SOURCE: No heat coming from Amana Dryer
2 screws at the bottom of front panel if no screws there, then pry top off with wide flat screw driver then look inside toward top of front panel remove two more screws and the front should lift right out then remove screw/s in center of drum and lift out of cabinet there should be your heat element
SOURCE: replace electric heat element in Amana dryer
You can find an exploded view of the dryer on searspartsdirect.com. Looks like you access from the rear service panel.
