Question about HP iPAQ RX3715 Pocket PC
Ipaq totally dead after leaving it in my car for two weeks, temperature down to -6C
I left my fully charged Ipaq 3715 in my car for two weeks and the temprature went tyo -6 below freezing, its now dead and will not charge or turn on, any ideas anyone?
    Novelist:
  • 198 Answers
Just for the knoledgebase. Ipaq 3715 is one of the fewer pda's that have a built in ac power only circuitry. It means it can power on without battery, only from AC, as long as the battery lid is closed. So in a case like this you may want to check if the pda does that. If not, there is a hardware fault. Most rx3715 (also most RX series) are known to have a particular sensibility to cold. In fact some of them may display a message "Too cold" or symilar. This happens when placed in cold environments, and it's symptoms are battery permanent failure, internal inverter circuitry failure (most likely your case), firmware corruption (this is also very possible) or the failure of the screen's digitalizer controller (on the main board not the actual display). Hope this helps in the future.
Posted on May 24, 2007
  • 624 Answers
Its possible (but not likely) that when you took it into a warm room condensation built up inside it. Try removing the battery, memory cards and letting it sit in a warm, dry environment for a few days and try again. If nothing changes I suspect that a component has failed, but -6F is still within the operational range of commercial electronics. If your device is still in warranty then I would call HP up and ask for a warranty replacement. Let us know if you have any other questions and please don't forget to rate this posting.
Posted on Feb 12, 2007
  • tomj23 Feb 12, 2007
    Another thing is that its also possible and more likely the battery was damaged when it got that cold, won?t supply power and won?t charge. It might be worth it to purchase or borrow a new battery and perform a test.
Stange battery performance???? - iPAQ h2200
surely the problem is with the battery ask for a replacement, try to find one which has the same mah with the battery you got along with the phone.
Apr 15, 2009 | HP iPAQ H2210 Pocket PC
How do you reset it to factory settings
To perform a soft-reset (if the device has locked), briefly insert the stylus or a paperclip into the reset hole on the bottom left of the 3715
To perform a hard reset (losing all data!), insert the stylus or a paperclip into the reset hole on the bottom left of the 3715 while holding down the far left and far right of the four main buttons. Information in the iPAQ File Store will not be lost, but data on the Internal memory will be wiped.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Mar 30, 2009 | HP iPAQ RX3715 Pocket PC
Hp ipaq 3715
Hopefully you can do a warranty repair, I'm pretty sure the main board is damaged since a hard reset should have taken you back to the factory defaults.
Dec 10, 2008 | HP iPAQ RX3715 Pocket PC
HP iPaq 3715
is this windows compliant and if it is in the control panel check to make sure that your sound that you use is default set some times this can lead to a no sound usuage
May 28, 2008 | HP iPAQ RX3715 Pocket PC
How do i play mp4 on my ipaq 3715
try converting the mp4 into either an mpeg or mp3
Nov 20, 2007 | Compaq iPAQ H3630 Pocket PC
Back up battery
 recharge the battery by connecting the HP iPAQ to AC power using the cradle or the AC adapter or insert a fully charged battery into the HP iPAQ.
Oct 07, 2007 | HP iPAQ hw6515 Pocket PC
No power to Ipaq 3715
Just did this one, please refer to
http://www.fixya.com/support/t395532-not_turn
For the solution
Jul 29, 2007 | HP iPAQ RX3715 Pocket PC
Totally Dead
I had the same issue. Got it fixed at PPCTechs at $60 + shipping. Better than buying a new device http://www.pocketpctechs.com/main~unit~HP_Compaq_iPAQ_hx4700-265~area~repairs~item~PPCDIAG~name~HP%2FCompaq+iPAQ+hx4700+Pocket+PC+Diagnostic+Service.htm
Dec 22, 2006 | HP iPAQ HX4705 Pocket PC
Rx3715 battery power trouble
Did you check if the PDA was hot? My battery was totally dead one day when I picked my 3715 up, just to found out it was blistering hot (was turned off) and even the backup battery was empty. Running fine now after hardresetting it, but still...
Sep 08, 2005 | HP iPAQ RX3715 Pocket PC
Hebrew Support for IPAQ 3715
Try Laridian.com They specialize in Bible and some language software for PDA's. Good Luck.
Sep 07, 2005 | HP iPAQ RX3715 Pocket PC
HP iPAQ RX3715 Pocket PC Logo
148 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
