Question about Fellowes Powershred C-220 Strip-Cut Shredder
Our PowerShred C-220 was jammed - when we unjammed it, it no longer will shred automatically when paper is fed into it. It will shred continuously when we push the 'I' button and it will run in reverse and it will only stop when we push the 'O' button.
  • msr1 Jan 08, 2009
    Do not remember our shredder becoming jammed but we have the same problem with ours. It runs continuously when turned on.
  • mjhapd Jan 15, 2009
    Ours won't run at all now. The motor hums,and the jam light comes on. No forward, no reverse - no nothing!
2 Suggested Answers
POCBM
  • 121 Answers
SOURCE: PowerShred C-220 will not shred automatically
OK lets try.
You likely have a photo sensor that detects the paper and it is dirty.
It is likely covered with paper dust (hopefully only on the outside)
Locate the sensor and wipe it off or just wipe the entire throat area.
WITH MACHINE OFF
Hope this helps
Posted on Mar 15, 2009
How do I get top off to clear Paper Jam on Fellowes PS-12Cs
FELLOWES SHREDDER
In case of a paper jam , which may occur if the shredder is pushed beyond its specified capabilities, press the control switch to the off [O] position and empty the basket if full. Then:
1) Press and hold control switch in reverse [R] position and attempt to back paper out of shredder.
2) If shredder jams in reverse mode, press control switch to automatic [I] position and attempt to continue shredding operation.
3) If shredder jams again, alternate control switch slowly between reverse [R] and automatic [I] positions to attempt to move jammed paper completely through shredder.
If you are unable to clear the jam using this method, turn off and unplug the shredder; remove the wastebasket from cabinet and carefully remove any paper extending below the cutting cylinders; empty the wastebasket; insert wastebasket and repeat jam clearing procedure.
May 23, 2014 | Fellowes Powershred PS-12Cs, 12 Sheet...
Fellowes Powershred 220 gives a perfect cut on half of the paper only? How can this be fixed to give a perfect shred across a whole sheet of A4 paper? Can anyone help?..PLEASE..
Welcome to fixya
Hello
I have a solution for this
Press Ok, Accept or replay so we may get started
Your pre-solution is coming up shortly
PLEASE REPLY OR LEAVE COMMENT TO CONFIRM YOU RECEIVED THIS EMAIL
My name is Bruce
Jan 16, 2011 | Fellowes 220 Powershred Strip-Cut Shredder...
Jammed in Auto, but works fine in reverse. How to unjam?
Continue to alternate between auto and reverse a number of times. Try to shred narrower pieces of paper at opposite ends to see if it can trigger the auto trigger wire. All else fails, carefully take the shredding part apart and you may find a hugh paper jam underneath.
Sep 02, 2010 | Aurora Electronics AS662C Shredder
Need a sensor switch for fellows powershred 220. Won't sense paper.
The top sensors may be bad or even the main board that they are connected to is bad. Try cleaning them with a lightly moistened swab or compressed air. Fellowes will sell you the parts.
Apr 29, 2009 | Fellowes Powershred 220 Shredder
The "bin full" keeps on coming on
first off, fellowes has had problems with the bin full sensors that sometimes, can only be corrected by replacing them. however, there are two things to check. make sure it doesn't have a bunch of shredded paper hanging down from the cutters. that can trigger the bin light as the sensore are located under the head, but above basket. last, but not least, clean the sensors. they get paper dust on them after awhile causing same indication. if those two things don't fix it, it will have to have sensors replaced.
good luck,
razors
Jan 20, 2009 | Fellowes Manufacturing Powershred C-220...
OK lets try.
WITH MACHINE OFF
Hope this helps
Dec 05, 2008 | Fellowes Powershred C-220 Strip-Cut...
Unjamed, but jammed light remains on and won't shred
Most likely the PC board has gone bad. It will cost over 100.00 from fellowes.
Sep 06, 2008 | Fellowes Powershred 480 Shredder
Jammed shredder
First UNPLUG THE MACHINE.
Unscrew four (4) screws, two in front underneath top cover and two in back of top cover. BE careful not to disconnect any wires.
Rotate motor gear or belt in reverse to remove jam. Do not put oil on paper because it expands the paper thickness and only makes it worse.
Sep 02, 2008 | Fellowes Powershred 480 Shredder
Shredder stops in the middle of shredding and won't shred.
Is the paper bin full?....mine always shuts down when the paper bin is a little over half full.
Jan 21, 2008 | Fellowes 220 Powershred Strip-Cut Shredder...
Fellowes Powershred C-220 Strip-Cut Shredder Logo
81 people viewed this question
Top Fellowes Office Equipment & Supplies Experts
quennie732
Charles T Nevin
Charles T Nevin
Adorjani Laszlo
Are you a Fellowes Office Equipment and Supply Expert? Answer questions, earn points and help others
