That you can go on internet without paying and without having a wi-fi connection ?
SOURCE: I cannot make a wi-fi connection
are you that ******* stupid that you think that blackberrys have wifi you ignorant lowlife ***** you cheap ***** blackberrys do not have wi fi you better go to a low quality iphone with that **** you have been dismissed wiht your stale ***
SOURCE: failure of wi fi connection
Go to manage connections and check wi fi is turned on and scan for the available network.and connect to your net work.(also make sure your wireless router is working fine)
SOURCE: can't use wi-fi without data plan? on blackberry
you can surf the net on a wifi network even of you dont have a data plan. turn the wifi on then select "set up wifi network" then just follow the instructions to be able to connect to the network. if you still can't after doing this, it might be because the signal of the network is not that strong.
regarding the bluetooth, go to media, then press the menu button (the bb logo), then select "receive via bluetooth" for your bb to receive the file from your laptop/other phones.
