Question about Sony Dvcam DSR-PD170 DV Digital Camcorder
I have a SONY DSR PD170T the rubber eye cup and the diopter to which the eye cup is attached snapped out and got lost. I am trying to find and order a replacement? What do they call it? part#? thank you
  • 10,594 Answers
You should order Eye Piece rubber under following part number...
" X-3953-896-1" CABINET ASSY, VF (REAR)
Here is exploded view of required part...
Above said part is available in Part Store on $110
Need further info, let me know please.
Thank you.
Posted on Dec 05, 2008
Trying to rewind a tape in a Sony DSR 300 and I am getting a SLACK error.Why is this so?
as the reels are rubber belt driven, it is possible that a belt has broken
May 06, 2015 | Sony Dvcam DSR-300 Camcorder
My view finder on my sony dslr A100 wont show what i am looking at though the view finder
The A100 uses sensors near where you place your eye. Make sure the rubber eye cup is clean, and does not block these sensors.
as a test put your finger on them while holding camera away from face ( located just below eye cup) then you will see the view finder light up. If not problem is the sensors.
Jul 29, 2014 | Sony Alpha DSLR-A100 Digital Camera
How to hold binoculars properly
1. Remove the lens covers, if they are in place.
2. Set the diopter on the right barrel eyepiece. The function of this setting is to adjust between vision differences between your eyes if you are NOT wearing corrective lenses. Set to zero if you do have corrective lenses on (glasses or contacts). For proper diopter adjustment see this article: Binocular Selection Guide.
3. Most binoculars will hinge in the middle to allow for differences in the spacing between the eyes. Set the spacing to fit your eyes.
4. Adjust eye cups. Each eyepiece will have a means of maintaining the correct eye relief for the user. On quality binoculars the rim of the eyepiece will extend and retract as you twist the eyepiece rim. Move all the way in if you are wearing eyeglasses or adjust out if not wearing eyeglasses. You will know if they are set correctly when you look through the binoculars and check to be sure that the circular edge of the view should be sharp and not fuzzy. At this point we are not looking at any object in the view but rather the perimeter of the view. You may need to adjust the eye cups again to compensate. On lower cost binoculars the eyecup may only be a rubber lip that you either fold over (the "in" position) or out.
5 Raise binoculars to your eyes and use one finger to adjust the focus wheel on the center shaft between the two barrels, until the view is in sharp focus. If viewing for extended periods you may want to keep your elbows down near your side as this will increase comfort while viewing.
Final safety tip: Do not look at the sun through binoculars.
Many people enjoy observing nature with binoculars. Having them handy is key. Hunting, astronomy, marine use, and stadium sports are a few more activities where having a pair of binoculars can make a real impact to your experience.
Mar 06, 2014 | Zeiss Optics
VIEW SCREEN IS SO BLURRY I CAN'T TELL WHAT ITS SHOWING.
Is it the viewfinder (that you hold up to your eye) or the screen that's blurry?
If the viewfinder is blurry, there should be a diopter adjustment to fix it, probably right above the rubber eye cup.
If the screen is blurry, you should take some pictures and video and view them on a computer. I they are sharp on the computer but blurry on the camera screen, there may be a problem with the screen and you may need to take it in for repair.
If the pictures are blurry on the computer as well, the camera may not be focusing properly. If you can't focus manually, or the camera can't focus when auto focus is turned on, you have good light, and aren't too close to your subject, then it may need to be serviced.
Feb 26, 2011 | Sony Cyber-Shot DSC-F717 Digital Camera
The diopter setting eyepiece has come out of the body of my Bushnell 10X42 ''Waterproof'' binoculars, model 13-2410. I see keyways inside, but cannot screw it back in more than about 1/4 turn, which is...
The entire diopter setting eyepiece was off.I separated the eye cup from the rest of the diopter setting eyepiece, and aligned the channel guides on the lens piece to slide it into place. Then holding it in place, taking care not to gum up the lens, I experimented with how to screw in the retainer ring so that its white dot registered correctly. Finally reattach the eye cup and focus. It's like new!
Apr 10, 2010 | Bushnell Waterproof Binoculars
Our sony dsr 45 is giving us a C:31:41 Error code shortly after tape is inserted.
error cause by drum head, u can try fix by ur self, open the compart then open the black drumhead cap,u can see to screw on the upper head open,then u can see rubber pick it up clean the rubber and the con inside outside head, try again if doesn't work u can change the drum head
Nov 30, 2009 | Sony DSR-45 Mini DV VCR
I LIKE A VIEWFINDER COMPLETE HOW CAN BUY?
There is no single part number for the entire viewfinder per se. What is the problem so I can get you the list of parts you will need?
Thanks,
Dan
Oct 01, 2009 | Sony Dvcam DSR-PD170 DV Digital Camcorder
Lost Nikon Travelite ex eye piece
I'm supposing by eyepiece you mean the rubber or plastic eyecup. The eyepiece is the whole unit that contains the lens. Nikon has a service center in many countries. If you have one in your country then they can order the part. I have ordered from Nikon. They find the part number if you tell them your model and can email you an order form. Alternately Binoculars.com is very good to deal with as is Adorama Camera in New York. Both will sell internationally.
Jul 13, 2009 | Nikon Travelite V Binoculars
Sony Dvcam DSR-PD170 DV Digital Camcorder Logo
397 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
