phaser 7700 Laser Printer
Xerox Phaser 7750DN Laser Printer Logo
234 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
