Question about Kenmore 24032\24036 Top Load Washer
Kenmore model 11092284800 washer
Regardless of water temp setting no hot water will go into the tub. I have the water heater next to the unit & have hot water throughout my apartment.I do hear water running but no flow ito the tub. No visible leaks behind the washer, either Thanks for your advice
    President:
  • 2,992 Answers
Most likely you have a problem with the fill valve. This uses solenoids to control the water into the machine. Shut off the hot water supply and remove the fill hose. Make sure the hose isn't kinked or clogged. There is a filter screen in the valve where the hose connects so check that too for clogs.
If the hose is OK the valve hot side solenoid may have failed. It needs to be checked with an ohmmeter. A good site is here:
http://repair2000.com/nowater.html
It shows a diagram of a fill valve and the terminals where you'd check. They have lots of other good troubleshooting information too, and sell parts.
It's also possible the temperature switch is bad, but this is not as likely as the valve.
Hope this gets you going.
Posted on Dec 05, 2008
Washer will not fill when hot selected ok on other settings
Could be that there is no hot water going into the tub when you select that setting. Make sure the hot water tap is on. Sometimes there is a difference in pressure coming from the hot water heater than cold and that may affect your washer.
Feb 01, 2015 | Kenmore Washing Machines
Washer comes up with f-05 code what does this mean?
Could the unit possibly be a whirlpool duet or kenmore elite model? They are 99.9% the same. If so, it is a temperature sensor error. If you have the unit set for warm or hot water, and not enough hot water makes it into the tub by the time it is full, the washer realizes this and drains the water, to refill with warm or hot water. If the tap water never gets warm, the unit will fault out and act strange.
If the water in the tub is in fact warm or hot like it should be, the water temp sensor should convey this information to the control board. If the sensor has failed, the control board never sees this change, and sets the same error code.
If you cannot or are not willing to dig deep into this machine, call a service tech out. Chances are, the tech can have your washer running again in an hour or two. Please mark me down as helpful.
Jan 05, 2015 | Washing Machines
Purchased in 2003. Dishes were exquisitly clean till 2008. Our water heater temp was set at 140 temp. This heater was replaced with a heater now set at 125 temp. In the past two years dishes are nowhere as...
try turning on your water at the sink for a while on hot let it run then start the wash cycle that should help. what that will do is let the cold water run out of the pipes and therefore you will have a hot water start.
Dec 17, 2010 | Kenmore Dishwashers
I have a top loading Kenmore Washing Machine. I don´t have the excat model but looks like a KENMORE HEAVY DUTY SERIES 70 AUTOMATIC WASHER, MODEL # 110.92273100. The problem presents after finishing...
You may have 2 defective parts.
First,make sure the hot and cold water hoses are connected correctly and both turned on.
If the water fill problem is the same,the water temp switch is bad.
The not filling after the wash cycle could be a bad lid switch.
Set the machine for SPIN and turn it on.
If it does not spin,replace the lid switch.
Sep 20, 2010 | Kenmore 24042 Top Load Washer
Washer will not fill up with hot water however it will with warm
Is your water temp on your water heater set high enough? If it is sounds like you are getting water from both hot & cold water valves. If temp is set correctly on machine temp switch may be bad on warm all time.
Mar 12, 2010 | Kenmore Washing Machines
Automatic warm/cold water temperature setting does
The temperature control board is bad . Pt # 388246
Aug 17, 2009 | Kenmore 22422 Top Load Washer
Bath tub water doesn't stay hot
it is because the tub has a temp control valve in it so if you were to put more cold with the hot it will last longer but still won't be all the way hot,, now a days people are suing the manifacture because they are getting burned form the hot water so they put these saftey temp controls in place of the old style 2 or 3 handle faucets,, there fo no more real hot water nothing you can do outside of change to the othere type of faucet 2 or 3 handle tub shower diverter,, that why the water is hot in the sink but not the tub.....
Jun 23, 2009 | Water Heaters
Washer is rinsing with hot wateer nomatter what temp. setting is used. I have tried to switch hoses twice now, no difference in rinse but now on correct wash temp.
The MAH5500 series washers have automatic temperature control functions so the washer can control water temp regardless of water heater settings and other factors. I would say either your definition of "hot" is not truly "hot" (over 110 degrees), or the washer's ability to sense has failed (which would also affect fill temp on "wash" fills also). If someone has worked on the washer recently, maybe they reversed the wiring to the water valves inside the machine? ATC temps are as follows: Cold 70-90, warm 90-110, and hot is unregulated at 110 degrees and up. These are normal temp ranges for ATC controlled machines, and are completely safe for fabrics.
Apr 25, 2009 | Maytag Neptune MAH5500B Front Load Washer
Washer is a top load set it hot water and starts with hot and then will go cold willnot stay on hot G E Profile ,model wwa8350g
most new washers sense water temp and will try to adj final tub water temp by alternately running cold or hot as needed ..most hot settings are not faucet temp but a predetermined temp so if your hot water is 140 degrees coming in the control will switch the cold on to bring final tub water temp down to preset ..which could be as low as 100 degrees the industry's way of energy conservation
Sep 23, 2008 | GE Washing Machines
Washer tub will only fill on the hot setting
Is the tap to te cold water turned on
I would check that
Jan 13, 2007 | Maytag MAV3905EWW 13 Cycle Washer
Kenmore 24032\24036 Top Load Washer Logo
100 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
