I have tried to start in safe mode but it won't do that even. Where do I find the cmos battery and how does it come out? I have looked in every cavity on my laptop but may have just overlooked it not knowing what it looks like. Thank you for any help you can give me.
The cmos battery on the M700 is situated under the cover for the modem, and has a short cable attached with a connector on the end. Turn the machine upside-down, locate the small rectangular cover, remove the fixing screw, unplug the cable and pull out the battery.
Posted on Jan 21, 2008
It could be under the keyboard or under the hard disc drive, there may be peice if tape over it to secure it. it looks like a large flat 3v watch battery.
Posted on Feb 12, 2007
Jan 16, 2013 | HP Computers & Internet
Jul 03, 2012 | HP OmniBook XE3 Notebook
May 29, 2012 | HP Mini 110-1037NR Netbook
When you boot up to the log in screen type in administrator as user to log in if you cant log in
during the boot up process you will see on the screen for a short amount of time press a certain key to enter set up press and hold that key during the boot up process to enter BIOS using the arrow keys scroll down to set user password or supervisor password you can change or remove your password from there
The most common way that we know on how to reset or clear the BIOS password is to physically remove the power from the computer by disconnecting the power plug and then removing the Cmos battery for 30 minutes from the motherboard.
Another way is to reset the clear CMOS jumper on the motherboard itself.
Both of the 2 methods mentioned works because most motherboards use a battery to sustain the BIOS/CMOS settings for the motherboards PROM chip. So by cutting off cmos the battery power, the BIOS/CMOS settings will be erased.
cmos battery Under the keyboard or bottom of laptop - If you are working on a laptop computer the location of the dipswitch (almost never a jumper) can be under the keyboard or on the bottom of the laptop in a compartment such as the memory compartment. Although on some motherboards the Cmos battery is soldered in
Often many users will leave the administrator account alone or have other accounts with administrator rights. If you're not logging into the computer as administrator or have other accounts follow the below steps to reset your other accounts password.
Reboot the computer into Safe Mode
During the boot process tap the f8 button three times this will boot into safe mode where the only things working will be your mouse and keyboard enabling you to attempt to repair your computer Advanced Boot Options screen appears.
Select the Safe Mode option using the up and down arrow keys, then press the ENTER key. Choose "Windows XP Home/Professional", depending on the version of the operating system.
Press ENTER. Shortly, the welcome screen should show.
Log in as "Administrator". Click Yes to not use System Restore Mode.
Click the Start button. Choose Run and type in "control user passwords" (without the quotes). Click OK.
Select the "Administrator" user. Click Change my password. Enter a new password in the corresponding text boxes. Click OK. Write this password down and store it in a secure place Close the User Accounts window and restart Windows.
In User Accounts select the account you wish to change the password for, click change password and then enter the new password or click remove the password to remove the password from the account. Hope this helps you
Feb 26, 2012 | Computers & Internet
Mar 19, 2011 | Dell Latitude D620 Laptop (Latitude-C620)...
Dec 22, 2009 | HP Pavilion dv4000 Notebook
Mar 30, 2009 | Dell Latitude X300 Notebook
Jun 06, 2008 | Averatec 3200 Notebook
May 05, 2007 | Compaq Evo Notebook N400c
May 02, 2007 | HP Compaq Business NX9110 Notebook
112 people viewed this question
