Question about GE Profile JB968 Electric Kitchen Range
F2 Error My GE profile range has issues when I try to cook above 350 degrees.... it either beeps loudly and displays an F2 error.... or just quietly shuts off without a peep. Is it possible for an oven to "overheat"? We cut the power at the circuit breaker (as suggested in the manual) but it had no effect. can anyone help? Thanks! Traci
    President:
  • 878 Answers
Traci, F2 is the error code for a overtemp in the oven compartment. It could be two things. The oven temp. sensor or the main board itself. Start with the temperature sensor. It should ohm out at 1080 ohms at room temp. This of course is the least expensive and probably your problem. The temp sensor is the probe that is in the back wall of the oven. It will remove from the front with two screws. There will be a harness that you can disconnect it from when pulling it out. Some one can ohm it out there. The other possibility is welded relay contacts on the main board. Let's hope it's the sensor. Part number WB21T10007. Catriver..post back.
Posted on Feb 13, 2007
I tried to reset the time on my stove and it started beeping and flashing F2. why
The error code "F2" will be displayed along with a beeping sound if the ERC (Electronic Range Control) or "clock" senses a runaway heat condition during the "cook" or the "clean" modes. It could be caused by the oven temperature sensor, by the ERC or by the wire harness between the oven temperature sensor and the ERC. If the error code "F2" is displayed in the "cook" or "clean" modes only, then the problem is a bad oven temperature sensor or its wire harness. If the error code "F2" is displayed in the time of the day mode also, then most likely a problem is the bad ERC.To get the right replacement part just click on the link AppliancePartsPros,
Aug 03, 2016 | Optics
What is the F2 error message?
Hi There
I have found the code for you. I hope this helps you.Let me know how it goes.
F2 During Clean Control senses oven temp above 915 degrees F High resistance connection in oven temperature sensor circuit. Check Electronic Range Control (ERC) - Welded clean relay contacts. Both lock switch 1 & 2 closed at the same timeThank you for writing to fix ya.
Best Regards Richard
Mar 22, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
Describe your GE Profile Spectra XL44 Oven
My GE Profile Convection Microwave Oven will beep and display a F2 for no apparent reason. What is this?
Mar 09, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
Whirlpool SF36 Gas Oven - F3 F2 ERROR above 350 degrees
Unplug the range.
The oven temperature sensor has failed and must be replaced.
Remove the racks. Remove the temperature sensor located up high on the back wall of the oven.
It is a short thin round piece of metal.
Feb 13, 2010 | Whirlpool SF369 Gas Kitchen Range
oven senor not working right . it may have carbon that need removing or it may just need changing due to breakage
Feb 13, 2010 | Whirlpool SF367 Gas Kitchen Range
We have the ge profile xl44 spectra and the F2 message has appeared on the display and need to know what this means
An F2 error code means your Electronic Range Control (ERC) board is going out or has already gone oit.
We are GE factory authorized parts and service so please contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service
frm 7 AM until 9 PM CST Monday through Saturday for this part. We ship next day air to our customers and would love to get you cooking again asap.
We look forward to hearing back from you soon. Thanks, Ella
Nov 22, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Self Cleaning Gas Range F2 Error, happens at 400 degrees and turns oven off any advice?
Your oven temperature sensor must be replaced. It is located in the oven compartment up high, may be right or left side depending on model. Smaller than a pencil about 3&1/2 inches long.
Jul 25, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Display shows error code "F1"
F1 Failed Thermistor Control Replace Electronic Range Control (ERC)
Good Luck and Please Rate Fixya!
Jan 06, 2009 | GE Profile Spectra JGBP79 Gas Kitchen...
F2 Error code displays with audible beep.
The F2 typically means an overtemperature conditions:
1. over 650 degrees F unlatched or 915 degrees F latched.
2. cooling fan stalled while over above 650 degrees F or an oper thermal switch in the yellow leads.
Check for:
1.Welded relay contacts
2.Cooling fan stalled or blocked air flow to rear of unit.
3.High resitance in over sensor leads/connectors, especially at sensor in rear.
Nov 03, 2007 | GE JTP20 Electric Single Oven
GE Profile JB968 Electric Kitchen Range Logo
432 people viewed this question
Top Kitchen Ranges Experts
Ismael Rodriguez...
Craig Butler
Craig Butler
Sal De
Are you a Kitchen Range Expert? Answer questions, earn points and help others
