Question about Acer X193W LCD Monitor
Words are stretched - computer runs on Windows XP
I can not set my computer on resolution 1440x900. My words and pictures are stretched and I have tried multiple ways to fix it.Should I just exchange the monitor or is there a solution to my problem? I just had a new computer made for me and it seems that the person who made it does not know how to solve the problem either.
  • Anonymous Dec 09, 2008
    me too!huhu...
  • 102 Answers
The resolution issue you are describing sounds like a video card driver issue. You must determine what video card or chipset you have and apply the appropriate driver. The Acer x193w monitor is plug and play, it will display whatever the OS sends to it provided it is within its display range and 1440x900 is definitely within that range.
Posted on Dec 20, 2008
I have installed viewsonic va1716w monitor using windows xp. I am unable to set its resolution to 1440X900. from display properties it going from 1024X768 to 1280X1024
It is possible that the video driver cannot support 1440X900 resolution.
Try installing the latest video driver and then try the higher screen resolution.
Mar 19, 2011 | ViewSonic VA1716w Monitor
How do I get my gateway fpd1975w tft lcd monitor to not stretch images images across the screen?
You need to make sure your computer's display resolution is set to 1440x900, which is the monitor's native resolution. Other resolutions will result in fuzzy displays or, as you're seeing, distorted images.
Right-click on an open area of the Windows desktop (that is, not over any icons), then select "Properties" from the pop-up menu. Click the "Settings" tab and you'll find a slider adjustment to set the resolution. If 1440x900 is not offered as a resolution, you'll need to upgrade your video card (or add a video card if you have a motherboard with integrated video). Most newer computers support that resolution, but some older systems may only go to 1024x768.
Thanks for using Fixya!
Oct 20, 2010 | Gateway FPD1975W 19" LCD Monitor
Samsung 920WM monitor - Color problems, "blotches"
The 920WM has a recommended resolution of 1440x900. If your display properties are set to a higher or lower resolution, there will be ugly effects on videos, photos and fine text.
If you're running WindowsXP, minimize your apps and web browser so you can see the background.
Right-click on the background and select "Properties" to bring up the display properties dialog.
In that dialog, select the "Settings" tab to see the display resolution.
Set that to 1440x900 if it's not already, then hit "OK"
If videos are still blotchy, then check the video playback software to make sure it's not setting it's own resolution.
If that helps, please be sure to hit the "thumbs-up" button for me.
If not, use "add comment" to fill in some more details (XP or Vista? What's the video playback software called? How are you viewing pictures?) and I'll do my best to help!
Jan 05, 2010 | Samsung SyncMaster 920WM LCD Monitor
How do i set my x193w lcd monitor to hd?
install the CD that came with the monitor else right click on monitor screen in windows and adjust on properties menu
Nov 22, 2009 | Acer X193W LCD Monitor
Windows XP Not displaying fully on 1440x900 resolution.
If you have one of those older CRT monitors you should be able to resize the image. Some LCDs have screen shifting tools too. Try doing a full restart, too. (shutting your computer down, waiting 1 or 2 minutes, then starting it up again.)
Nov 09, 2009 | BFG Technologies NVIDIA GeForce 9600 GT OC...
I recently purchased and installed the P191W monitor, and now my pictures are stretched. I was told I new to get a new graphics card. What card should I get? Or can I just update the driver? I am running...
Find your monitor's native resolution, in your case it's 1440x900. Go to display settings (usually right-click on desktop and choose properties), go to settings tab and move the resolution slider until it shows 1440x900. Confirm, the screen should flicker for a moment and adjust - and you should be fine.
If there is no 1440x900 resolution available, then installing a monitor .inf file that came on a disk accompanying the monitor might help.
Oct 24, 2009 | Acer AL1916W 19" LCD Monitor
Acer P193W monitor stretched image
What service pack of windows xp are you running? Also, do you have your old monitor, if so, then plug it in and see if the same problem occurs. If not , go under the settings for your graphics card (not windows display options) and see if there can be a correction made to the settings for your monitor. Also, try going to microsoft.com and updating your computer (it's free) and you'll probably get the required driver to fix the problem from them. Check under your control panel and see if you have automatic updates turned on, if so you may want to limit what updates are to be installed by allowing updates but you choose which one's to install. Hope I could help. My e-mail
tallcoolone@yahoo.com .
Jan 04, 2009 | Acer X193W LCD Monitor
Screen resolution for LG 194wt
Hi, Afraid the only operating system now is windows 10 on any PC unless your using a Mac system. Once you upgrade to windows 10, everything will automatically set everything correct for you & you will be surprised how it will speed up your system! this is the best Microsoft release operating system they have ever made. Please leave me feed back: Malcolm Campbell, Thanks.
Nov 11, 2017 | LG L1915S 19" LCD Monitor
Proview wb926wbi monitor
Try changing the resolution to 1440x900. This is the ideal resolution for this monitor.
To change the resolution:
Right click on an empty space on your Windows desktop.
Choose Properties (XP) or Personalize (Vista)
Choose the Settings tab (XP) or Display Settings (Vista).
Slide the resolution slider to 1440x900, then click apply.
If asked whether you want to keep this setting, choose yes/ok.
Note: Not all video cards support this resolution. Updating your video card's (not monitor's) driver may add it.
Jun 29, 2008 | Proview PL926WBi 19" LCD Monitor
Acer X193W LCD Monitor Logo
271 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
