Question about Moultrie GameSpy 4.0 Digital Camera Deluxe
Will a Kingston 4 GB HC card work in this camera?
On the card package it states that this card is not compatable with all
devices & i dont wont to damage the camera.
Thank you
Yes, the 4Gb SDHC will work.
I use those at 3 different D40 myself.
/Stefan, Sweden
Posted on Jun 23, 2009
I just put a Scan Disk 4GB HC card in my D40 last night. The card said it would only work in devices made for HC. It seems to work fine.
Posted on Jan 05, 2009
My computer wont format my micro sd card
Is it an SD card or a microSD card? If it's a 4GB (or larger) card then it's neither, but instead an SDHC or a microSDHC.
If the card is an SDHC/microSDHC then your card reader may be only SD-compatible. If this is the case then you can buy an SDHC-compatible card reader and use that. Alternatively, if you want to use this card with some other device, such as a camera or a phone, format the card in that device instead of in your computer.
Jul 10, 2012 | SanDisk 4gb Class 4 Sdhc Sd Hc Flash...
Computer Cannot read my SD Card
STOP SD MEMORY CARDS ARE NOT ALL THE SAME !This is a very common issue as of late because of the fairly recent addition to the market place with the "HC" and "XD" Cards. I have found most computer older than 2008 wont read HC and XD cards however I'm sure there are USB card readers that can fill this gap available at your local pc shop. Please look Carefully at these different formats Standard SD: 1 MB to 4 GB readable by almost all computers most often up to 2GB rarely up to 4GB 6468175.jpg
SDHC: 4 GB to 32 GB Most older Computers Cannot read the the HC format, good however for NEWER devices such as camera's, video cameras and recent phones (my cannon powershot S80 will NOT read HC format, nor will my 2007 laptop.)
SDXC: 32 GB to 2 TiB same limitations as above, Great cards for Digital Video Camera though!
here is a wikipedia note "Changes to the interface of the established format have made some older devices designed for standard SD cards (≤4 GB) unable to handle newer formats such as SDHC (≥4 GB). All SD cards have the same physical shape, which causes confusion for many consumers"
So.. in closing MAKE SURE your device supports HC and or XC before your purchase one! Also be aware that most of these cards have a lock switch on them to write protect the data, located on the side of the card. It MUST be in the Unlocked position to operate normally. Hope this helps someone out there. please use the thumbs up if it clears up anything for you! Gurvy
on Aug 31, 2010 | Computers & Internet
The only sd card i can find locally is an 8gb marked PNY SD HC it says on the packaging that this is new technology and only compatible with SD HC host devices. Is this card suitable for the Vivitar...
To be correct, the 8GB card is not an SD card but an SDHC card.
The 925DVR can use both SD and SDHC cards, up to 32GB in size. There should be no problems with the PNY card.
May 08, 2011 | Vivitar Cameras
Hi there i have a jvc gz mg20ek and have just bought a 4 gb memory card. i have formated it but when i try to copy/move from the hard drive to the card it just asks to insert memory card which it then...
If the memory card says HC on the label, there is a chance it is not compatible with your device. HC stands for high capacity, and is not compatible with older devices. Unfortunately you will have to stick with smaller memory cards, or upgrade your device.
Mar 14, 2011 | Cameras
I just put a new kingston 4 gigabite SDHC card in my Emprex 5 megapixel camera, and to my surprise, the camera froze up, the lens came out but nothing else happends, or works. Hmmm. Maybe it's a...
probably either: too big for the camera or the HC is not compatible. Did you try to format the card? Put the other one back in and see if that one still works. If so, take the card back, with thte camera and show the vendor that it does not work. Get a Non-HC card. It will probably be smaller as well, because the bigger capacity is a relative design increase with the speed (HC).
Sep 16, 2010 | Kingston 4GB Secure Digital High Capacity...
Should you use an 8gb sd memory card in a panasonic lumix dmc-fx3 camera ?
The manual lists the following SD cards compatible:
4 GB SDHC Memory Card
2 GB SD Memory Card
1 GB SD Memory Card
512 MB SD Memory Card
256 MB SD Memory Card
128 MB SD Memory Card
64 MB SD Memory Card
An 8GB card may or may not work. If you try it, make sure it is an SDHC card. (Note: HC=High Capacity)
Thanks for using Fixya.
Apr 27, 2010 | Panasonic Lumix DMC-FX3 Digital Camera
Sd card issue
According to the manufacturer specs, only the mmc and sd flash protocols are supported. The sd hc protocol is not supported. There are some 4 gb sd cards that were produced before the sd hc format was produced (starting at a 4 gb capacity). Try a few different manufacturers for the 4 gb sd card.
Mar 19, 2009 | Casio Cameras
Camera Memory Card Capacity
Hi there, and welcome to FixYa.
First, make sure your cards are either, SD or MMC. Any other type won't work.
If they are SD and/or MMC cards, then the reason the cards aren't working is because they have to be formatted in the camera BEFORE you use them. Use the camera to format the cards, don't use your pc or a card reader.
The manufacturer says to use a 2gb card, but that doesn't mean you can't try a higher one. The only thing is that maybe it won't format the card right. Or, it may slow down the processing speed. It won't hurt the camera any.
Have fun with your camera. If you have any further questions, leave me a comment, and don't forget to rate my solution.
Mar 02, 2009 | Casio Exilim EX-Z750 Digital Camera
Micro sd card in ke850
When the Prada 1 (KE850) was launched, it officially only supported up to 8 GB SD(HC) cards, but there are SD card manufacturers (i.e. Kingston) which claim that their 16 GB cards work in a KE850.
You could contact LG Customercare to confirm this or go with the 8 GB card to be sure ...
May 26, 2008 | LG Prada KE850 Cellular Phone
Moultrie GameSpy 4.0 Digital Camera Deluxe Logo
118 people viewed this question
Top Moultrie Cameras Experts
Are you a Moultrie Camera Expert? Answer questions, earn points and help others
