Question about Acer X193W LCD Monitor
Unable to set right dpi for my monitor - Acer 193W
I just got a new computer which runs on the newest version of Windows XP. I also bought a Acer X193W LCD monitor because it came highly recommanded. The problem I am having is that I was told to get best results my dpi should be set to 1440x900, but my computer does not have that resolution, so all words on the monitor are stretched. Are the two not compatable or is there a solution to my problem? I am at work so I am not writing from the computer with the issue.
3 Suggested Answers
rjwharris
  • 102 Answers
SOURCE: words are stretched - computer runs on Windows XP
The resolution issue you are describing sounds like a video card driver issue. You must determine what video card or chipset you have and apply the appropriate driver. The Acer x193w monitor is plug and play, it will display whatever the OS sends to it provided it is within its display range and 1440x900 is definitely within that range.
Posted on Dec 20, 2008
kitsuneki
  • 7 Answers
SOURCE: Acer's x193w killing my eyes..please help
First off, LCD monitors have what is called a 'native resolution' and that is why it is recommended to be at 1440 x 900. That is the resolution they work best at. My first suggestion is to try to move the monitor closer to you. If that is not possible, try right-clicking on your desktop, click on the Properties tab (That is where you change the resolution. I am doing this for a Windows XP machine - if you are running Vista please let me know and I will try to walk you through it there). Click on the "Advanced" button and in the "General" tab, there should be a "DPI Setting" drop down box. There is usually 96 DPI and 120 DPI. Try 120 DPI and see if that helps.
Second, try using your monitor's menu settings to help the color settings. On your monitor there is a "Menu" button of some sort. Press that and select "Acer eColor Management" and try "Text Mode" to see if that is easier on your eyes. You can also manually adjust the screen and lower the strength of the red color by picking "User" instead of "Acer eColor Management" and selecting the icon that looks like a pyramid of 3 dots. Try adjusting the Red slider and see if that helps.
Posted on Jan 02, 2009
My operating system is XP. the driver for this
To the best of my knowledge this is a pnp device witch stands for plug and play you should not have to download any drivers but you should only have to go in to your properties and adjust the settings
Right click on the desktop and go to properties then in the next window click on settings adjust them to this
Maximum Resolution & Refresh Rate
  • 1440 x 900 @ 75Hz AND in 32bit color
that should salvo your problem :)
Apr 22, 2010 | Acer X193W LCD Monitor
New netbook unable to see whole screen
I was having that problem as well on my msi wind netbook. Turned out that the default DPI setting was on large. After changing it to normal it fixed it. This is what I did, perhaps it will work for you. Good luck.
  1. Right-click somewhere on your desktop (not on an icon) and select properties.
  2. Click on the Setting tab and once there click advanced.
  3. You will see DPI setting, change that to Normal size (96 DPI) and then click apply
  4. Now restart your computer for the changes to fully take effect.
Oct 20, 2009 | Acer Professional P211 21" CRT Monitor
Tried to update drivers for acer arcde deluxe, system crashed and now the arcade won't start at all. Unable to update again.
Do a windows system restore to a day before you installed the new software, and if this fixes it, leave the acer arcade alone. If you must upgrade acer arcade, check the acer website and be sure you get the correct version for your version of windows: ie xp/vista and 32bit/64bit.
you can check your windows version this way: right-click 'my computer' in xp 'computer' in vista and left click properties. this will tell you your windows version, and whether it is 32 or 64 bit. If this fails again, do another system restore, and contact acer for support. My best advice is to leave it alone if you get the pc functioning properly though. please contact me if you need any further help.
Jul 19, 2009 | Acer Aspire 5720-6661 Notebook PC
Changed dpi setting
when was the last time it worked?...Right-click anywhere on the desktop, select properties, settings, display and make sure you have selected the correct monitor display. are you running xp?.
let me know
Apr 09, 2009 | Acer Aspire 5920-6727 Notebook
'input not supported'
First install another monitor so Windows will load.
Then right click on "My Computer" and select "Properties", then click on the "Hardware" tab and click on "Device Manager" button. In the list and click on the "+" sign next to "Monitors" then right click on the monitor in question and select "Uninstall", then click "OK" and close all windows and "Shut Down" your PC. Install the monitor in question again and start your PC and wait 10 minutes or so and XP will set up the monitor like it's the first time you installed it.
I hope I understood your issue and Good Luck.
Apr 08, 2009 | Acer Aspire 3680 Laptop
Native resolution suddenly scrolls.
The native resolution for the Acer AL2216W is 1600X1200. It is acting correctly for the resolution you have set it to.
Apr 05, 2009 | Acer AL2216W LCD Monitor
Jan 02, 2009 | Acer X193W LCD Monitor
How do set up 20 inch monitor to xp
I just recently purchased this monitor, my computer is running windows xp home and i didn't have any trouble hooking it up it is just plug and play
Dec 28, 2007 | Acer AL2016W 20" LCD Monitor
Resolution
You could check your DPI setting in the display, being a large monitor your DPI setting shoul be up around the 75 - 85 Hertz.
To access this
Control Panel --> Display --> Settings --> Advanced --> Monitor and then click the drop down box and see what the DPI is set to and keep trying the different options until it is clear.
Hope this helps.
Dec 04, 2007 | Gateway GT4010 (RBGT4010) PC Desktop
Acer monitor
you have to change the monitor setting in the display box in windows properties right click to get in windows desktop/settings/display resolution
Nov 24, 2007 | Acer AL2016W 20" LCD Monitor
Acer X193W LCD Monitor Logo
140 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
