Question about Uniflame 153100 Open Flame Patio Heater
I need a manual for the uniflame 153100 model or sn.006007115 robert
I need a manual for this product.
Helloo there,
Well here are a few
http://outdoorcooking.manualsonline.com/manuals/mfg/uniflame/uniflame_gas_grill_product_list.html
You REALLY need to get the exact model number and search online for it or try here for a start to your quest
http://www.grill-parts.com/uniflame/models/uniflame-grills-main.htm
Sep 16, 2014 | Uniflame Grilling
I need type of motor for mercury outboard motor, I only have sn
Good Morning Robert Please Take Photo And Post,
What Further Info Are You Looking For
Mar 20, 2014 | Boating
I need an owners manual foe uni-flame gold gass grill
I needn an owners manual for UniFlame Gas Grill # GBC772W
Seril # 0646005257 06-2011
Jul 05, 2012 | Uniflame Grilling
I am looking for replacement burners (4) for a uniflame grill model gbc772w-c. The original ones were brass.
You don't see brass burners much any more, because of the iron content. However, stainless steel replacement burners are available for your model. Check them out at the link below.
http://www.clagrills.com/grillparts/uniflame/uniflame-grill-parts-home.htm
I hope this helps you and Happy Grilling!!
Jul 19, 2011 | Grilling
Pilot light will not stay lit, even after holding for the required 60 seconds. Need manual and replacement parts.
Go to the Uniflame Home web page and you can download the Owners Manual for your heater in a pdf format. You can also order parts or find a dealer in your area that stocks parts. Uniflame is owned by Blue Rhino.
Jan 26, 2011 | Uniflame 200209 Open Flame Patio Heater
I have a sunjoy patio heater and i can light it be after about 30 seconds it makes a click noise and goes out like gas is cut off. What is the problem and where can i order parts?
The thermocouple needs to be replaced. If you still have your Owners Manual it will show you a parts breakdown and how to replace it. If you don't have it, go to the Uniflame home page and search for the owners manual for that model heater. You then can download it in a pdf format.
I believe the website address is www.uniflame.com. Uniflame is owned and manufactured by Blue Rhino.
Jan 24, 2011 | Uniflame 200209 Open Flame Patio Heater
I have an Endless Summer (Blue Rhino) patio heater with model number 153100 and the pilot flame is not strong enough to keep the thermal coupling open. What has to be done to fix that?
The pilot jet may be clogged. If there is a flame, it must be small and blue. A large flame that is orange or yellow tipped means that there is a partial blockage in the pilot assembly which needs to be cleared. The pilot flame must also touch the thermocouple in order to heat it correctly. Make sure that the pilot jet and thermocouple are positioned correctly. If you have an extremely small pilot flame, try repalcing the regulator and hose as the regulator may be failing.
Sep 02, 2010 | Endless Summer 153100 Open Flame Patio...
I purchased a barbeque and ended up with a natural gas instead of propane can it be converted to propane if so how? it is a UniFlame 4 burner with side burner cant find model on there web site
Yes but you need to replace the valves, burner orifices as well as the regulator the screws into the propane tank. Go to cagrills.com and search their models for the proper parts.
Jan 14, 2010 | Uniflame Heating & Cooling
Uniflame 153100 Open Flame Patio Heater Logo
Top Uniflame Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
John Rodgers
John Rodgers
Are you an Uniflame Heating and Cooling Expert? Answer questions, earn points and help others
