Question about Panasonic CT-32HXC43 32" TV
Fuse location on tv
I think my fuse is blown but i have no idea were it is or what looks like. Is it like an automotive fuse? is it behind the back panel?
    Scholar:
  • 168 Answers
A fuse is a small glass tube about 3/4" to 1". it is located near the end of the power cord inside the tv. it is located in the power board supply circuit. there are several reason why fuse blew up. 1. sudden surge current/voltage in your area 2. shorted in either power supply or horizontal deflection circuits. when replacing fuse, be sure to change it with the same value. but if after replacement has been done and the fuse blew again, there is a short in the circuit as stated in reason no. 2. refer to a qualified service technician if you are not inclined with this job. good luck!
Posted on Feb 13, 2007
Samsung plasma 55" tv won't power on. Model: 850FH-YB01. Bight flash on wall behind the tv. TV off. I think my power source is bad. But what is that, How or where do I purchase one from?
The power board is the one that the power lead connects to on the back of the panel there is two fuses on the board check them for continuity and replace if blown with ones of the same values
look at the tops of the capacitors for popping they should be flat topped not bulging up replace any that are bulging
finding a supplier for you without a geographic location for yourself is not possible
also you can get the power board repaired or replaced but the power surge during the failure could have damaged other components making it cheaper to replace the whole TV with a new one
Dec 28, 2016 | Samsung Televison & Video
My 1994 explorer will run fine only sometimes the headlights windshield wipers blinkers and door locks will stop working. electrical short but have no idea where to start looking. Any ideas? Bill
I wouldn't think a short , would blow a fuse ! A lose connection more then likely . A ground connection to be specific . You would need to look at a wiring diagram for each of the affected componets to see if they share a common power (fuse) or a ground point on the body , chassis etc... You can look at free wiring diagrams at http://bbbind.com/free_tsb.html And do a voltage drop test on the circuits to find which part of the circuit has the problem .B+ voltage or ground side . There are videos on youtube showing how to do a voltage drop testing . It would also be a good idea to have a repair manual that shows ground locations . Ground locations can be behind the dash panel , left or right kick panels . I mean they hide them in places you wounldn't even think . Automotive electrical testing is one of the must time consuming jobs there is . The fix mite be as easy as just tighting a nut on a ground stud . But finding an getting to it are another story . I have had to pull instrument panels to get at bad grounds . Good luck !
Dec 04, 2016 | Ford Explorer Cars & Trucks
Corsa xi 2001. The radio has no power. The fuse is ok. Is there a second fuse behind the radio that requires the radio to be removed to check or replace? Any other ideas. The battery is low.
there should be a fuse in back of radio also check your fuse panel see if one has blown cause not sure if radio in panel runs off cigarette lighter and interior light also, worth checking, also check wiring at back off radio maybe connector has come loose. Another thing charge the battery lol
Oct 25, 2016 | Cars & Trucks
How can you tell when a fuse is blown under the hood Can you show pictures I want to see this is supposed to look like
Hi Lisa.
The specifics of where your fuse panel(s) is/are will depend a lot on the make and model of your car. There is often one panel in the passenger compartment, and one in the engine compartment. This WikiHow page does a pretty good step buy step of identifying panels and locating / testing fuses for if they're blown: How to Check Fuses
This is an example pic of good vs blown fuse:
image blown automotive fuse Google Search
Good Luck and Happy Holidays!
D
Dec 09, 2015 | Cars & Trucks
Where is the circuit breaker panel on a 2012 Salem Villa Classic 372REDS?
It should be near the floor - look for a brown or black square - the circuit breakers may be behind the door - you may have to turn the black plastic pieces 90 degrees or you may just have to pull down on the cover. Instead of circuit breakers, I think they used automotive fuses. There should also be a fan in there that runs when the AC is plugged in to cooler the rectifier.
Feb 13, 2015 | Forest River 2012 Salem Villa Classic...
Where is the radio fuse on a 1995 camry? I do not see a fuse box under dash.
1.Answer It is a 15A fuse (#24), located in the instrument panel fuse box (behind the small fold out draw on lower the left side of dash board. Left of the steering wheel). It is the far right fuse on the middle row.
2. I had the same problem when my dome light went off. When I pulled its blown fuse, the radio went out. The radio fuse was fine, but when I replaced the dome light fuse, the radio came back on again. The dome light fuse is a 20A in the fuse box under the hood next to the battery.
3.there is on fuse in the back of the radio itself
Jan 13, 2015 | 1995 Toyota Camry
No picture on toshiba 42" flat screen tv
Definitely a blown fuse, you just need to locate it.
Look up the diagram for your make and model.
Dec 22, 2017 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
Cub cadet
This will have blown the main fuse, they are normally automotive style fuses, it should be located somewhere behind the dash board.
Jun 09, 2013 | Garden
2001 2 series saturn.....both turn indicators will not work...changed the fuses still dont work
if both do not work I'd check the flasher unit first or look for a blown fuse (by the passenger side left knee, behind the cover on the console.) The flasher unit is behind the bolster cover above the driver's knees.
Mar 03, 2011 | Saturn S-Series Cars & Trucks
My kenmore 400 electric dryer stopped working. im told the fuse might have burned out but when i looked for the fuse there was none. the light in the dryer still comes on when you ope the door so power is...
The internal 'thermal' fuse may have blown. This fuse is on the back of the dryer, behind the panel. just to the left side of the vent outlet. It is white with 2 wires going to it.
This fuse trips if there is too much heat around the vent, usually caused by an over heating operating thermostat, which is right next to the thermal fuse and is black with either 2 or 4 wires going to it. The other thing that can cause it too get too hot is a restricted vent system, make sure you have good air flow all the way outside.
Apr 22, 2010 | Kenmore 400 6942 Dryer
Panasonic CT-32HXC43 32" TV Logo
438 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
