Question about Car Audio & Video
Rockford fosgate amp 5 ch
Just installed it has a hard wired remote that adjusts the bass ch. it stopped working just about 15 minites into adjusting the sound !! the connections are like a phone type , that clicks in , any ideas
  • 15,935 Answers
Its a simple rheostat. disassemble the controller, and clean with an eraser.
Posted on Dec 22, 2008
How do I adjust the fade on the stereo of my 1996 Toyota Camry DX V6? it says "PULL FADE" underneath the BASS and TREB, but those nobs only effect the Bass and Treble.
Jim Norton Toyota of Tulsa, Oklahoma: 2012 Camry Adjust ...
? 0:54
https://www.youtube.com/watch?v=ghwosvmNxkk
Feb 8, 2012 - Uploaded by Jim Norton Toyota
Jim Norton Toyota of Tulsa, Oklahoma: 2012 Camry AdjustSound Qualities ... Toyota Tacoma Stereo Install with Bluetooth - 2005 to 2011 ...Missing: 1996
Stereo not balanced in 2015 Camry XSE - Toyota Nation Forum ...
www.toyotanation.com > ... > 7th Generation (2012+)
Apr 14, 2015 - 15 posts - ‎11 authors
I noticed that I can hardly hear my rear speakers in my 2015 Camry XSE. I have adjusted the fade control from the center position to the rear position. ... dash speaker on the driver's side, regardless of how I adjust the sound. DIY - How to fix a flakey volume control in a 2001 ...
Sep 25, 2012
DIY: 1996 Camry Power Antenna Replacement Procedure
Jan 18, 2009
AUDIO: What does ASL stands for while we adjust the ...
Jan 20, 2008
no sound from rear speakers
Mar 18, 2007
More results from www.toyotanation.com
Jan 15, 2016 | Car Audio & Video
Bass level is the same @ all volume levels
your problem is the wiring... but it is really hard for me to see where the problem is..
is there a way for you to send a picture of what you have done?
Dec 24, 2007 | Rockford Fosgate Punch P5002 Car Audio...
Is the base and treble audio adjustible on this 1996 Sony TV KV- 20S20
Adjusting various sound settings (e.g. bass/treble ... - Sony
docs.esupport.sony.com/imanual/NA/EN/hx850/c_snd_qv.html
You can adjust various sound settings, such as bass, treble, balance, etc. ... [Setting Memory]: Applies custom sound settings to the current input or to common ...
General information on how to adjust the bass and ... - SONY
https://us.en.kb.sony.com/.../general-information-on-how-to-adjust-the-b...
Aug 15, 2015 - Follow this procedure to adjust the bass and treble surround parameters on the A/V ... Adjustable sound field parameters vary by sound field.
Dec 25, 2015 | Sony KV-20S20 20" TV
My rockford fosgate punch p-1000 bd amp stopped working.all it does now when I turn my stereo on is pop my 100amp inline fuse.
You have shorted outputs that are causing this. The amp will have to be repaired. I can repair it for you.
Dec 02, 2015 | Rockford Fosgate Car Audio & Video
Why did speakers get really loud, then stop working?
Have you checked the fuse on the amp and/or make sure the amp did not burn out?
Aug 01, 2015 | Rockford Fosgate Car Audio & Video
Mtx tna251 amp has bass remote that has a light glowing but turn knob up and down and no difference like simply not working no difference in bass? Posible causes,
It is actually in the controller, if you turn the remote all the way down and press on the controller until the bass goes off, you will be able to turn the bass up and down with the remote, mine worked but stopped after a month, I tried adjusting the amp but then I noticed that if I wiggled the knob on the remote that it would work, I mashed mine until it worked again and velcroed it to my console sonibcan get it on and off easily.
Mar 03, 2015 | MTX Car Audio & Video
How to adjust bass and treble and surround sound
On the Remote Control
Press
1 TONE
ToneControl•OFF-
2 Use selection button to select "ON".
ON : Allow tone adjustment (bass, treble).
OFF : Playback without tone adjustment.
NOTE
The tone cannot be adjusted in the direct
mode.
3 Press
to select an item to be set, and use
TONE
to select a setting value.
Bass : Adjust low frequency range (bass).
• -6dB - +6dB (0dB)
Treble : Adjust high frequency range (treble).
• -6dB - +6dB (0dB)
"Bass" or "Treble" can be set when "Tone Control" is set to
"ON
Oct 24, 2014 | Denon Avr 391 5.1 Channel 110 Watt...
It's not hitting hard at all
Signal getting to and from the Amp is problematic, if you do not have the correct wiring that will carry the necessary power then you are never going to get the sound you are looking for. Start with testing the AMP and then Wires....
Mar 01, 2014 | Hifonics Car Audio & Video
I have 3 JL Audio 12
Reduce the amount of boost or, better yet, turn off the bass boost. With your installation, overemphasis on the bass is causing the rattles and distortion
Nov 16, 2012 | Kenwood KAC-9103D Car Audio Amplifier
Fosgate 1500 amp settings
low pass of course set the crossover around 80Hz. Then turn the bass down to around 35% on headunit and the volume all the way up on your head unit just below distortion. slowly turn the amp gain up until you start to hear distortion, then turn it back down until it's completely gone. Then, lower the gain just a little more to make sure you keep out the distortion on all songs. From here you should be good. If the gain is still to high. The adjust to your taste. Just don't move the bass up on the headunit or the gain past your distortion point.
May 22, 2012 | Rockford Fosgate Car Audio & Video
Car Audio & Video Logo
81 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
