Question about Sharp AR-M455N Copier
Duplex Set-up fro Sharp AR-M455N
How do you set up duplexing?
  • Anonymous Mar 26, 2014
    don't know how to set it up to get a receipt to show the fax was sent and received.
    Problem Solver:
  • 7 Answers
Does the machine have a duplex fitted? as it is an option for this machine either called a du3 or du4. It bolts onto the left hand side of the copier. On the lcd touchpanel you should see it sais 2 sided next to the output box, tap it and select 1 to 2 or 2 to 2 depending on your origonals.
Posted on Dec 06, 2008
Have a weird problem on a Sharp AR m455n the screen stuck on the sharp logo any ideas?
Sometimes this would happen when a bad print job got sent to the machine. I'd make sure to delete all of the print jobs in everyone's print queue on their computer then reboot the machine to see if it comes back up.
Copier Collin Houston TX Copier and Imaging Expert
Aug 18, 2014 | Sharp Black Toner Cartridge For AR-M355N,...
Sharp ar-m205 showing e7 error code
Duplex model memory error/ Image data error
Detail 1. The memory capacity for the duplex model
machine is wrong. Insufficient memory
2. Duplex setting is set for a single surface
Apr 08, 2011 | Sharp AR-M205 Copier
Sharp ARM237 crooked prints and jams w/double sided printing only.?????????
this will be an issue with the duplex rollers check where it is jamming is it in the duplex unit if yes then check the duplex rollers for wear worn rollers will cause scews also check there is no torn pieces of paper stuck in the guides of the duplex
a good thing to do is to get a thin piece of card stock slide it into the duplex manually and frred it where the paper path goes on the duplex from beginning to end and it will push out any thing in the path
Jan 20, 2011 | Sharp AR-M237 Digital Copier
Duplex cover - where is it?
If there is a finisher on the left side slide it away the duplex door is on the left end of the copier do not open the left door that exposes the drum and fuser area this is a door on the outside of the left side
Jun 08, 2010 | Sharp AR-M455N Copier
Sharp 5516 n legal duplex copying is not coming
Duplex unite only use a4 size not other size.You can try other size before configure.
Dec 14, 2009 | Sharp AR-5316 Advanced Digital Imager...
Sharp ar -m351 Error codes L4-30
Main motor is being locked because of drive overload, check the drive system and make sure it is smooth especially the duplex area.
Nov 24, 2009 | Sharp AR-5316 Advanced Digital Imager...
AR-235 how to set default to duplex - network printer
On the server, go into the 235's properties, click on the advanced tab, click on printing defaults. That's where the clients get their default printer settings from. If that helps, please rate me. Thanks.
Feb 17, 2009 | Sharp AR-235 Copier
Duplex printer
Check the driver you have installed on your computer, that's where the duplexing would be generated from. You should be able to choose through print properties at this point. Here's the link to Sharp:
Sep 10, 2008 | Sharp AR-507 Copier
Duplex not working on sharp ar-m207
Hi, i suspect duplex has been switched of in 'key operator programs', consult the manual to change this, or follow these instructions: press special functions, scroll down to 'key op prg', ok, enter 0000 (default number may of been changed), select copier, ok, scroll down to duplex, change to enable. Hope that helps
Jan 22, 2008 | Office Equipment & Supplies
Sharp AR-M455N Copier Logo
270 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
