Question about LG VX8300 Cellular Phone
Wold clock display
I just got my LG Scoop and have been doing a walk thru using the manual. I checked out the world clock and hit end, back out to the main screen. Now I have 2 time zones displayed on my main screen. I tried shutting the phone off to see if it would reset itself, but it didn't
    Brigadier General:
  • 7,752 Answers
You will need to reset the phone in it's settings
Posted on Dec 05, 2008
How do i down load the manual for a litter maid self cleaning litter box? kat at acollins3@aol.com
Here are the websites for part and manual. Spare Parts http://www.useandcaremanuals.com/pdf/lm500-lm950138.pdf
Depending what operating system typically you can hover your mouse in the lower right of the document and you will see the print save etc option.
Dec 08, 2014 | Cats
How do i set the clock
what model machine do you have? If it is similar to what I've had maybe i can walk you thru it.
Press change and CH should show in the display window. Press and release clock button and it should announce the day, to change the day setting hold down the skip/scan button or the repeat/scan button (this is for whether you want to go forward or back, i.e. from Friday to Thursday, etc. When you get correct day set, press and release clock, again & go thru holding down the skip/scan or repeat/scan buttons till you have correct hourly time, release button. Press clock again and repeat the skip/scan or repeat/scan until you get correct minutes, release button. To check if you did it correctly press and release the clock button. It should announce the correct day and time.
I hope this helps you, if your answering machine is similar to mine this should work. If it isn't give me the model number and I can try getting you a manual. Good luck, Barb
Feb 26, 2011 | AT&T Lands Phones
Clock is set properly. I want to turn on outdoor lights at 5PM everyday. In addition I want to turn off the lights each night at 11PM. Problem - When I go thru the process of turning on the lights it...
I answer questions for free.
I know timers and electrical devices, and have tested most of the brands.
You posted under the Woods 7-day timer 59018 or 59028.
Here is the manual:
http://waterheatertimer.org/pdf/Woods-59018-59028.pdf
There are several programmable timers today that look like Woods, and each brand has different programming.
If you do not have Woods, add a comment and I will walk through programming your brand
1) You have the clock set correctly which implies the wiring is correct. Good job!
2) Programming review:
Each program requires ON time to be set, and then OFF time to be set
For example you set Program1 ON 5:00PM for ALL days.
And then you set Program1 OFF 11PM for ALL days.
3) Programming steps:
Press PROG button until Timer 1 ON appears on display
Use Hour button to set 5 PM
Use MIN button to set :00
Default selects ALL days
(If you want other days, press DAY button until display shows correct block of days)
Press PROG button again to save Program1 ON
4) Now for Program1 OFF
5) To set Program1 Off
Press PROG button until Timer 1 OFF shows in display.
Use Hour button to set 11 PM
Press PROG button again to save Program1 OFF
6) Program 1ON and Program1 OFF have been set ... so press the CLOCK button to return to current time.
If you want to set another program, press PROG button until Timer 2 ON displays
7) After setting programs, press Clock button so current time shows.
8) The manual shows one more thing ... if you program the timer during the hours 5-11pm, and the timer should be ON during those hours, you have to 'tell' the timer to turn ON by pressing the manual override ... after that the timer will operate normally.
If you need more assistance, add a comment.
If instructions help, give it a 4-thumb
Nov 10, 2010 | Woods InWall 7 Day Digital Programmable...
How do you set clock on a lg rumor cell phone
Here are the instructions for changing the clock display. I'm sure somewhere along the way you can set the clock too.
1.
Press Menu > Settings/Tools > Settings > Display >
Main Screen > Foregrounds > Clock & Calendar
2. Select Normal Clock, Analog Clock, Digital Clock,
Dual Clock, or Calendar, and then press Menu/OK .
3. Press Menu/OK to apply the clock display setting.
This came from the manual for the LG Rumor at this link:
http://www.cellphones.ca/upload/manuals/lg-lx260-manual.pdf
Jul 21, 2010 | LG RUMOR Cellular Phone
Settiongs for Weather Data World Clock
Citizen Weather Data Clock Settings.
To set time press and hold for 5sec "set" button
Use advance to add days, years, hours seconds.
Press SET to hold.
Oct 17, 2009 | Citizen Watches
How do i set the clock on my pioneer super tuner III D
To set a Pioneer clock you do this..
1. Press the Source button till only the clock is displayed, this is Stand-by mode.
2. Press & hold the "F" or function button until "menu" appears on the display. You are now in the set-up menu.
3. Using the ff/frw button go thru the choices until clock adj is displayed.
4. Using the ff/rw set the correct hour and min and hit "f" to return to your menu.
5. Also turn off or on the AUX if you want and if that model offers it.
6. Relax and chill cause now your clock is set and your early. good luck
Aug 06, 2009 | Car Audio & Video
-how do I set the clock
hit display for clock. hold display down till clock flashes. press 5 for hour. press 6 for minutes. hit display again when done
Mar 12, 2009 | Alpine CDE-7853
My split system LG LSK2463HL unit will not turn on.. the remote appears to be working, checked batteries etc.
Use this link to get the service manual, they walk you thru an entire series of steps to check it out beginning on page 43 and up.. http://136.166.4.200/contents/AC/LS-K2430HL/LS-K2430HL_Service_Manual.pdf
Hope this helps..
Sep 21, 2008 | LG Heating & Cooling
World Cloack
As far as I can ascertain, you need to set your clock time to GMT, and then use the world clock feature to look up times in various cities. It would only be of any use if you were travelling.
May 18, 2008 | LG Prada KE850 Cellular Phone
HITACHI LIVING SYSTEMS HIT KC91 INSTRUCTIONS
Hi, I have one of these - You need to tap the "clock" icon (centre button on the right) twice. The display will flash. then press the "return" button the scroll through the hour/minute/tuner sections on  the display using the up & down arrows to change.
Feb 26, 2008 | Audio Players & Recorders
LG VX8300 Cellular Phone Logo
235 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
