I got the laptop in january and it has been taken care of very well but now the laptop boots up and then goes to a red screen with no pictures or writing it has been like this for about a week now, i thought it was just over heated but it has to be something else.
SOURCE: My Acer Aspire 3050 laptop can not boot
Hi
Thank you for your query
unfortunatley you are stuck in a windows loop and will need to reformat your PC
Please do the following to reformat
1) Put your recovery disc into your PC and allow the PC to restart
2) The laptop should pick the disc up and boot from it
3) Follow the onscreen instructions to complete the rest of the install
If this has been useful please leave postive feedback/vote/testimonial - Thank You Again
SOURCE: ACER Aspire laptop power cycles on and off
Sir, form the symptoms I believe that the Battery is completely dead, the system is unable to identify the battery. If possible try checking the battery with a similar model, and the the system should be all set to go.
please encourage us,if this tip was helpful to you.
SOURCE: Acer Aspire 5100 laptop's screen remains black at start-up
This is probably a hardware issue with the monitor. Just to make sure, uninstall, and reinstall the monitor's driver. If that doesn't fix it, it's a hardware issue.
You will have to either take it to a shop, or contact the manufacturer (your computer should be under warranty if you've had it for less than a year).
SOURCE: Monitor on Acer staying gray
have you tried to the "function+8" (or the number to transfer the
signal to a monitor) when you are on the laptop with grey screen?
Did you said that grey, means that there is light on the laptop, but no colors, or that tha screen is not turned on?
SOURCE: acer aspire 5570z wont boot to windows
Insert a windows boot disc. Go into the bios select it to boot from CD-ROM first. Then you can go from there. If you get it to boot to windows disc, then you could start reinstalling windows. If you are still having issues then there is a more serious issue. If you have any other questions let me know.
Thanks,
Lee
