Question about Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White
My oven door will not close, my husband tried to straighten the hinges and still it will not close. What more can we do? My model # is FEF450WBD-A
    President:
  • Frigidaire Master
  • 2,651 Answers
If hte hingesoverextended them selves( door open past ninety degrees then replacing the hinges is your only option, roming hte door is in your manual, the hingss are part of the door, not a baad repair
Posted on Dec 06, 2008
How do I fix an oven door
sounds to me like bottom hinges are set to close to oven/ need spacers so oven door closes flat top and bottom at moment it seems that bottom is to tight before oven door is closed ,try fitting spacers behind hinge fixings at bottom, good luck
Sep 22, 2016 | Ovens
Door will not close completely leaving 1cm gap at top.
If the door closes fine till that 1cm gap hinges more than likely wont solve it you need to replace the supports that the hinges slot into
Dec 13, 2013 | Electrolux EOG6330 Gas Single Oven
Miele classic h 383 b-cat Oven door will not seal properly. Checked seals and cleaned around hinges. No obvious signs Help Thank you
SPRAY HINGE WITH WD-40 AND SEE F THERE ARE ANY SCREWS OR BOLTS AT HINGE THAT ARE LOOSE OR THE HINGE IS BAD,GRAB IT BY THE HINGE AND SHAKE TO SEE IF IT IS LOOSE.THE HINGE PART THAT GOES INTO OVEN THAT YOU CAN NOT SEE COULD BE LOOSE OR ENLARGED TO MAKE IT NOT LINE UP.
Nov 17, 2012 | Ovens
My JenAir oven door doesn't close fully
most likely you have bad door hinges if the door doesn't close correctly,i don't know if you know this but alot of parts are no loner available for this model,it must be old,the only thing you can get for the door is the hinges and that's it,you'll need the rest of the model number to get the right hinges you're missing the last two letters,you can go here put your model number in to look up parts.
https://www.searspartsdirect.com/model-number/JMW8527CAB/1266/0125300.html
go to door and look at part 16 the hinge,hope this helps you out,when you open the door,if it sags down lower to the ground the hinges are bad,when open it should be at a 90 degree angle
Feb 01, 2018 | Jenn-Air JMW8527C Electric Double Oven
GE Oven door lock 'engaged' while door was open and door will not close - how do I release the lock?
If your oven door has gotten bent or warped (maybe you rested something heavy on it...), you need to remove the door, disassemble it, and straighten it. You can lift most oven doors off of their hinges by opening the door several inches to its first "stop," and lifting the entire door straight up. If the hinges have become worn, damaged, or bent, you probably need to replace them. We recommend replacing both hinges at the same time, to prevent uneven wear of the undamaged hinge.
Dec 06, 2010 | GE JTP27 Electric Double Oven
My oven door doesn't close completely. Is there a way to adjust the door?
Hi There
I found this for to read so you can fix your door.I hope this will help you.Let me know how it goes.
The oven door won't close If your oven door has gotten bent or warped (maybe you rested something heavy on it…), you need to remove the door, disassemble it, and straighten it. You can lift most oven doors off of their hinges by opening the door several inches to its first "stop," and lifting the entire door straight up. If the hinges have become worn, damaged, or bent, you probably need to replace them. We recommend replacing both hinges at the same time, to prevent uneven wear of the undamaged hinge.
Thank you for writing to fix ya.
Best Regards Richard
Dec 30, 2009 | Ovens
Oven door won't close fully.
The only satisfactory solution, is to replace both the oven door hinges,\ which is a fairly straightforward job to do.
Please rate my solution.
Thanks
Nov 09, 2009 | Bosch Ovens
I have a Frigidaire Gallery Oven Professional Series, I don't have the model number. In trying to self clean my oven, I accidentally pressed something that engaged the oven door lock. Now I can't close...
If the hinges have become worn, damaged, or bent, you probably need to replace them. I recommend replacing both hinges at the same time, to prevent uneven wear of the undamaged hinge.
Sep 04, 2009 | Ovens
KEBS208DSS6 doors wont close compleat
Place a hammer handle between the door and the frame at the hinge location.
Carefully apply pressure on the door to push the door closed.
This will often re-set range door hinges.
Mar 08, 2009 | KitchenAid KEBC208 Electric Double Oven
Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White Logo
104 people viewed this question
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
ashburton
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
