Question about Kodak EasyShare C330 Digital Camera
I dropped my Kodak EasyShare C330 when the lens was out and now I'm getting the error messages 12 & 22. I tried pulling out the lens because it was stuck and it caused the lens to now move around in the socket. The front part of the lens is also a little bit detached. I was wondering if there was anyway to fix this problem without having to pay for a repair shop or Kodak to fix it?
  • 6,831 Answers
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance.
Regards
Andrea
Posted on Sep 30, 2010
Kodak c330 error 22 lense
pull the lens when you turn it on.... something has jammed the gear about half way out and will need to be released.
Mar 08, 2014 | Kodak EasyShare C330 Digital Camera
I Dropped my camera model c330 and the lens will not return. I get lens error codes 22 and 12 and the camera will shut down.
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
Jan 02, 2011 | Kodak EasyShare C330 Digital Camera
My kodak c330 turns on thens says lens error 12, and the lens door will not open. what does this mean and how do i fix it?
Dec 24, 2010 | Kodak EasyShare C330 Digital Camera
How do you fix lens error 12?
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try:
Feb 21, 2010 | Cameras
Lens on camera (kodak easyshare c330)
Hi There,
Try removing the batteries the reinstall them and press the Power On Button. Let me know if the lens retracts.
Mar 30, 2009 | Kodak EasyShare C330 Digital Camera
Kodak Easy Share C330 lens error 14 and lens error 22
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Oct 08, 2008 | Kodak EasyShare C743 Digital Camera
Camera error message
This suggests a stalled lens motor.
Check Kodak for repair costs
A new camera may be as cheap.
Dec 26, 2007 | Kodak EasyShare C330 Digital Camera
Lens won't come out,lens error 14,kodak c330
same thing happened on my camera. think it got dropped. lens only comes out part way. pull out with fingers and then lens works fine.
Nov 27, 2007 | Kodak EasyShare C330 Digital Camera
Lens error 12 & 22
Our school uses this camera. It's reporting a lens error 12 and the lens does not extend. Bumping it did not work, nor does pulling the lens out with a fingernail.
One teacher said that another school had LUCK by installing a new battery pack. The old one might not hold enough power to fully boot up the camera, causing the lens error.
I have noticed that the battery does not hold a charge for any length of time. This will be our next approach.
Cameras that are dropped, banged or bumped are not covered by a warrantee, so beware.
Oct 22, 2007 | Kodak EasyShare C330 Digital Camera
Kodak C330 [lens error 14]
Hey Sarah, I'd say that up to 5 min ago, I was having the same problem. My camera (Kodak C330) had been giving me this Lens Error 14 for about a month and I hadn't been able to make it work. The first 2 times it did that, I turned it off and on again, but then it just would work anymore. I tried opening it but it wouldn't let me so I thought I was screwed.. until I found this forum where people seemed to think that banging on the bottom and pressing hard on the lens would fix the problem. I had nothing to lose so I tried and guess what: Now it's working fine again! I had taken it to the beach and I'm not sure if it's because I had gotten sand in it or water perhaps but in the user manual, it said that getting that error message after dropping it or getting it wet was voiding the warranty. So there. Hope that helps! ~Vero
Aug 26, 2006 | Kodak EasyShare V550 Digital Camera
Kodak EasyShare C330 Digital Camera Logo
Top Kodak Cameras Experts
Tony
Greg Cann
Greg Cann
Are you a Kodak Camera Expert? Answer questions, earn points and help others
