Question about Maxtor Hard Drive
How do i make a maxtor hard drive to be a secondary hard drive for my pc
    Sergeant:
  • 236 Answers
Short answer - make your current hard drive a master and your maxtor a slave by setting jumpers.
Here is a tutorial on this
Posted on Dec 05, 2008
Why my maxtor hard disk showing SMART Failure?The maxtor is my secondary hard disk drive...
Hello
The smart control inside the hard drives is to let you know that a drive is about to fail. If you restart your computer and bring up the BIOS you should be able to shut off the SMART warnings. That wont fix your drive, but at least you wont be bothered ...
I would copy the info off that drive asap and save it. SMART is not always right, but its right most of the time and problems will come.
Best of LUCK
Nov 27, 2010 | Maxtor Hard Drive
I want to hook up a 250gb maxtor hard drive as a secondary drive on a dell dim 8400 computer. I have it plugged in to the board and two cables attached. Need to know what jumper settings I need to put on...
on the hard drive you originally had installed you should have your pins settings to master and on the second drive you installed you should have it set to slave. I am assuming you know how to install it as a secondary drive so your system sees it if it still dose not work with the proper drive settings pleas post again with all your settings and OS specks and we will get back to you as soon as possible with a solution.
I hope this helped.
Thank you
Norse
May 19, 2010 | Maxtor Hard Drive
Computer will not recognise external hard drive
Here are a few things to try. If you have access to a secondary PC or laptop, try connecting your drive to it using a different USB cable. Also try unplugging your drive from the power outlet for a few seconds and then connecting it again. If it?s still not being recognized, Maxtor has a free utility called PowerMax (available at www.maxtor.com) that lets you run various tests on your drive till it identifies the problem.
Apr 07, 2010 | Iomega 1TB Desktop USB 2.0 Hard Drive
How do I set the jumpers on my Maxtor DiamondPlus 9 80 GB SATA /150 HHD drive as a second drive.
SATA drives are jumperless -- each drive has its own cable to the motherboard or controller -- so there's no setting on the drive to say "primary" or "secondary" as there was with IDE.
The connection on the controller or the motherboard will determine which drives are primary and which are secondary.
Jan 06, 2010 | Maxtor Hard Drive
I need to set jumpers on hard drive Maxtor Maxline plus II y653z5le as a secondary drive. How do i do that?
on the drive there should be a diagram for how to set the jumper settings. you want to set it to slave.
Jun 13, 2009 | Maxtor MaXLine Plus II 250 GB Hard Drive
How to detect the hardrive?
setup the first drive as slave ( sometimes No Jumper ) then the furthest away drive as Master.
If this fails, and you have 2 IDE Slots on the motherboard. ( Primary/Secondary ) Put 1 drive on primary as Slave. And DVD Rom As Master ( same Cable ) Then put second drive On Secondary IDE Slot. ( Set As Master Or Slave )
If none of these solutions Work For you, check to see if Both Channels are activated in the Bios.
Thankyou For Using Fixya.
Mike @ compurepair.
Jan 28, 2009 | Maxtor Hard Drive
How can I detect maxtor 3200 ide as slave
Somewhere on the harddisk, you should be able to see a label indicating jumper settings. Check that the jumbers are set to slave sattings.
Dec 17, 2008 | Maxtor DiamondMax D540X 100 GB ATA-133...
I bougth a maxtor hardrive is this same connection with western brand hard drive
If your talking about the number of pins and the power plug, yes! Don't forget to set the device order the same as your old one,master primary master slave/ secondary master/ secondary slave.
Oct 27, 2008 | Computers & Internet
Maxtor external hard drive is not accessable
- Do you hear any beep sound when you plug in the USB drive into the laptop? - You can also try a different USB cable - Try connecting the hard drive to a different computer and see if it works All those steps will help you determine where the issue is. Please revert back with any other observations. Good Luck
Mar 30, 2007 | Maxtor (H01R300) 300 GB Hard Drive
Maxtor Hard Drive Logo
94 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
