Question about Music
Lacking volume overall the volume control does increase and decrease the volume, but at the highest level it is still too quiet. Is there a way to fix or restore to original volume?
Yes, it's true that MM6 is lack of volume when on stage. I used a Sonic maximizer or Sonic Enhancer and I had plenty of volume on stage.
Posted on Nov 16, 2011
We used canned air to blow dust from the volume control slider connection. It did increase the volume, not quite to the original level, but to an acceptable level.
Posted on Dec 07, 2008
My Roland FP8 plays very quietly through its own speakers, through an external amp & speaker and through the earphones. There is a hissing/crackling/static sound too from the speakers. Anyone
A number if things can be wrong with it, from the audil preamp to the the audio amplifier. Even as simple as a bad volume control. Does the actual noise change patterns when you move the volume?
Jan 03, 2015 | Roland Music
Mpc 1000 loud static
Maybe try adjusting the MASTER level?
Good Luck
Other settings
Adjusting the master level You can adjust the level of the headphone and the stereo out by turning the MAIN VOLUME knob. The MAIN
VOLUME changes the analog signal level. This will also adjust the entire level of the MPC1000 digitally.
01. Press the [MODE] key and then the [PAD 10] (OTHER).
It switches to the OTHER mode.
02. Press the [F1] (GLOBAL) key.
The GLOBAL page will be displayed.
03. In the Master level field, set the level.
You will set the digital signal level, which will be sent out to the DA converter. The MPC1000 can output up to
32 sounds simultaneously. There is the great difference in the level when you play single sample and play 32
sounds. If you increase the value in the Mater level field, you can increase the entire level of the MPC1000 to
create more powerful sound with less noise. However, if you playback many sounds at the same time, the
level may be overloaded, which may cause distortion. If you decrease the value in the Master level field, you
can prevent distortion when you play many sounds at the same time. However, you cannot have a good
result in respect to the noise or punch of the sound. Set the appropriate value in the Master level field
depending on the application.
Mar 31, 2014 | Akai Mpc1000 Music Production Center
Right channel cuts out when I increase the volume
Blown or defective Headphone Amp IC or alternatively a defective Pot. Either way only AVID can fix it for you.
Outside parts and service is impossible.
Oct 03, 2012 | Digidesign *mbox2...
I have an Epiphone Les Paul Custom Silverburst, and it's pretty new and has worked great until now. It seems my bridge pickup lost tone and volume for some reason. My volume and tone knobs are cranked...
Need more info: 1- does the volume control still change the level? 2-Does tone control still change the tone? 3- What happens when in the center position on pickup select switch? Put pickup switch in center position (both pickups active). Then take a coin and tap on the pickups. Does bridge pickup sound lower? Lastly remove rear electronics cover and inspect all wiring for something loose or disconnected.
Aug 26, 2011 | Epiphone Les Paul Special II Guitar...
In a few words I can clarify that the gain controls are affecting the volume of the corresponding input, so that you can set the slider at the proper level. In other words you use the gain controls in order to increase or decrease the audio level of the input so that the differences at the audio level from the sources (different recording levels, different cd players etc) will be eliminated.
In case you'd like the full user manual you can follow this official link. Click on your model and at the new window make out your name and your e-mail at the form and you will get the user manual.
In case of a problem or clarification or further details needed, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
direct fixya link:
May 14, 2011 | Numark Industries Numark DM 1200 Mixer
The volume level from MY MM6 has suddenly dropped off. no idea why. Have checked all the cables and they are fine. Seems to be a decreased output from the board itself, but I don't know why. Help!
I have had this problem too. Often just turning it off and restarting the keyboard fixes the problem, however a year ago this easy fix did not work and so I opened the machine up. I had to remove a few screws and turn the circuit board over. Sure enough, near one of the output jacks there was a solder joint that looked darker than all the other. I uses a solder gun to reheat the solder joint and all worked well again for another year, at which time I had to do it again. I wonder if others have been having this problem.
Jan 29, 2011 | Yamaha MM6 61Key Synthesizer Keyboard
Low Volume using Kaoss Pad Mini while DJing
I'm having the problem too...I'm thinking that maybe getting the DC adapter MAY fix it though as stated in the Manual: "...The output level of the mini-KP will be smaller than its input level. This is because the attenuator circuit is connected at the input section, considering that the mini-KP is used on battery power." so maybe the dc connector will increase output volume?
Aug 22, 2009 | Korg Mini Kp Kaoss Pad
Amp goes quiet after working fine for about 15-20 min.
If you are not a tech, I suggest you send it to one. If you are, after signal-dropout spray output transistors (one at a time) with component cooler (freeze spray). If still no results, go to the other transistors & IC's. Chances are that will pinpoint faulty component.
Apr 05, 2009 | Line 6 Spider Iii 120 Stereo Guitar Combo...
Music Logo
401 people viewed this question
Top Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
