Question about Dryers
Hoover Nextra HNC 771 XT doesn't start...
I have a dryer machine - Hoover Nextra HNC 771 XT (7,5 Kg)
The machine doesn't start and flashes the condenser light ?!?!?
All filters are clean. The wheel that selects the programs doesn't select nothing...because the program in LCD display doesn't switch also...
2 Suggested Answers
hards327
  • 30 Answers
SOURCE: How do i replace belt on condenser tumble dryer
you need to remove the whole front of the machine by removing the : top by the 3 screws at the back,then unscrew the screws across the front of the top of the bezel then remove,then open the door,remove the circle of screws then put the machine on its back,remove the screws at the bottom front of the machine,then lift the front bottom of the machine and slide it upwards then you should be able replace the belt then refit in reverse order good luck.
Posted on Mar 17, 2008
I have a Hoover nextra 6 kg condenser tumble dryer which is leaking water and the collector is empty and seems not to locate fully into the hole at the back?
Check for Lint/Dirt in the Drain and then you need to ensure it is fully connected in the Washer to the Drain...
Jan 03, 2015 | Hoover Dryers
Hoover nextra washing machine door wont lock / cycle start
sounds like the door lock mechanism. if this cannot signal it has engaged, to the board, no other function will work (you don't want the washer going with the door open, trust me :) )
Nov 08, 2013 | Hoover Nextra 160 HNWF 3137 Front Load...
Hoover Nextra HNWF 3135 door will not lock
1) test the switch door, you do not have error code.
see the video, and replace for defective switch, or loose wires or broken, or burn.
God bless you
Jun 28, 2012 | Hoover Nextra HNWF 3135 Front Load...
I have a hoover nextra dryer hnc 170. The drum will not turn, and both the lights for filter care are on. I assume the reason it is not turning is because of the filter care light. Is there anythin i...
the filter care light comes on when the machine is over heating so the "brain" thinks the lint trap is full , clean the entire venting system, including the outside vent cover and remove any debris , then unplug the machine for a few minutes and see if it resets
Jul 04, 2011 | Dryers
Hi, nextra 7 wont`t spin could it be the bushes
not necessarily as it may be anything from the electric motor,a belt or a capacitor that start the motor..
Jun 17, 2009 | Hoover Nextra HNWL 3136 Front Load Washer...
Noisy when running need to check belt and bearings
i need the serial # to assist you better
thank you
May 14, 2009 | Dryers
Flashing lights
Check your exit hose spigot, it may be clogged. This is if your filter is all clean (ref manual) There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it (maximum 7 inches). Snaking out your standpipe & drain would be good. All lights flashing indicates you have a block somewhere.
Pl. rate me if helped............
May 30, 2008 | Hoover Nextra HNWL 3136 Front Load Washer...
Dryers Logo
713 people viewed this question
Top Dryers Experts
