Question about Uniflame 153100 Open Flame Patio Heater
Instruction manual i need a manual for the endless summer out door heater model no 153100 or sn 006007115 robert
Burner lights and burns yellow flame
Lack of air causes it to burn yellow clean out burner air ports
Oct 11, 2016 | Endless Summer 153100 Open Flame Patio...
Can not start pilot light. where is it located?
The pilot light is at the top of the heater inside the mantle screen. You will need to disassemble the top of it, to access it.
Mar 12, 2011 | Endless Summer 153100 Open Flame Patio...
I have an Endless Summer (Blue Rhino) patio heater with model number 153100 and the pilot flame is not strong enough to keep the thermal coupling open. What has to be done to fix that?
The pilot jet may be clogged. If there is a flame, it must be small and blue. A large flame that is orange or yellow tipped means that there is a partial blockage in the pilot assembly which needs to be cleared. The pilot flame must also touch the thermocouple in order to heat it correctly. Make sure that the pilot jet and thermocouple are positioned correctly. If you have an extremely small pilot flame, try repalcing the regulator and hose as the regulator may be failing.
Sep 02, 2010 | Endless Summer 153100 Open Flame Patio...
The pilot light won't stay lit, sometimes it will stay lit and start the heater, but then it just turns off within 5- 10 seconds?
Probably the thermocouple is bad and needs to be replaced. I assume you have enough fuel? . Is this a new unti or is it a bit old?
Mar 29, 2010 | Endless Summer 153100 Open Flame Patio...
Pilot light lights
air gas mix racio to high on air.
Jan 03, 2009 | Endless Summer 153100 Open Flame Patio...
Endless Summer Model 153110
try to clean flame sensor with wire brush
Apr 12, 2008 | Endless Summer 153100 Open Flame Patio...
Uniflame 153100 Open Flame Patio Heater Logo
Top Uniflame Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
John Rodgers
John Rodgers
Are you an Uniflame Heating and Cooling Expert? Answer questions, earn points and help others
