Question about Whirlpool Dryers
Gas dryer won't heat
Dryer runs but does not heat up
    Genius:
  • 3,422 Answers
If your dryer doesn't heat, check these:
Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Posted on Dec 06, 2008
    Sergeant:
  • 399 Answers
 Things that could stop a gas dryer from heating:
- glow bar igniter, thermal fuse ( not all models ), coils on the gas valve, gas valve, thermostats,motor heat switch, timer, selector switch, sensor.
A page for checking gas dryers is here.
Gas dryer under water due to flood. Will run but
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Jul 27, 2010 | GE Profile Harmony DPGT750GC Gas Dryer
WE have no heat in the dryer. It will keep running but no heat
heatman101
Jun 15, 2010 | Frigidaire GLEQ642A Electric Dryer
Kenmore dryer, the dry runs, but does not heat
heatman101
Jun 11, 2010 | Kenmore 63942 Dryer
Dryer runs but will not heat
heatman101
Jun 07, 2010 | Maytag MDG2600BWW Gas Dryer
Dry run is running but no heat maybe heater is gone maybe fuse
heatman101
Jun 04, 2010 | Dryers
My dryer runs, but does not generate any heat. Is
heatman101
May 31, 2010 | KitchenAid KEYS750LQ Electric Dryer
Runs but no heat
May 29, 2010 | GE Profile Harmony DPGT750EC Electric...
Kenmore Dryer 65512 won't heat
heatman101
May 14, 2010 | Kenmore 64742 Electric Dryer
Not heating
Dryer Troubleshooting2_bing.gif Electric2_bing.gif Dryer won t Heat
heatman101
May 12, 2010 | Maytag Atlantis MDG7400AW Gas Dryer
Dryer runs but no heat
heatman101
Mar 13, 2010 | Estate TGDS740JQ Gas Dryer
Dryers Logo
21 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
