Locating a users guide for my fax machine
I spoke with customer service about getting a users guide for my fax maching. the model isFAX770 and the serial no. is U56348GBK056720. i am online and cannot seem to find what i am looking for. i was told i would be able to download this information onlilne.
  • 10,594 Answers
Download User Manual of Brother Fax 770 from HERE.
Thank you.
Posted on Dec 05, 2008
Mfc 5840cn problem
Machine Error 46 – Purged Ink Box Full MFC620CN/420CN/410CN/210C and FAX2440C
The machine counts all purge (cleaning) operations in order to prevent the internal ink absorber box from overflowing with purged ink. An “initial purge”, for example, advances the purge counter by 187 + 420 = 607. When the purge counter approaches 6400, an internal "Machine Error 46" is generated. Further purge operations are prohibited, and therefore the printer becomes unuseable.
When an internal Machine Error 46 is generated, the user will see an “Unable to Clean” external message and will be unable to use the printer. The “Unable to Clean” external message can relate to many different internal error codes however.
The user can establish the internal Machine Error Code as follows: pull the mains cable out of the machine (power off), hold down the Menu/Set key, re-insert the mains cable into the machine (power on). The internal Machine Error Code will be displayed.
If there is a Machine Error 46, it is necessary to dismantle the printer, replace the ink absorber box (or possibly break the ink absorber box open and clean its absorbent sponges under a tap), re-assemble the printer and reset the purge counter to zero.
Resetting purge counter MFC620CN/420CN/410CN/210C and FAX2440C
1) Enter machine maintenance mode (on MFC210C all four photo/copy/fax/scan lights flash in maintenance mode). Care is needed in maintenance mode, otherwise critical settings may be inadvertently corrupted.
FAX models with numerical keypads: Press the Menu/Set, *, 2, 8, 6 and 4 keys within two seconds. (if you fail to complete the correct key sequence within two seconds, press the Stop key to try again).
Other (non-FAX) models: Press the Menu/Set and Black Start keys. Next press the “up arrow” key four times to enter the maintenance mode).
2) Press the 8 then 0 keys in the initial stage of the maintenance mode to call up the machine's log information list (function code 80).
3) Press the Black Start key several times to scroll through the log information list to reach the purge counter. The purge counter is the 25th item in the list.
4) Press the 2, 7, 8, and 3 keys in this order to reset the purge count to zero.
5) Press the Stop/Exit key to return to the initial stage of the maintenance mode.
6) Press the 9 key twice to return to the standby state.
Carry on printing !!
Jul 17, 2008 | Brother MFC-5840CN All-In-One InkJet...
How to find brother sewing machine ZZ3-B982 user guide?
Brother has extensive website and customer service. If you go to their site for your country and put in your model number, they'll tell you if they can get you a manual. Most are just downloads.. very easy. I'd give you a URL but I don't know where you are located.
They have fabulous customer service, so try there first.
Jul 01, 2014 | Brother Sewing Machines
Have changed phone service providers. they say that the fax mach. and land line can work together. I say i need another phone line for the fax mach. please help. the fax mach. is a hp 1040 fax. jeff h.
If they changed you over to Vonage or some other digital service, the fax machine will not work reliably.
You need a plain old telephone system POTS for your fax. All faxes are analog.
Nov 12, 2009 | HP 1040 Plain Paper Inkjet Fax
I need the instructions for the Bissell Little Green Machine Model 03041 J03041.
BISSELL User’s Guides can be downloaded at www.bissell.com
On the front page under Customer Service click on User’s Guides and enter the model number of your unit.
User Guide will be displayed as a PDF file.
Jul 14, 2009 | Bissell THE BISSELL LITTLE GREEN MACHINE...
Open to clean juicer maching
http://www.powerjuicer.com/customer-manuals.html
This is the site to download Jack Lalanne's Power Juicer Manuals of all models which include troubleshooting guide, user instructions, cleaning and opening machine.
Jul 13, 2009 | Jack Lalanne Power Juicer (Stainless...
Maching wont do anything
Typical "machine" as it turned out! I unplugged it, walked awacy & came back 5 minutes later, plugged it back in and WHOOPIE it worked!
Feb 03, 2009 | Brother MFC 240C All-In-One InkJet Printer
New yet old fax wanting to hook up ...needing User's guide
IF YOU WANT TO GET A USERS GUIDE, YOU CAN EITHER DOWN LOAD IT FROM BROTHER.COM OR CALL BROTHER AT 908-704-1700 - BROTHER TECH
Jan 11, 2009 | Brother IntelliFAX-870MC Fax
Compatability with efax
Try Brother customer service 1-800-284-4329 (usa voice #), but be prepared to answer a few questions 1st. The manual mentions nothing about eFax.
Jan 28, 2008 | Brother IntelliFAX 4100 Laser Fax
Delta Luv Crib Replace. Parts - 4XG lower plastic guide & 4XM steel peg
I went to the website www.deltaenterprise.com. You will have to have the country of origin, model number and the date of manufacturer or you can not get the parts. The phone number is 800-816-5304. I do not have fast you will get the parts. I called and did not have the country of origin so I will have to wait.
Jan 09, 2008 | Delta Luv Delta - Baby Products 5-in-1...
59 people viewed this question
jasbo
jasbo
