Question about Saeco Magic De Luxe Espresso Machine
Saeco Magic type sup 012 problem
Howdy! Our old Saeco Magic Superautomatica de luxe, Type Sup 012, is having a major problem. It had been leaking lots more water the past month or so, but making the normal amount of coffee. Then a couple days ago it started making a constant noise as though it were cleaning itself after making a cup of coffee, along with producing an electrical burning odor (i.e., from a blown electronic component, rather than simply burning coffee).
Even when I turn it off by the power button, it continues to make the noise, and after 20 or so seconds of that, the light comes on telling me that the central unit is not seated properly (although I think it really is).
The sound seems to be coming from behind the dispenser tubes, i.e., inside the unit. (It doesn't seem to be a problem with the grinder, or the water heating unit.) The top of the unit -- the "hotplate" area -- gets quite hot.
Any ideas on the problem, if it's repairable, and if so, how much it'd cost to fix?
Sincerely,
Harold Kyriazi
  • sad_loser Apr 12, 2009
    I have a magic as well. has been working problem-free for 6 years, but now pulling the slops drawer out shows a niagra happening behind.
  • bansheracer May 11, 2010
    Hi
    If this is a Magic Delux, you could have a boiler leaking and now its spraying water inside. If you haven't done any damage to the CPU this is repairable but don't keep using the machine until its fixed. If the machine is a Vienna Delux it is probably the same thing.
  • 1,089 Answers
Hi sad_loser
Your problem is easier. On the top left side of the brew unit is a thumbscrew that holds the filter screen in the brew head. See if you push down on the thumbscrew you can get the filter screen to move? If it dose pull down on the filter screen and see if it will come out. If it does there will be an extra nut on the screw end and that needs to be removed and you need to order a new thumbscrew. That is why we call it a thumbscrew. It only has to be finger tight. The key is only for removing.
Posted on May 23, 2009
3 Suggested Answers
mirran
  • 515 Answers
SOURCE: help saeco deluxe sup 012
I have in Italian
Posted on Jul 13, 2008
espressodoc
  • 29 Answers
SOURCE: saeco magic de luxe cleaning grinder
I don't know what you mean by disarming the grinder. Unless you are talking about using the bypass. If that is the case there is a button on the panel that has waht looks like a scoop. Push that button and put a scoop in the bypass door and then push the button for what cup size you whant. Regarding the taste of the coffee. It may need a cleaning and service. Try googling "saeco repair" and find an authroized Saeco repair center and have a good service done on it.
Posted on Aug 27, 2007
Saeco Vienna digital coffee maker sup 018d after starting display group blocked but on hand this work
The machine's brew unit motor is not working correctly and needs service. A wire may be broken, motor can be burnt, or the power board is not sending enough power to the motor.
Best to bring it to a service center.
http://www.cerinicoffee.com/espresso-parts/espresso-machine-service-center-new-york.html
Aug 05, 2013 | Saeco Vienna De Luxe Espresso Machine
We have a saeco magic deluxe maker SUP 012 that has a cracked water reservoir. We would like to order a new one. Could you please advise us? Thanks
Howdy, they don't have a central online parts distributor, but rather several physical locations throughout the states. I was able to get their customer service number, though, which may be of the best use to you.
Saeco Customer Service at 1.800.933.7876
hope this helps:)
Farmerbear
Aug 31, 2010 | Saeco Magic De Luxe Espresso Machine
Saeco Roayal Sup 016
Hi
I am assuming your machine grinds, then clicks twice, then the brew drive starts but you never hear the pump.
If this is so? The there is a lever at the top center of the door on the right. Pull the lever back 1 click, and try again.
Mar 10, 2009 | Saeco Vienna De Luxe Espresso Machine
Saeco Magic de luxe SUP 012
open the machine up and follow the line from the spout (which should give the coffee) till the boiler. The spout most likely is clogged.
Follow THIS LINK for parts etc,
Jun 01, 2008 | Saeco Magic De Luxe Espresso Machine
Temp light not on and coffee is dead cold.
I think your boiler is broken, look at www.saeco.com to locate a service center near you
Oct 28, 2007 | Saeco Magic De Luxe Espresso Machine
Saeco magic de luxe cleaning grinder
Aug 20, 2007 | Saeco Magic De Luxe Espresso Machine
Saeco Magic De Luxe Espresso Machine Logo
619 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
Mike Cairns
Mike Cairns
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
