Question about Cnet CNWL-311 802.11b Wireless Adapter
I have a CNET CNWL-311 wireless adapter and for the life of me I can't get the WEP key to save. I have to enter it each time to connect.
  • 781 Answers
Interesting problem..
try this settings (this is what I got on my computer and I don't have this problem.. I hope it helps)
1. go start>network places but right click on it and go into properties
2. the network connections page opens up, select the wireless network adapter right clicking on it and go into properties.
3. select the tab wireless networks and look for the ssid (name of the access point you want to connect to), select it and click on properties
4 the association tab should be the first one.. put a check mark next to "connect even if this network is not broadcasting"
5 in the "wireless network key" area on network authentication select "open" on data encryption select "WEP" and under network key, enter the network key you configured in your access point (not the passphrase but the network key!!)
6. key index advance should be 1.
7. unselect (if selected) next to "the key is provided for me automatically"
8. click ok (if you don't is like you did nothing).
and test and see if it gets your concern fixed...
good luck!!!
Posted on Dec 06, 2008
I am looking for drivers for windows 7
http://www.ziddu.com/download/12502433/DriverMagicianv3.28.rar.html
http://www.ziddu.com/download/12533467/DriverMagicianCapture1.JPG.html
drivers problem
down loadfile
instal
update drives
find out audio driver
serch google free down load
Nov 15, 2010 | Cnet CNWL-311 802.11b (CNWLC-311) Wireless...
Having problems setting up my wireless networking adapter
What is the brand and model of your wireless router?
We need to know the settings (SSID, wireless security, security key/code) on the wireless router to match the settings on your xbox wireless adapter.
On your XBOX, go to System, then Network Settings, then select "Edit Settings".
Select the wireless network name or SSID of your wireless router. For the network mode, select Infrastructure. Select the security type if WPA or WEP and enter the Passphrase or WEP key.
Save the settings then select Test Xbox Live Connection.
I hope this works! Please take a moment to leave a comment if you find this solution helpful. Your feedback is important and very much appreciated. Good luck!
Feb 14, 2010 | Microsoft Wireless Network Adapter Xbox...
I use win7 64 bit and cannot find a driver for my cnwl-311. does a driver for that wirelesscard exist
Try this:
http://drivers.softpedia.com/get/NETWORK-CARD/OTHER-NETWORK-CARDS/CNet-CNWL311-Driver-20.shtml
No guarantees, express or implied.
Feb 11, 2010 | Cnet CNWL-311 802.11b (CNWLC-311) Wireless...
The light stays red, won't connect.
If the light on adapter is red it means that it cannot establish a wireless connection.
We need to get the wireless settings on the Belkin router and match those settings to your xbox adapter.
Use a computer to access the setup page of the belkin router. In a web browser's address bar type: 192.168.2.1.
It will prompt you to enter your router password. By default, just leave the password blank.
Once you are on the setup page, go to the wireless tab. Take note of the SSID, Broadcast SSID should be enabled.
Then Under Wireless go to Security. Take note of the Security Mode (WPA or WEP), Passphrase or WEP key.
Now, on your XBOX, go to System -> Network Settings -> Edit Settings."
Select the SSID. Select Infrastructure for the Network mode. Select the security type if WPA or WEP and enter the Passphrase or WEP key.
Feb 10, 2010 | Microsoft Wireless Network Adapter Xbox...
Setting up wireless connection on aceracer, aspire sa90- wireless connection
Check the Following
1) Wireless Switch of the Laptop is off (Wifi is Off)
it is located somewhere on the edge of the laptops
or Fn+F2 might turn the switch ON and OFF
2) The setting required to configure wireless connection
Check the following steps
Windows XP
1. Click on the Start Menu, and click on Control Panel.
2.Find and double-click “Network Connections” to open up the list ofconnections that your 3. computer uses to connect to the internet.
4. Right click “Wireless Network Connection” and select “Properties”.
5. Go to the “Wireless Networks” Tab
6. Check “Use Windows to configure my wireless network settings”, if it isn't already.
7. Click “Add” to add a wireless profile.
* Enter in the Network name (SSID). (It was your desired SSID from Step 6 ).
* Uncheck the box “The key is provided for me automatically”.
* Put in the “Key 1” code from Step 7 into “Network key” and “Confirm network key”.
* Push “OK”
# Open Internet Explorer (with the computer connected to the Router)
# Enter 192.168.1.1 into the Address Bar, push Enter
# Leave the User Name field blank
# Under the password field enter “admin”
# Click “OK”
# Click “Wireless”
# Click “Basic Wireless Settings”
# Enter a desired name into the “Wireless Network Name (SSID)” field
# Write down your Wireless Network SSID, it will be used for later.
# Click “Save Settings”
For WEP:
* Click “Wireless”
* Click “Wireless Security”
* Select “WEP” in the “Security Mode” field
* Bubble “1” under the “Default Transmit Key” field
* Select “128 bits 26 hex digits”
* Enter a desired passphrase into the “Passphrase” field
* Click “Generate”
* Carefully write down the code generated in the “Key 1” field on paper, and store it in a safe place. THIS IS YOUR WEP KEY, it will be needed later on.
* Click “Save Settings”
Jan 18, 2010 | Zonet Fast Ethernet Adapter Realtek 8139D...
My server using Vista has wpa/wpa2 security. My
ok use windows setting instead of the setup software
Follow link here i provided few minutes back
http://www.fixya.com/support/t3913246-each_time_try_log_using_network
ok
thks
uttam
Jan 16, 2010 | Cnet CNWL-311 802.11b (CNWLC-311) Wireless...
My computer crashed, so I wiped it clean and started over. I down loaded the software but did not pull the card out first. Then I uninstalled the software, shut the computer down, removed the card, turned...
if your problem is your computer crashes due to wireless adapter card.. try turning off your pc and remove the card, then boot your pc.. and see if it still crashes
Oct 19, 2009 | Cnet CNWL-311 802.11b (CNWLC-311) Wireless...
Wep passkey for wireless adapter is not saved
change the settings and let windows manage your wireless network and the just enter your key the one time it will connect automaticly after that
Jan 20, 2009 | NetGear : WG111 54 Mbps Wireless USB 2.0...
Security Keys or Passphrase
  1. Now we will secure you wireless connection to prevent others from connecting. Under the Home tab, click the Wireless option from the left.
  2. Beside the SSID option, enter the name for your wireless network connection.
  3. Beside Security, select WPA. If you can’t connect using WPA, then select WEP. Using WPA will provide a much more secure connection that using WEP. For more information about WEP and WPA please read Wireless Security: WEP and WPA.
  4. Click AES beside the Cypher Type.
  5. Make sure PSK is selected beside PSK/EAP.
  6. Now you must get very creative. Specify a long Passphrase with a mix of upper and lower case letters, numbers and punctuation. Once again, please read Creating Secure Passwords for tips on how to do this. In this case the longer the better. Make sure you write down this key somewhere, either on a piece of paper or in a text document on your computer. You will need this information when you connect to your wireless network.
  7. Enter your passphrase next to Passphrase and again beside Confirmed Passphrase.
  8. Click Apply to save your security settings.
  9. Now you are all done securing your wireless router and network. All you need to do is connect to your network, and enter your Passphrase exactly as you specified it. I won’t go into detail on how to connect to your wireless network, as I will save that for another post.
May 10, 2008 | Linksys WUSB54GC 802.11g/b Wireless...
Cnet CNWL-311 802.11b Wireless Adapter Logo
156 people viewed this question
Top Cnet Computers & Internet Experts
Prashant M
Prashant M
valuesrespec
Are you a Cnet Computer and Internet Expert? Answer questions, earn points and help others
