Question about Fellowes Powershred C-220 Strip-Cut Shredder
PowerShred C-220 will not shred automatically
Our shredder became jammed. When we unclogged it - it will no longer shred automatically when paper is fed into it. If we push the 'I' button it will run and shred continuously until we push the 'O' button to stop it. It will also run in reverse.
  • kseivert Mar 30, 2009
    The trash light is always on, even if there is nothing in there. Which in turn will not shred automatically. I can't find where the sensor is on the shredder to "clean up".
  • Anonymous Mar 19, 2014
    Please help!
    An expert whose answer gotĀ voted for 100 times.
  • 121 Answers
OK lets try.
You likely have a photo sensor that detects the paper and it is dirty.
It is likely covered with paper dust (hopefully only on the outside)
Locate the sensor and wipe it off or just wipe the entire throat area.
Hope this helps
Posted on Mar 15, 2009
How do I get top off to clear Paper Jam on Fellowes PS-12Cs
In case of a paper jam , which may occur if the shredder is pushed beyond its specified capabilities, press the control switch to the off [O] position and empty the basket if full. Then:
1) Press and hold control switch in reverse [R] position and attempt to back paper out of shredder.
2) If shredder jams in reverse mode, press control switch to automatic [I] position and attempt to continue shredding operation.
3) If shredder jams again, alternate control switch slowly between reverse [R] and automatic [I] positions to attempt to move jammed paper completely through shredder.
If you are unable to clear the jam using this method, turn off and unplug the shredder; remove the wastebasket from cabinet and carefully remove any paper extending below the cutting cylinders; empty the wastebasket; insert wastebasket and repeat jam clearing procedure.
May 23, 2014 | Fellowes Powershred PS-12Cs, 12 Sheet...
Unit won't turn off automatically
There could be a shred of paper blocking the sensor. It is good, and necessary, preventive maintenance to clean the shredding mechanism regularly to remove trapped paper.
Apr 24, 2014 | Fellowes Powershred C-320C Shredder
Fellowes Powershred 220 gives a perfect cut on half of the paper only? How can this be fixed to give a perfect shred across a whole sheet of A4 paper? Can anyone help?..PLEASE..
Welcome to fixya
I have a solution for this
Press Ok, Accept or replay so we may get started
Your pre-solution is coming up shortly
My name is Bruce
Jan 16, 2011 | Fellowes 220 Powershred Strip-Cut Shredder...
THE SHREDDER ISNT SHREDDING ANYTHING ANYMORE, the power still runs and it will still take the paper but its not shredding anymore???
You wil need to Have the shredding head rebuilt or replaced. and or a new machine. A new head is very expensive. Here is the number for fellows 800-955-0959. Check on parts if they are still available. Hope this helps your friendly service tech (colorado).
May 06, 2010 | Fellowes Powershred 220 Shredder
Not completely shredding. one side only makes
need bearing plate call cooks mobileshredding inc. or email or call bill cook or beverly miller 901-565-8188
Apr 23, 2010 | Fellowes Powershred 220CC Shredder
All lights turn on as needed and has power but won't grab paper to shred
suspect paper jam try using reverse button the dislodge paper.
suspect paper feed sensor is blocked or damaged there is a light beem in front of the teeth that starts the shredder if this defective the shredder will not start.
suspect a panel or bin is not correctly seated causing the shredder to not start.
Nov 13, 2009 | Fellowes Powershred 320C Shredder
Need a sensor switch for fellows powershred 220. Won't sense paper.
The top sensors may be bad or even the main board that they are connected to is bad. Try cleaning them with a lightly moistened swab or compressed air. Fellowes will sell you the parts.
Apr 29, 2009 | Fellowes Powershred 220 Shredder
The "bin full" keeps on coming on
first off, fellowes has had problems with the bin full sensors that sometimes, can only be corrected by replacing them. however, there are two things to check. make sure it doesn't have a bunch of shredded paper hanging down from the cutters. that can trigger the bin light as the sensore are located under the head, but above basket. last, but not least, clean the sensors. they get paper dust on them after awhile causing same indication. if those two things don't fix it, it will have to have sensors replaced.
good luck,
Jan 20, 2009 | Fellowes Manufacturing Powershred C-220...
Shredder stops in the middle of shredding and won't shred.
Is the paper bin full?....mine always shuts down when the paper bin is a little over half full.
Jan 21, 2008 | Fellowes 220 Powershred Strip-Cut Shredder...
Fellowes Powershred C-220 Strip-Cut Shredder Logo
617 people viewed this question
Top Fellowes Office Equipment & Supplies Experts
Charles T Nevin
Charles T Nevin
Adorjani Laszlo
Are you a Fellowes Office Equipment and Supply Expert? Answer questions, earn points and help others
