Question about AT&T 9350 Cordless Phone
Changing the answering setting from AO back to recording message
I don't know how I got the setting to AO and I don't know how to get it back to A or B. Had no idea I wasn't receiving messages. The manaul is so unclear how to do this. Please help me.
    Problem Solver:
  • 4 Answers
Manual says to press "change", then "setup" until...(it comes out to pressing it twice), then use "repeat" or "skip" to get to the one you want (A,B, or AO), then press the "Mbox 1" or "Mbox 2" button.
Posted on Jan 01, 2009
I am trying to record my outgoing answering machine message on my Uniden Dect 6.0 cordless phone. I know my security code, but I don't know how to record it.
Hi There,
Press the Menu button Use the volume up/down buttons to navigate to 'Answ. Setup' Press OK Use the volume up/down buttons again to get to 'Record greeting' You might need to press OK here, I'm not sure. Press the Start key and record your greeting
Jul 15, 2011 | Uniden TRU8885 Digital Answering Machine
We don't know how to retrieve out messages from outside the house.
To play back messages remotely, first you'll need to have set up your two-digit security code (PIN). You can download a copy of the manual here which gives all the details. Once you've done that, here's how to use the system:
1) Call your telephone number and wait for the system to answer. If the answering system is off, it will answer after about 10 rings and sounds a series of beeps.
2) During the greeting message (or a series of beeps when the answering system is off), press 0 and enter your PIN code within 2 seconds. The answering system announces the current time and the number of messages stored in memory. You hear "To play incoming messages, press zero-two. For help, press one-zero." You will hear a beep.
3) Enter a command within 15 seconds. Each command thereafter must be entered within 2 seconds. These are the available commands:
  • 0 then 1 Repeat a Message*
  • 0 then 2 Playing incoming Messages
  • 0 then 3 Skipping a Message
  • 0 then 4 Deleting a Message
  • 0 then 5 Stop Operation
  • 0 then 6 Answering System On
  • 0 then 7 Memo Record/Stop**
  • 0 then 8 Greeting Message Record/Stop**
  • 0 then 9 Answer System Off
  • 1 then 0 Help
* For the Repeat a Message function, press 0 then 1 within about four seconds to repeat the previous message, or press 0 then 1 after about four seconds to repeat the current message.
**For the Memo Record and Greeting Message Record function, the first time you enter the corresponding command, it starts the Recording function. If you want to stop the recording, press 0 then 7, 8 or 5.
4) After the command has finished, you hear intermittent beeps indicating that the system is in the command waiting mode. You may enter another command at this time from the chart above.
5) Hang up when you're done.
Jul 05, 2011 | Uniden TRU8885 Digital Answering Machine
How do i set the answering system on a uniden 1580-3 phone, mine is just background noise on the answering machine when someone calls in to leave a message
Here is the manual for your phone. You can download the manual and the instructions for setting up your answering machine are on page 43:
http://www.uniden.com/pdf/DECT1580-3om.pdf
Setting Up the Answering System
You can set up your answering system's features from the handset. Only one handset at a time can access the answering system menus.
Note: If you have multiple bases, select the base with answering system you want to access (see page 15).
Recording a Personal Greeting
Your answering system comes with a pre-recorded outgoing message or greeting that plays when you receive a call: "Hello, no one is available to take your call. Please leave a message after the tone." You can record your own personal outgoing greeting. Your recorded greeting must be between two seconds and thirty seconds long.
Press /mute. The system announces the number of new and old messages, then starts to play the messages unless it has no messages.
Press 5 to stop the announcements or message playback. You will hear intermittent beeps indicating that the system is in the command waiting mode.
Press 8 to start the recording. The system announces, "Record greeting." Begin recording after the announcement.
When you finish recording, press 8 again or press 5. You will hear a confirmation tone, and your recorded greeting plays back for you.
Selecting a Greeting
Once you have recorded a personal greeting, the phone automatically switches to your personal greeting. You can
also switch back and forth between the pre-recorded greeting and your own greeting at any time.
Press 6. The system plays the current greeting.
Jun 15, 2011 | Uniden 5.8GHz Expandable Cordless Phone...
Can I check my messages from a phone outside my home, is it possible to make a remote enquiry? And if so, how does it work?Thanks in advance for your answer. Regards, Joy
Remote Message Retrieval
You can operate your answering system from a remote location using any touch-tone
telephone or the handset.
Remote access away from home
You can check, play, or delete messages, even record a new greeting message when
you are away from home. Additionally, you can turn On or Off your answering system
from a remote location.
Remote access:
press 0 and enter your PIN code within 2 seconds (see "Setting a PIN Code" in your owners manual.
3) The answering system announces the current time and the number of messages stored
in memory. You hear "To play incoming messages, press zero-two. For help, press onezero".
4) Enter a command within 15 seconds, each command there after must be entered
within 2 seconds. You may select a command from the following chart:
For your convenience
a remote operation
card is provided for
you to use while
away from home, it can be found in the back of your owners manual.
Command Function
0 then 7 Memo Record/Stop **
0 then 8 Greeting Message Record/Stop **
1 then 0 Help Guidance
Command Function
* For Repeat a Message function, press 0 then 1 within about four seconds to
** For Memo Record and Greeting Message Record function, the first time you enter
the recording, press 0 then 7 or 8.
5) After the command has finished, you hear intermittent beeps indicating that the
6) When you are finished, hang up to exit the system. The answering system
automatically returns to standby.
Your machine automatically has a PIN set of 80.
If you are trying to use remote access from a cellular phone and having trouble: Try changing your tone length on your cell phone to long.
May 25, 2011 | Uniden Cordless Phone
I need to update the message on our answering machine but don't know how to do it.....& don't have the user guide any more...
there is usually a buttom labelled OGM (outgoing message) press and hold until it beeps - record and let go of the button whne you have recorded the message
May 09, 2011 | Lands Phones
Forgot how to record answering message
my parents Doro cordless phone is showing a eep error message after changing the batteries, any ideas?
Feb 25, 2009 | Vtech Lands Phones
Greeting message
To Record Outgoing Message on Radio Shack’s Answering Machine [Model 43-3829]:
Press and Hold the ANNC/DAY/<< button. You’ll hear a beep; continue to hold down the ANNC/DAY/<< button and record your message. When recording of your [outgoing] message is complete, release the ANNC/DAY/<< button. Your message will automatically play back for you.
Please let me know if you have additional questions. Thanks!
Take care,
Gail :-)
Sep 17, 2008 | Radio Shack (43-3829) Digital Answering...
RCA 25205 2-line corded pnone answering machine won't answer
Record the message for both line one and line 2, see if that helps.
Sep 03, 2008 | Lands Phones
Instructions for model 1188
Hi Diana - To record your outgoing message, hold down your ogm button ( outgoing message) for two seconds and it will ask you to record a message. To play back your message, just push the same button and it will play your message. If you don't like it just do it again. If this solves your problem PLEASE rate this as fixed. If you need more help just add a comment and I'll be happy to assist you further. Thanks and have a good day.
Jeff
Jun 11, 2008 | BellSouth Digital Answering System 2006C...
AT&T 9350 Cordless Phone Logo
131 people viewed this question
Top AT&T Lands Phones Experts
Paul C.
Are you an AT&T Lands Phone Expert? Answer questions, earn points and help others
