Question about Dell Vostro 1500 Notebook
When i power on my dell d420 it ask for a datebase password.
The boot menu starts then it goes start to the datebase password menu.
i cant press F2 or F10.
  • Derek Fuller
    Derek Fuller May 11, 2010
    Can you clarify "datebase password menu"? ....I don't quite understand what that is
How can i have the password bios of laptop dell E6420
f you are running Dell servers, it is recommended to enable BIOS password. This is will prevent accidental changes done to Dell BIOS settings by others who get physical access to the server.
You can setup two different types of passwords in Dell BIOS:
System Password: This will be prompted before the system can boot up, and load the operating system.
Setup password: The system will prompt for this password only when you are trying to access the BIOS settings.
Depending on your situation, it might be a good idea to enable both the system and setup password at the BIOS level. I recommend that you at least enable BIOS password.
Press F2 for System Setup
When the Dell server is booting up, press F2 to start system setup, from where you can change Dell BIOS settings.
BIOS System Security
From the Dell BIOS main menu, scroll down to "System Security" and press enter.
Password Not Enabled
From here, you can see that both the System and Setup password is not enabled by default.
Enable System Password (and Setup Password)
Scroll to "System Password" and press enter, which will prompt you to enter the password that you like to set for the system. Please understand that if you set this password, you have to enter this password everytime you start the system. Do the same thing for Setup Password.
Don't forget this bios password. If you forget, then you have go through the painful process of resetting the Dell BIOS password.
Password is Enabled
Once you've enabled both the password, from the "System Security" menu, you'll see that that both system and setup password is enabled as shown below.
password is set
System Password Prompt (During Startup)
From now-onwards, anytime you start the system, it will not load the operating system, unless you specify the system password as shown below.
12345
Setup Password Prompt (To Access BIOS)
If you press F2, to get to the BIOS, it will prompt for the setup password as shown below. If you don't enter a valid password here, you cannot access the Dell BIOS settings anymore.
Dec 16, 2014 | Dell Latitude E6420 Laptop Computer...
I have an optiplex 260. The desktop was at my inlaws house. i disconnected everything and brought it to my house. When i connected everything and turned on the computer, it asked for a password in a...
press CTRL + ENTER at the same time that should disable the password security and it should boot properly. If not there is a jumper on the motherboard that you can pull to clear the password as well.
Aug 22, 2011 | Dell OptiPlex GX260 PC Desktop
My daughters dell lap top has suddenly began asking her for a password. no password was ever required prior. i did try to repair by prewssing f2 at start up and entering the security tad and iether reenter...
Boot up in safe mode (Hold F8 key at startup) Log in as 'Administrator' Go to start menu, control panels, users Reset the password for the account you want. Restart.
Regards.
Sep 10, 2010 | Dell Latitude D600 Notebook
DELL latitude 100l, someone disabled all boot devices then set config / administrator password. Please help
Boot Priority on Dell Latitude 100L
  1. Turn On Your PC
    Have you ever noticed the messages that pop up on the screen as soon as you turn on your PC? These messages tell you a key combination you can press to enter "Setup" or the "BIOS." Watch your screen and see if you can read what keys to press.
  2. Press the Keys to Enter Setup Mode
    If you did not see a message telling you what keys to press, try tapping the following possibilities as you turn on the machine:
    • Esc
    • F2
    • F12
    • F10
    • F1
    After pressing Esc or other key, you will most likely see instructions telling you how to enter "Setup Mode". Follow those instructions.
    tip.gif On some computers, you must hold down the key before you press the power button to turn on the computer. For example, if you are converting a Toshiba laptop to a Linux Workstation, you must hold down the Esc key and then press the power button. The computer then asks you to press F1, and you can then set the "Boot Priority."
  3. Using the Arrow Keys, Choose the "Boot," "Boot Order," or "Boot Priority" Option
    The menu of choices you see will be different for different kinds of computers. Remember that the choice you want is the "Boot" order or "Boot Priority." On some computers, this is called the "Start Up Options" or "Start Up Sequences." You are going to change where the PC will look for boot information when it starts up. (CD-ROM, HARD DRIVE/HDD, LAN, FLOPPY, USB). If you wish to boot from your Hard drive, then select it as your First Priority.
  4. Using the instructions on the screen, save your settings and start up your PC. The PC must boot from the HDD. Regrds
Jul 01, 2010 | Dell Latitude 100L Notebook
Dead Dell Latitude D420 laptop--virus?
if u had a virus infection pobably some file on system32 has ben deleted so windows cant start up just show's the loading bar and thets it
If u have the Windows Cd
Boot from Cd
Repair the Windows
iff u dont
formate it
Jan 05, 2010 | Dell Latitude D420 Notebook
When you turn the laptop on it turnds on but then ask for a password but i forgot it
when booting up press F8 and it should take you to the admin acount that you can change your password from there
Mar 28, 2009 | Dell Latitude D420 Notebook
Restoring computer factory settings
another suggestion is boot the system from your OS disk, if you have one, and repair or reinstall OS. Reinstall should not cause you to loose any files.
Jan 01, 2009 | Dell Inspiron 531s Desktop Computer
Restore factory settings on a Dell Latitude C510
Get a USB CD drive, insert a winXP pro tablet CD, go into bios and tell it to boot from USB device, turn off, attach the USB drive and fire it up. That should reformat and once you get Winxp working you should be able to get the necessary drivers from the Dell web site. Tech suppt at Dell may sell you a disc for the machine that will restore the factory image, just ask. I got new ones from HP for $10.72 total incl postage! 3 to 5 days, what a deal!
Any decent tech should be able to reinstall everything you need for less that $50.00, but you will lose all data on the drive. Who else knows or remembers the login?
Mar 24, 2008 | Tablets & eReaders
Dell Vostro 1500 Notebook Logo
48 people viewed this question
Alun Cox
