Question about V1 Radar Detector
V1 "J" display??
Occasionally I receive three beeps of different tones immediately followed by a "J" display. I thought I was seeing things, but this has happened three times so far and I have only had the V1 detector for about a week. Thanks for any help you can give.
    Sergeant:
  • 347 Answers
That is an indication that the unit is "seeing" non radar signals otherwise "Junk"
Posted on Dec 06, 2008
My pioneer sx-316 multi channel receiver is off on protected mode what do I do to restart
I read the instructions perhaps slightly differently perhaps. I take the instructions to mean first hold down tone and then hold standby/on key for three seconds. Have you tried doing it as two steps?
1 Switch the receiver into standby.
2 While holding down the TONE button, press and hold the  STANDBY/ON button for about three seconds.
3 When you see 'RESET?' appear in the display, press the ENTER button. OK? shows in the display.
4 Press SETUP to confirm.
Feb 03, 2015 | Pioneer New Original SX316S Remote Control
No display problem for intel D865GSA board
What are you formatting ? Have you changed the RAM. Does tour system work in its original configuration ? You do not say what the pattern of the beeps is. Before the display disappears, is there a message sent to the screen ?
From the manual
http://download.intel.com/support/motherboards/desktop/d865gsa/sb/d5600601us.pdf
Whenever a recoverable error occurs during POST, the BIOS displays an error message
describing the problem (see Table 53). The BIOS also issues a beep code (one long
tone followed by two short tones) during POST if the video configuration fails (a faulty
video card or no card installed) or if an external ROM module does not properly
checksum to zero.
An external ROM module (for example, a video BIOS) can also issue audible errors,
usually consisting of one long tone followed by a series of short tones. For more
information on the beep codes issued, check the documentation for that external
device.
There are several POST routines that issue a POST terminal error and shut down the
system if they fail. Before shutting down the system, the terminal-error handler issues
a beep code signifying the test point error, writes the error to I/O port 80h, attempts
to initialize the video and writes the error in the upper left corner of the screen (using
both monochrome and color adapters).
If POST completes normally, the BIOS issues one short beep before passing control to
the operating system.
18.April.2014
18.April.2014
Apr 18, 2014 | Intel 865G Motherboard
MT1500 shows full battery but beep's like it's dead
Hello
This double beep tone you are hearing is a acknowledgment tone indicating that the radio is in the transmitting mode. On the Motorola MT1500 radio you can adjust the tone volume separate from the reception volume by simply holding down the volume control and setting the tone volume level.
I hope this helps.
Bruce
Jan 04, 2014 | Motorola Radio Communications
Phone not working
Hi Pam,
Try these..1...remove your telephone line from base unit and fix it into a working land phone and check whether is it having normal dial tone.If it's having engage tone(beep beep...)remove paralleled phones and re connect to cordless base unit.
2.If line is ok (normal dial tone with full volume) & still display indicates line is busy, your main base unit must be having faulty components inside.Commonly these defects happen in thundering or surges through telephone lines.You have to take full set to a repair shop.
Rana.
Dec 28, 2013 | Gigaset As300 Twin Dect Cordless Phone -...
Driverts calls
Hi, You can use this instruction to activate and de-activate Call divert .Works on all phone
Turning Call Divert On
by Touch Tone phone
Step 1 Lift the receiver and listen for the dial tone.
Step 2 Press the Divert On button if using an Optus OneTouch phone, or dial *78 from any other touch tone phone.
Step 3 Listen for three beeps followed by a continuous tone.
Step 4 Dial the telephone number to which the calls are to be diverted.
Step 5 Listen for two short beeps, confirming the diversion.
Step 6 Replace the receiver
Turning Call Divert Off
By Touch Tone phone
Step1 Lift the receiver and listen for the dial tone
Step2 Press the Divert Off button if using an Optus OneTouch phone, or dial #78 from any other touch tone phone
Step3 Listen for two short beeps to confirm removal of the diversion
Step4 Replace the receiver.
Other Call Divert Options - Selective Calls
With selective call options, you can choose which numbers you wish to divert, accept or reject by adding these numbers to a list. You can list up to 30 numbers for each call option.
Turning On or Off Selective Call Options
Step2 Press the access code for the service you require. You will hear a prompt telling you the status of the service and how many telephone numbers you have on your list. To turn the service on/off press 3.
Access codes Dial
*63 for Selective Call Divert Dial
*68 for Selective Call Accept Dial
*60 for Selective Call Reject
Step3 For Selective Call Divert you will then hear the 'divert to' number that is currently entered. If this number is correct press 1. If it is incorrect, press 0, then re-enter the phone number you wish to have your calls diverted to. When turning this feature off dial 3 again.
Step 4 The feature is now on/off.
Step 5 Replace the receiver.
Note: You can divert calls to a local, national or mobile. However, you cannot divert calls to emergency, 0055, 1900, 008, 1800, 0050, 13, 1300 or international numbers.
Hope it helped.
Thanks for using fixya...
Jan 11, 2011 | Cell Phones
I just purchased a STR-DG820. I get a green light when I turn on the power, but I get no digital display. I tried it standing alone, then with components connected - same outcome. Because of an error in...
Didn't you get a manual with either one?
Page 29....
>>> Before using the receiver for the first time, initialize the reciver by performing the following procedure. This procedure can also be used to return settings you have made to factory defaults.
1 Press POWER to torn of the receiver.
2 Hold down TONE MODE and 2CH/A DIRECT and then press POWER to turn on the receiver.
3 Release the TONE MODE and 2CH/A DIRECT after a few seconds.
After "CLEARING" appears on the display for a while, "CLEARED" appears. <<<
See if that helps.
Mar 22, 2010 | Sony STR-DG820 Receiver
Acer travelmate 290 beeping, starts with blue screen and then black and beeping
See if there is an error beep. If there is an erro beep, then change
main board.
Power off. Then check if RAM CPU BIOS are well-connected.
Press Fn+F5 three times slowly
LCD FPC
LCD inverter
LCD
USB does not work correctly USB device cable is firmly connected into the USB ports. Test
Oct 29, 2009 | Acer TravelMate 290 Notebook
Latitude D600 beeps twice
that may be because of a bad connection with the harddrive thats easy to fix you just take the harddrive out and blow the connecting surface clean then it should behave normaly agian:)
Jan 04, 2009 | Dell Latitude D600 Notebook
Recieve but not send
Is your handset plugged in the right hole. Customers occasionally plug the handset in the hole marked ext.
Dec 07, 2007 | Brother IntelliFAX 1270E Plain Paper Fax
Handset doesn't turn on; press a button, beeps and turns off
from a different brand portable phone - - it worked for me! "If you experience difficulty with placing/receiving calls, a lost security code may be the problem. The handset cannot communicate with the base. Unplug AC adapter. Disconnect handset battery for 10 seconds. Reseat the battery and then place in base. Replug AC adapter."
Oct 22, 2006 | Panasonic KX TC901W Cordless Phone...
V1 Radar Detector Logo
394 people viewed this question
Top Valentine One Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Valentine One Vehicle Part and Accessory Expert? Answer questions, earn points and help others
