Question about Nokia 6260 Handheld
Blank screen My phone sreen had a problem of being too bright even if I try to to adjust brightness. Now finally it is completely blank, but I can still make and receive calls without seeing anything on display. I am not sure wether it is software problem or a sreen.
I have the same problem with my nokia 6260.. what i did was, at first getting the fone "power on" and "power off" repeatedly while charging makes the screen back to normal. b4 it would only take me 3x "on and off" but now i cant count how many until it turns normal again. or if it doesn't work try to open (disassemble) your fone n make sure it does not have any moisture on it, check the connectors if properly connected worst... you must change yor LCD. try it n i hope this post helps..
Posted on Dec 07, 2007
When trying to take pictures outside the screen goes blank.
Try to manually make it so that it is set to outdoor settings. Or maybe try low brightness and no flash.
May 12, 2008 | Olympus FE-190 Digital Camera
Blank screen
they do have updates to your model but how old is it cuse i way does a great job replaceing parts for free
Jan 26, 2008 | Lowrance Iway 500c GPS Receiver
Acer 4320 Screen turn blank when it load Windows.
press fn button and with up-arrow increase brightness ,,, in windows open display settings by right clicking on the desktop (intel or nvidia properties ) acer 4320 could have nvidia or intel ... increase the brightness and the contrast or load the default settings ,,, use external monitor if need ...
Mar 07, 2012 | Acer TravelMate 4320 Notebook
I have a compaq paserio notebook and when I boot up the computer, either I get a blank screen or I get a very faded image that I can't hardly see so I can't log on. Most of the time I just get a blank...
Have you checked the brightness options for the screen using the HP function keys? Fn +F7 or Fn+F8 should adjust the brightness of the screen for that C306 model laptop. If adjusting the brightness has no response then try the next steps.
What happens if you turn the computer off, plug it into an external monitor or projector, and then turn the computer back on? If the video displays correctly on a computer monitor or projector, but it stays dim on the LCD screen of the laptop, then the laptop LCD Screen Back-light or inverter is probably going out. You'll need to contact HP for a replacement part or take the laptop to a certified repair center.
Nov 05, 2010 | HP Compaq Presario C306US Notebook
Fujitsu siemens esprimo mobile v5535 has blank screen. displays on projector but not on lcd. run through Fn + F10 but remains blank. have tried brightness keys as well. Any ideas?
This answer is probably too late for you but may help others. Just to the left of the right hinge of the laptop is a small plastic lug which presses on a switch when the laptop is closed. That switch switches off the back light of the screen. Dirt can accumulate in the switch so it is permanently stuck in the off position. Clean it out carefully with a toothpick, small brush and finally vacuum it. Once clear of debris, squirt a bit of contact cleaner in (NOT WD40). You can also check to see if the LCD part of the screen is 'dead' by shining a bright torch at it once boot up has completed. You should be able to make out the normal 'enter password / logon' screen (front / side lit instead of backlit). If nothing can be seen the LCD is dead, so we're into new screen territory.
Jun 25, 2009 | Computers & Internet
Sreen has gone blank
This happened to me when I dropped my phone in the sink. I took it all apart and laid all the parts out to dry for 2 hours. It works fine now. You can also try doing a hard reset. Keep the phone turned on and take the battery out. Wait 30 secs before replacing the battery. If that doesn't help, try calling your service provider.
May 22, 2009 | AT&T CECT Unlocked i68+ Quadband GSM FM...
Brightness/Contrast Adjustment
try going to the setup screen button left of adjustments
try going to the set up menu on the left of the buttons come down to the slider control just above the information icon then go across to color reset hope this helps regards Jim
Mar 12, 2009 | Samsung SyncMaster 2253BW LCD Monitor
Display problem!!
Hi there polarized.
All you need to do is this.
1. Switch your mobile phone off then switch it on again.
2. Click the MENU button which is the top left keypad (the silver colored one)
3.Scroll down once, then to the right once.
4. Click the MENU button again.
5. Scroll down twice. Click MENU button.
6.Scroll down once or twice and click MENU button again.
This should either reset your theme to the default themes.
Nov 09, 2008 | Sony Ericsson T280i Mobile Phone Silver on...
I can't get my HP pavilion laptop to work. The actual system is working, but the screen is completely blank...please help.
hi
try adjust brightness and contrast if doesn`t help try connect to external monitor.
if you require more help let me know ;
regards
Oct 14, 2008 | HP Computers & Internet
Nokia 6260 Handheld Logo
106 people viewed this question
Top Nokia Computers & Internet Experts
Computer Links
Gopi Venkatesan
Gopi Venkatesan
Are you a Nokia Computer and Internet Expert? Answer questions, earn points and help others
