Question about Motorola Mobility V400
Deleting contacts and numbers
I Want to delete phone numbers from the phone (not Sim) memory, but no help in the phone's manual.
Bring up the listing you want to delete. Click center function key above arrow. This will bring up list. Click down two spaces to delete and then right button to select. This will delete the entire entry. I have found no way to do a group delete.
Posted on May 21, 2007
Do a master reset on the phone this should delete everything from the phone but not your sim. If that doesn't work keep looking around your settings and you should find something. If all else fails email Motorola's customer support they get back to you fairly quickly.
Posted on Feb 14, 2007
How do I delete contacts from sim card
copy the contacts on the sim card to a sd card in the phone. If you don't have one, get one and put it in the phone. Set up the memory in the phone to both sim and memory card. Copy the contacts onto the memory card. Remove the memory card and then go about deleting the contact list in the phone. Put the memory card back in the phone and set the memory in the phone touse the memory card only...not the sim. You're done.
Feb 24, 2015 | Cell Phones
MODEL NOKIA 6021 CONTACTS STORED IN PHONE MEMORY DELETED BY MISTAKE HOW CAN I RETRIEVE IT?
H,
Once you delete the phone numbers from phone then it is not possible to retrive the phone numbers.
If you saved the numbers in SIM card then you can copy to phone memory.
To copy contacts from SIM card to phone,Contacts > Copy. You can copy names and phone numbers from the phone contact memory to the SIM card memory or vice versa.
Thank You
Aug 11, 2010 | Nokia 6021 Cellular Phone
My Lg Kg 195 suddenly attacked by a virus it restarted with deleting all contacts and the sim shows Invalid sim
Put your SIM in another phone and try to recover the contacts.
If it's not working on another phone it means your sim is corrupted.Contact service number and get a duplicate sim.
If it's working then reinstall your phones firmware from the nearest gadget shop.
Jan 16, 2010 | Cell Phones
Why does my message icon keep flashing? even though i dont have any messages
easy.click on messages, options, sim messages, mark all and delete and your box will stop flashing
Oct 20, 2009 | Sony Ericsson Satio Cell Phone
Deletion of Contacts from i mate jama 101 without sim
Are the contacts in phone memory or in sim memory?? If in phone memory, There's no problem. Switch on the phone and manully delete all contacts. There's no need of the sim to be inserted. If the contacts are in sim memory then insert the sim. Switch the phone on, and scroll contacts. Chek and find the no.s which have the sim image, it will surely be a sim contact. Then delete it. If you are fearing that your contacts ( if in sim memory ) will be deleted and it is important then first switch on the phone with sim. Note down all sim contacts, after that delete. Then if you give your sister another phone which she likes, switch on the phone and then install all sim contacts which you earlier noted down.
Aug 16, 2009 | i-mate Jama 101 Smartphone
Nokia 7310 Supernova. If someone calls cant see their name!
well, simple problem in your device.
You must have copied each number with two names or there may be double entery inside phone.
possibly problems
  • Double entry for single number
  • same contact in phone and sim
  • missing country code (ex. +91 xxx) in special cases
Solution:
  • take one other phone, and delete that number from your phone (sim n phone both memory) after deleting that contact details, misscall from working phone to your phone, and store that contact in ur phonebook
  • delete all contacts and add one time only. make sure no double copying
  • add country code before number
Tht's it, solution is as simple as 1 2 3
www.softzonelab.com
Jul 08, 2009 | Nokia 7310 Cellular Phone
Password required for deleting contact
hey I solved it myself!!!
initially i was entering only four digits, but this time I just kept entering '0' as many times as the phone takes (which i think is six digits)....and VOILA...everything done!!!!
Anyway thanks for providing the forum to seek help!
Aug 29, 2008 | Motorola Mobility RAZR V3i Cellular Phone
How to delete phone memory from a nokia 6070
Hi-
To delete all the contacts and the details attached to them from the phone or SIM card memory, select Menu >
Contacts > Delete all contacts > From phone mem. or From SIM card. Confirm with the security code.
To delete a contact, search for the desired contact, and select Options > Delete contact.
To delete a number, text item, or an image attached to the contact, search for the contact, and select Details.
Scroll to the desired detail, and select Options > Delete > Delete number, Delete detail, or Delete image.
Deleting an image from contacts does not delete it from Gallery.
Pls rate as fixya if it helps, THANKS!
Jun 30, 2008 | Nokia 6630 Cellular Phone
Sony ericsson W700i
most of the SE phone have two types of contact saving
1- in phone memory
2- in SIM card memory
if u have contacts saved in SIM memory but u r using
phonebook memory then it is default
if u save any contact in phone memory u have an option too
to copy it to SIM memory
for deleting a contact it will behave like this:
for example, u have a contact saved in phone memory
as well as in SIM memory
if u delete this contact, then it will be deleted from phone
memory but not from SIM memory
and when u are called from same number
(which is not present in Phone memory but is in SIM)
it displays the name again
Jan 17, 2008 | Cell Phones
Haven't changed password, default "00000000" doesn't work!?
normally if it's not zeros it's numbers in sequence 1 to 8
Nov 29, 2007 | Samsung SGH-D900 Cellular Phone
Motorola Mobility V400 Logo
78 people viewed this question
Top Motorola Mobility Cell Phones Experts
vince
D. E. Hev
Steve Berry
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
