Will not print error and toner lights flashing no manual we have had this only a month and have not printed nearly 1000 copies. more like 300 at the very most. do we need a new toner??
    Sergeant:
  • 236 Answers
If the toner lights are flashing then it is out of toner. Replace and see if that fixes your problem.
Posted on Dec 05, 2008
What does error n9 indicate?
You may call on 877-372-5594 (Toll Free) for help.
Dec 03, 2015 | Xerox WorkCentre 5020 Laser Multifunction...
Help! My machine won't copy or print
check the old cartridge was empty or it was just showing wrong indication.( flashing ).
Aug 29, 2008 | Sharp AL-1540CS All-In-One Laser Printer
Red light blinking not printing
Based on your error, the manual says that your toner is low or empty.
Thanks aid
Dec 12, 2009 | Samsung ML-2510 Laser Printer
Smasung clp 300 will not print in blk
check if your toner cartridge(s) is moving the toner supply spiral,
you can see it in hole where toner leaving bottle. (you must push the
valve in cylindrical output of cartridge inside about 20mm).
When you rotate anti-clockwise gear of cartridge, the spiral inside must rotate too.
My original toner has this broken and print was light.
You can have also bad developer unit, blade, or contacts, or printer electronic board.
Mar 07, 2009 | Samsung CLP 300 Laser Printer
Magicolor 2400W error
This happens to me every few months, I have to do a VERY detailed cleaning of all toner sensors. The knowledgebase on KM's website is actually very good about walking you through which sensors to clean and pictures indicating where they are located. This has fixed me up every time. GOOD LUCK!
Jan 19, 2009 | Konica Minolta Magicolor 2530 DL Laser...
Stopped printing
The printer will stop with an audible "clunk", and the symptoms above if the used toner container is full.
Sep 06, 2008 | Samsung CLP 300 Laser Printer
Dell printer 1700
First unplug power cord and plug back after 10 mins.
If problem persists, then it is probably a toner error, if the toner is nearly finished. In this case you will see the led flashing only when is printing. Sooner or later the printer will start printing blank or faded pages and you will need to change toner
When is not toner, with same symptoms as above, it can be drum error, in this case printer will keep printing but shows flashing light, at a certain point you will need to change drum kit.
If light flashes and printer does not print, then it is either paper jam inside, or one of errors above at final stage, or one of the door not well closed (check them all), or printer faulty (fuser, heads mechanics etc.), in this last case call service.
Mar 21, 2008 | Dell 1700n Laser Printer
Print problem
Have you tried replacing the ink cartridge?
May 01, 2007 | Minolta magicolor 2200 DeskLaser Printer
The red attention indicator light and the toner indicator light are both flashing together
ON your driver check that the paper size is correct and this most commonly occurs when the incorrect paper size is selected. For example if you are printing to A4 and you have letter size installed in the machine then the system will cause an error or jam when there is nothing there.
Also within word or which ever program you are using on the document goto file and then down to page setup once in there check the paper size make sure it's correct for the paper in your machine also check the paper source. Once you have done this check the paper tray guides are correctly against the paper turn on and try printing and hopefully this will work.
Thanks J
Oct 27, 2006 | Kyocera Mita FS 1000 Plus Laser Printer
191 people viewed this question
jasbo
jasbo
