Monitor issue have SVA 17" silver monitor and when I hook it up to pc it makes a quick-loud buzzing noise and then shuts off after a couple of seconds. Can you tell me what this might be and is it worth trying to repair? thank you!
  • staasee Dec 07, 2008
    forgot to mention that I actually can see the desktop & icons when it is on for those two seconds...would this still be the same problem? thx
    Champion:
  • 293 Answers
Hi...there,
lt's seems you got a busted backlight inverter. You can try to repaired by replacing a couple of faulty capacitors. Good luck!
Posted on Dec 07, 2008
USER Manual For Need a SVA VR-17B LCD Monitor
Did you try their web site? http://www.sva-usa.com/
This is 2005 model so it will be real hard or impossible to get.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Jun 25, 2011 | SVA-USA VR 17S 17" Flat Panel LCD Monitor
My screen is green I cant find the menu key on my sva monitor
You need to find menu button - it's got to be there somewhere. If you do find it, go to the "tools" menu (show a wrench and screwdriver), then select the "RECALL" option. Press then right and/or left arrow on that option. This fixed same problem on my SVA Monitor
Good Luck
Nov 19, 2010 | SVA-USA VR 17S 17" Flat Panel LCD Monitor
Display or power issues with my 17'' LCD screen (SVA LCD #7500L )
Check the high voltage ballast transistor.. see if one of them is burnt... If none.. it could be overheating when supply with current. The ballast transformer supply high voltage for the backlight inverter..If these were overheating then the supply voltage for your monitor will be unstable.
Check also the backlight inverter (cold cathode light) if it is busted.. the function of this backlight inverter is to give display image on the screen.. If these were busted then what you will be seeing is black on your screen. You can also replace this.
Please rate this solution if this help you. thanks..
May 27, 2010 | SVA-USA VR 17S 17" Flat Panel LCD Monitor
Monitor comes on, then goes blank
it an error on main board, check for dry joints, resoldering, and leaky capacitors..check out
Oct 25, 2009 | SVA-USA VR 17 17" Flat Panel LCD Monitor
Unknown mods sva vr17s
A little more information about your requirements on assistance may help.
Oct 10, 2009 | SVA-USA VR 17 17" Flat Panel LCD Monitor
I CANT GET MY MONITOR TO TURN ON
It could be the Monitor, the VGA adapter, or the PC itself. If you power on the monitor without anything connected to it, do you ever see anything on the display?
If not, it is probably the Monitor. If yes, it is likely the vga adapter and/or PC.
Mar 18, 2009 | SVA-USA VR 17S 17" Flat Panel LCD Monitor
''Out of range'' message on an older SVA monitor
This usually means the display resolution settings on your PC are set too high for the monitor to display the signal. Try lowering the resolution on your PC.
Mar 16, 2009 | SVA-USA VR 17S 17" Flat Panel LCD Monitor
SVA VR 15A flat screen monitor does not complete boot up.
It sounds like that monitor has a leakage problem on the ground or shield. This is a common flaw that forces intel motherboards to keep from booting. If you carefully cut the outermost layer of monitor cable away (it looks like a basket weave made of metal threads) that surrounds the other signal cables inside, this problem will go away.
Mar 08, 2009 | SVA-USA SVA VR 15A 15" Flat Panel LCD...
Computer making noise
Monitor clicks, pops, or makes other noises. Issue: Monitor clicks, pops, or makes other noises.
Cause: This issue could be caused by any of the below possibilities:
  1. Monitor degaussing.
  2. Monitor changing resolution.
  3. Monitor syncing with the video card.
  4. Monitor warming up.
Solution: Noise when turned on or off It is normal for standard computer CRT monitors to make a click, pop, crackle, hum, buzz, or other type of noises when they are first turned on or turned off.
Noise when monitor goes into standby mode When the monitor enters a "standby mode" or "power savings mode" this is similar to the monitor being turned off. It is completely normal for the monitor to make a noise when the monitor enters this mode.
Noise when opening Microsoft Windows or other operating system or when opening a game When a computer opens its operating system, for example, a computer opening Microsoft Windows or when a user runs a computer game it is very common that the monitor will need to switch its resolution of the operating system or game. When switching resolutions it is normal for the computer monitor to make some type of noise and/or for the computer monitor to flick or flash.
Noise during normal operation If the computer monitor click, pops, or flashes while it is being used this is not normal operation. It is very likely that the monitor may be failing or a component within the monitor has already failed and could also potentially be a fire hazard. We highly recommend that the monitor be repaired, replaced, and/or looked at by a qualified technician.
Additional information:
  • See document CH000302 for additional information and other noises that may come from
Jan 16, 2008 | HP Pavilion zd7000 zx5000 zv5000 presario...
Computers & Internet Logo
234 people viewed this question
David Payne
David Payne
