Question about Office Depot Ativa DQ60M Shredder
Shredder will not turn on, I think it is blocked.
  • 32 Answers
Unplug unit , open it up and clean it out , then lets see what its doing or not doing
Posted on Sep 01, 2009
My fellowes ps-70 shredder has a light on and it's not working
If the shredder is the kind that turns on when you insert paper, it may have an optical sensor that is dirty or blocked. Try blowing off the sensor with some canned air. The sensor is usually located in the center of the paper path slot. Also check that the bin is completely closed. Sometimes a tab on the door is bent or broken so that the shredder thinks the door is open. The tab activates a switch which tells the shredder that the door is safely closed. Fellowes has a lot of good tips on their website.
Apr 22, 2014 | Fellowes PS70-2CD Shredder
No power. Seems to be overloaded
Check the Power Ensure that the shredder top is firmly placed in the shredder basket if the unit will not operate. If the top is not in place the feeder will not work and accept any paper. Make sure it is firmly plugged into the wall outlet and that the outlet is active. Rest the Shredder Let the shredder cool down if the shredder has been running continuously for a long time. It may have overheated and needs to be left in the off position for at least 30 minutes to reset. Verify the basket is empty or not too full as that will cause the shredder to deactivate. Clear Paper Jam Rotate the shredder into "Auto" and reverse to loosen any paper jam that is stopping the gears. Pull out any papers that are sticking out from the shredder feeder. If there is no progress then unplug the shredder and remove the shredder top from the bin. Turn it upside down and use tweezers to free any paper that is blocking the gear. Auto Mode Not Working Select the "Auto" option and feed paper into the center of the feeder tray if the shredder is only working in reverse mode. The sensor is located in the middle of the feeder tray and could be blocked by jammed paper. Use an index card to firmly unblock any paper that could be blocking the sensor.
Oct 25, 2013 | Office Depot Ativa DSD160D Shredder
Paper jam, what to do
Rotate the shredder into "Auto" and reverse to loosen any paper jam that is stopping the gears. Pull out any papers that are sticking out from the shredder feeder. If there is no progress then unplug the shredder and remove the shredder top from the bin. Turn it upside down and use tweezers to free any paper that is blocking the gear. Select the "Auto" option and feed paper into the center of the feeder tray if the shredder is only working in reverse mode. The sensor is located in the middle of the feeder tray and could be blocked by jammed paper. Use an index card to firmly unblock any paper that could be blocking the sensor.
Oct 12, 2013 | Embassy Intek Tx40b 4 Sheet Countertop...
Wont turn on
Oct 01, 2013 | Cross Infoguard Shredder SX102M
I jammed it with too much paper
Sep 17, 2013 | Fellowes W10C Cross-Cut Paper Shredder
The shredder is totally inoperable
Sep 17, 2013 | HSM Office Equipment & Supplies
Shredder stoppped working, no display or power when restarted. Power cable is good.
Aug 07, 2013 | Universal Office Equipment & Supplies
Only runs in reverse
I just had this problem with my shredder. I think the problem started with a bin that was full. Running the shredder in reverse resulted in shredded paper being pulled up into the slot used to feed paper into the shredder. Some of this shredded paper was blocking the little plastic tab that activates the switch when paper is inserted, so the shredder would no longer start when paper was inserted. I emptied the bin and removed the shredded paper from the feed slot, being careful not to break the plastic "sensor" while removing the paper from under it. The shredder works fine now.
Dec 13, 2010 | Fellowes W11C Confetti-Cut Shredder
Runs only in reverse
Nov 06, 2010 | Fellowes W11C Confetti-Cut Shredder
Shredder model SPL TMC 16 A will not turn off automatically
my brother took the shredder apart and found out that when you oil, the oil goes between the lens so it thinks something is there when not, he had to take it apart and clean the lens which would void warranty. its also possible that the oil on the lens collects dust and also blocks the infared eye
Jun 30, 2009 | Fellowes DM15C Shredder
Office Depot Ativa  DQ60M Shredder Logo
Top Office Depot Office Equipment & Supplies Experts
Anthony Karuku
quennie732
Stan Marciniak
Stan Marciniak
Level 1 Expert
Are you an Office Depot Office Equipment and Supply Expert? Answer questions, earn points and help others
