Question about Rockford Fosgate 800.2 Car Audio Amplifier
Rockford fosgate amp 5 ch
Just installed it has a hard wired remote that adjusts the bass ch. it stopped working just about 15 minites into adjusting the sound !! the connections are like a phone type , that clicks in , any ideas
    Scholar:
  • 125 Answers
Most likely your remote wire or remote crapped out if not its your amp itself can you adjust and play without remote? if so go to this site for info and replacement as well as tips:
http://www.rockfordfosgate.com/rftech/wire_calculator.asp
Posted on Feb 04, 2009
My rockford fosgate punch p-1000 bd amp stopped working.all it does now when I turn my stereo on is pop my 100amp inline fuse.
You have shorted outputs that are causing this. The amp will have to be repaired. I can repair it for you.
Dec 02, 2015 | Rockford Fosgate Car Audio & Video
Bass level is the same @ all volume levels
your problem is the wiring... but it is really hard for me to see where the problem is..
is there a way for you to send a picture of what you have done?
Dec 24, 2007 | Rockford Fosgate Punch P5002 Car Audio...
Why did speakers get really loud, then stop working?
Have you checked the fuse on the amp and/or make sure the amp did not burn out?
Aug 01, 2015 | Rockford Fosgate Car Audio & Video
Fosgate 1500 amp settings
low pass of course set the crossover around 80Hz. Then turn the bass down to around 35% on headunit and the volume all the way up on your head unit just below distortion. slowly turn the amp gain up until you start to hear distortion, then turn it back down until it's completely gone. Then, lower the gain just a little more to make sure you keep out the distortion on all songs. From here you should be good. If the gain is still to high. The adjust to your taste. Just don't move the bass up on the headunit or the gain past your distortion point.
May 22, 2012 | Rockford Fosgate Car Audio & Video
ROCKFORD FOSGATE X7a Amp, I need compatiable remote control knob.
It will NOT work!
You need p/n AP-3212. If you are in USA then contact Rockford for this part number.
Aug 11, 2009 | Rockford Fosgate Type RF X7 Car Audio...
Amp Issues
1800W peak output at 2 ohms
975W peak output at 4 ohms
600W RMS (continuous) at 2 ohms
325W RMS (continuous) at 4 ohms
Variable LP crossover adjustable 35-250Hz
4 AWG power/ground inputs and RCA pass through
Low-pass filter
Bass boost 0-18dB adjustable remote punch bass EQ
Signal-to-noise ratio: >80dB
Line-level input
It is going into protect mode for a reason.
Disconnect the subs and turn everything on again. If the light comes on, the problem is internal and will need servicing by a technician.
Dec 22, 2008 | Ultra Linear UL-2200D Car Audio Amplifier
its a simple rheostat. disassemble the controller, and clean with an eraser.
Dec 05, 2008 | Car Audio & Video
Quick question, amp problem
make sure you ground wires arent shared, meaning run each ground wire from each amp to its own grounding point
Sep 08, 2008 | Rockford Fosgate P3001 Car Audio Amplifier
Bass control stopped working
on rockford amps, the bass control knob needs to be connected to get the maximum output (+18 db gain i believe). If you did this to the power wires, then yes, you may have at least damaged the bass control knob. Try replacing this to see if you get all of your gain back. If not, then you have damaged something inside the amp...maybe a capacitor or power supply inside. If that's the case, you'll need to get the amp looked at by an electronics repair technician or local stereo shop.
Aug 10, 2008 | Rockford Fosgate P3001 Car Audio Amplifier
No bass
There's a small switch on the side labeled LP-AP-HP. Make sure it's in the LP or AP position, not HP. There's a small dial labeled FREQ; if your amp is connected to subwoofers and the switch is in the LP position, adjust the dial until it's set around 80-100.
Jun 14, 2007 | Rockford Fosgate P3001 Car Audio Amplifier
Rockford Fosgate 800.2 Car Audio Amplifier Logo
76 people viewed this question
Top Rockford Fosgate Car Audio & Video Experts
seankane89
Level 1 Expert
hoyzee1
Tygh Duval
Tygh Duval
Are you a Rockford Fosgate Car Audio and Video Expert? Answer questions, earn points and help others
