Question about Canon PC-1060 Black and White Copier
Canon pc 1060 copier-some words from top are printed in middle
Canon pc 1060 copier- some of the words on top of the paper are printed in the middle of the paper, faintly.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 191 Answers
Remove your drum unit & change your cleaning blade
Posted on Dec 06, 2008
My Canon PC 1060 makes copies with a double-image of the original, about one-half inch apart, so they are very smudgy and bleary. Also, the ADF does not work; I wonder if that is related? Any advice?
You a get a technichian to look at your machine simply becouse you might not know where the problem is even if I instruct you, however note this:-
The problem is with the fixing unit, the fuser membrane is one at faulty no wonder double images therefore change the fuser membrane the problem is gone. the fixing unit is where the copy paper pass and the pressure roller together with the membrane enables the image to be permanent on paper, sometimes you just need to clean the rollers using silicon oil i.e. the pressure roller and the membrane.
Jul 31, 2011 | Canon PC-1060 Black and White Copier
The copier says rec paper jam slide left platen? what do i do ?
On the slide there is a handle. This releases the top reader port of the copier, move it to the left. Raise right side cover and remove the drum cartridge unit. You should see the jammed paper there, at the right lower access door, or in the fuser where the paper should come out. Just reverse the procedure to reset the jam. If the copier still indicates the jam then it must be in the fuser. You will have to have a technician remove the fuser assembly from the copier and take apart the unit to remove the jam. Hope this helps.
Jun 12, 2011 | Canon PC-1060 Black and White Copier
I just replaced the black and cyan ink in my i960 printer -- now nothing prints at all -- blank pages. I checked to make sure all of the packaging was off the cartridges
Run the Canon printer-software to launch a "print-head-cleaning" task,
because you may have "clogged" ink-jets, so that no ink can be sprayed onto the paper.
Test to see if FIXYA "censors" some words:
Start with the word CALM ( calm ) and swap the middle letters: **** ( **** ),
as in the ****-shell model of Apple portable computer,
or a cell-phone that opens like a ****-shell.
Do you see <star><star><star><star> instead of the word?
How about STUCK ( stuck ) and omit the 'T' to become: **** ( **** ),
as in "the printer sucks ink from the ink-tanks and jets the ink onto the paper".
Dec 06, 2010 | Canon I960 InkJet Photo Printer
Paper jam Cannon PC 1060
hello,remove all covers arond the exit area lift cart door, control panel screw ,slide left,remove glass.holes in top under glass and under control panel,slide top to left,look down into holes to see screws holding fuser in.three connectors slide out exit side ,carefully dissasemble fuser to remove jam.i replace at least one unit a week.do use sharp objects
Nov 03, 2009 | Canon imageCLASS D761 Copier
Canon PC 1060 will not SCAN
Cleaning the rubber rollers on the ADF may help it to pull the paper through; I did it on my 1060 and I think it helped. (This was suggested in another post some time ago.)
Press Additional Functions. Use arrow keys to find ADJUST/CLEAN; press SET. Use arrow keys to find CLEAN ADF ROLLER. Open the ADF. Press SET. Each time you press SET, the rollers will rotate a partial turn. With the corner of a soft cloth slightly moistened with isopropyl (rubbing) alcohol, wipe the black rubber rollers both on the bottom and top of the ADF. Push SET again and rub again, several times. (DO NOT use alcohol on the long white roller! Use a dry cloth only, if you want to clean it.) Push STOP/RESET when you're done.
Touch the rollers only after they stop--not while they are rotating!
No guarantees, but it may be worth a try.
Jan 18, 2009 | Canon PC-1060 Black and White Copier
Canon PC 1060 has a paper jam that we can't get to
It sounds like the paper jam is in the fixing assembly, and you can not access it unless you take it to a service center for canon products.
Nov 10, 2008 | Canon imageRUNNER 5570 Copier
Users Manual
the ADF is the automatic document feeder the part on top of the machine that you insert the paper to Automatically feed the paper in one at a time, there may already be a document on the glass lift the top and put it back down it should clear
Jul 31, 2008 | Canon PC-1060 Black and White Copier
Canon PC-1060 Black and White Copier Logo
110 people viewed this question
old marine
old marine
