Question about Dryers
My dryer stopped drying - Dryers
  • 3,463 Answers
Presuming that the motor is running and that the drum
is turning, then it could be one of several things.
Firstly open cct heater element, open cct stat or stats, and or a faulty heater relay
You need to check with a multimeter.
Check and clean filter.
Posted on Dec 05, 2008
Leq2152ee1 dryer does dry but keeps stopping if put on any setting over 15 min. Dryer stops single beep and top four lights blink.
MAY BE BAD MOTOR WITH BAD WINDINGS USUALLY STOPS AFTER 20 MINUTES OF USE? OR HEATING ELEMENT IS OVERHEATING? DUE TO BAD VENTING? THERMAL CUT OFF KEEPS SHUTTING IT DOWN?
May 08, 2014 | Frigidaire GLEQ2152ES Electric Dryer
My Dryer won't stop drying until I open the door.
If it does this in a Timed Dry setting the timer is bad. If it does this in an Auto dry setting it could be a bad moisture sensor or a bad timer.
Aug 21, 2011 | Crosley Dryers
Kenmore 11066912690 dryer stops working
if you are using the sensor drying cyle this could cause the unit to stop. it will detect the most dry clothing first usually light clothes that dry faster.if not and you are useing timed dry the most likely cause is a faluty timer,or a thermostat sesnor is going bad and turnoing off the dryer before the clothes are dry
Sep 16, 2009 | Kenmore 62602 Electric Dryer
Drying clothes & the dryer just stopped & won't come back on
This is likely the thermal fuse on the heating element. You can check it with an ohmmeter. Also clean out your venting, as this often causes it to blow. Hope this helps!
Mar 09, 2009 | Maytag PYE2300AY Electric Dryer
Dryer stops working after 10 minutes
Motor may be over heating.may need new motor.
Mar 01, 2009 | Kenmore 73952 Gas Dryer
Drying timer on auto dry
I called LG...they said to unplug the dryer for 5 min. to reset the timer ...this solved the problem.
They also said not to use dryer sheets during the sensor dry cycle as the coating on the dryer sheets causes the sensor to malfunction as it can't read the humidity level in the dryer.
Dec 28, 2008 | LG Dryers
Dryer stop drying
Check you venting,on gas units call for service.
Mar 17, 2008 | Maytag MDE2600 Electric Dryer
Dryers Logo
78 people viewed this question
Top Dryers Experts
