Question about Whirlpool GR465LXLS Electric Kitchen Range
Kenmore Electric Range Burner Stays on
I have a Kenmore C88066653030 model smooth top range. One burner will not shut off. When it decides to, it cycles off and on for a while. If it does shut off the indicator light says it is still on when it is no longer on. All of these conditions happen when the control knob is in the off position
  • rrixx2 Dec 06, 2008
    I did replace the switch and that was the problem. Thanks for your help.
  • disil Dec 20, 2008
    I did replace the switch and the right front burner will not shut off. Can anybody help me?
    Scholar:
  • 162 Answers
Replace the swich behind the knob.
Posted on Dec 06, 2008
Where are the fuses for the Sears Kenmore stove to elements located on Model C880 675080L0
Most likely no fuses. Either the element or the switch that turns it on is bad. If lighat comes on when you turn on burner the switch is probably ok and the burner went bad.
Jan 02, 2015 | Kenmore Sears Electric Range Surface...
The heat control on one of my burners on my smooth top range doesn't work correctly. The burner is only on when control is turned all the way up, lowering the control turns off burner
the burner; control/switch is bad /unplug range ..pull knob off burner control to see srews..remove back panel on range..1/4 inch srews are used ....look at all them wires an switches ..wow ..locate the bad switch ...buy a new switch from appliance parts store /or one from a used appliance store ..make sure you have the make /and model/serial # off of the range... to get the right switch ...install switch.. remove one wire at a time when installing switch or wright down how it is wired ...let me know ..good luck/joe/
Aug 26, 2010 | Kenmore 95002 / 95004 Electric Kitchen...
Frigidaire smooth top electric stone eye stuck on high!
Yes,the switch controlling the burner is bad and must be replaced.
Oct 31, 2009 | GE Kitchen Ranges
Kenmore glass top range left front large burner out
check the burner socket, it is likely that contact is being lost where the burner connects to the hardwired portion of the system (the socket). It is not unusual for the socket to "burn up" when there is a poor connection to the burner resulting in the burner being replaced and the new burner not working or working intermittently.
Please take the time to rate this solution
Jan 29, 2009 | Kenmore 95002 / 95004 Electric Kitchen...
Dual element burner on glasstop range...inner element stays on
It is the burner control (behind the knob). The triac in the control has failed. $50 item, 10 minute change. Just make note which wire goes to which terminal.
I doubt that it is the control board, as the board has little to do with the stove top, but rather controls the display and the oven temperature/feedback monitoring.
Hope this helps.
Jan 14, 2009 | Frigidaire FEF366DC Electric Kitchen Range
Whirlpool electric range burner power light stays on but no heat
Hello givemeanidth.
Welcome to Fixya
You said, have a Whirlpool electric range (model rf363pxpt0) with standalone burners - the burner power indicator light stays lit whether the heat control knob is on or off, there is no heat coming from the burner on or off. You pulled the burner from the receptacle and one of the tabs broke off and stayed in the receptacle. You removed the tab and made sure no pieces remained in the receptacle then bought a replacement burner, no change. You put the replacement burner in the back burner of the same size and had heat within 10 seconds. You changed out the burner with the one that had been in the back of the range, no heat. As long as the breaker to the range is on the power light stays lit but no power to that one burner only.
What is the model number and the age of your range?
Waiting for your reply.
Huuum
Sep 02, 2008 | Whirlpool GR465LXLS Electric Kitchen Range
Whirlpool GR465LXLS Electric Kitchen Range Logo
821 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
