I recently attempted to do a system recovery and this is what i got, (file\minit\system32\biosinfo.inf) could not be loaded, error code is 14 set up cannot continue , also my internet explorer will not load
    Scholar:
  • 52 Answers
If that what you did and got that kind of error... try boot selection and select.. Last Known Good Configuration.. by Pressing F8 while turning on the computer, there is a selection you need to select your primary drive, where your windows installation installed. select the drive and then select Last known good configuration or safe mode if the first selection won't work.. when you select safe mode and it start windows properly do the System Restore in the safe mode if you want it.TY
HOPE I CAN HELP
Posted on Dec 05, 2008
Installing Windows 7 from a flash drive. " $WIN_NT$.BT\biosinfo.inf could not be loaded. The error code is 14 ". Pretty sure it's not an error on the flash drive seeing as how I have used it succe
Click start control panel administrative tools computer management then select event viewer this may vary depending on what operating system you have
extend the events there you will see errors in red you will no what exactly what the error was and at what time it occured
or click start type in event viewer press ENTER
you might be able work your way through the problem.
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
If done properly the user should get to a screen similar to the below screen.
Select the option for Safe mode command prompt only
Windows Advanced Options Menu
Please select an option:
Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt
Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Start Windows Normally
Reboot
Return to OS Choices Menu
Use the up and down arrow keys to move the highlight to your choice.
select safe mode with command prompt then type in chkdsk/f/r which will scan for and and attempt repair of bad files and bad sectors on hard drive
you should have no input while chkdsk utility is in progress any input might further damage your computer or
Use the System File Checker tool (SFC.exe) to determine which file is causing the issue and then replace the file.
Type the following command and then press ENTER: sfc /scannow The sfc /scannow command scans all protected system files and replaces incorrect versions with correct Microsoft versions.
Hope this helps.
Nov 17, 2012 | Dell Computers & Internet
I have an acer Aspire 5100. wont start up
Install xp cd,boot to xp cd,recovery,press enter for password, select 1 for C: Type:Fixboot Agree,type:CHKDSK C: /R Once its thru, type:EXIT Let xp start,remove cd.
Oct 01, 2009 | Acer Aspire 5100 Notebook
File\$win_nt$.bt\bioinfo.inf error 14...while trying to xp
http://www.youtube.com/watch?v=_SwZDboRv6U
Follow the above link. I had the same problem and this simple method works as it will create all the .inf files for you.
Hope this helps
Sep 07, 2009 | ASUS Eee PC 1000H Laptop
\$WIN_NT$.~BT\biosinfo.inf could not be loaded
Should be here: C:\WINDOWS\inf\biosinfo.inf
Sep 01, 2009 | ASUS Eee PC 1000H Laptop
I have an eMachine T3410. When it boots, a screen
your missing the biosinfo.inf. try reinstalling the system but backup everything you need first.
Jun 09, 2009 | E-Machines eMonster 600 PC Desktop
Windows problem?
just reinstall your Oeratuing System
Dec 09, 2008 | Sony VAIO RB30C (VGCRB30) PC Desktop
Configuration error code purple
1. Load the system recovery disk into CD-ROM
2. Press F10 repeatedly at boot screen to load the Recovery Menu
3. Press R for the recover console
4. Select "Advanced Options"
5. Press Alt + D to bring up the command prompt
6. type "cd h:\" to enter the root directory
7. type "dir /w" to view the directory in wide view
8. open the master.log file (or something along those lines), this should bring up a prompt asking you what program to open it with, you should only be able to select notepad.
9. open the file with notepad and when it appears select the File>Open
10. in the file name box type in "C:\hp\bin\configcheck\run.py"
11. once the file opens clear the contents and select save as then save the file as run.p_
12. close the notepad program
13. delete the original file by typing "del C:\hp\bin\configcheck\run.py"
14. reboot system
After a reboot the windows screen might flash a few times and take a little longer to load, be patient and you should be able to continue with the windows set-up without that damned code purple error message.
Oct 02, 2008 | Computers & Internet
When i load the gateway system recovery disc i get line 20101 of the inf file \minit\boot is invalid setup cannot continue
Sounds like you have a damaged restore disk. Look at it under a bright light, and see if there are any scratches in the disk. You might be able to clean the disk (always clean from the inside out, never in a circle).
Jul 28, 2008 | Gateway Computers & Internet
Acer aspire 3680 problem (anyone help plese?)
if you haven't delete the recovery partition, you can reload the OS using alt+F10.
during boot (after acer logo), press alt+F10, it will guide you to reload your OS.
if your recovery partition is corrupt, you should call acer call center to get the cd or you can buy cd from microsoft
Jul 05, 2008 | Acer Aspire 3680 Laptop
Bios could not be loaded error code
Sure , you need to change the battery in your motherboard. Often it looks like a silver coin. What happens is that your bios setting are reset to default each time you restart PC, before updating bios (that is the solution from hp that you are trying), change the battery.
regards
Mar 04, 2008 | HP Compaq d530 CMT PC Desktop
Computers & Internet Logo
110 people viewed this question
David Payne
David Payne
