I've the HL2070N suddenly the paper light is blinking, I replaced the paper, took out a stuck piece of paper from the back, and now the paper light is still blinking and won't print.
  • Dan
    Dan May 11, 2010
    On my HP 6940 my light blinks to indicate an interruption of the printing process and if I press it it continues to print. Did you try that?
  • 75 Answers
As long as the paper was not ripped and any was left inside of the printer, you should check the little black paper sensor and make sure it did not get broken when you removed the paper. If all of this is good, the cycle the power on your printer and it should reset the error.
Posted on Dec 05, 2008
Paper got stuck because suddenly electricity went off.how do i get it out?i dont know how to pull out the cartrdige of how to put it back.
When paper get stuck inside your printer you have to make sure to turn the printer off before doing any action. Once the printer is "off", open the top cover of your LBP-2900, pull it up from the rightmost part just beside the paper light indicator. Pull out the cartridge then proceed with the paper inside it. Once the paper is gone, put back the cartridge slowly and firmly. Close the top cover and turn on the printer. If the paper light indicator is still blinking red, press the button and proceed using the printer when it turns green.
Jun 25, 2010 | Canon LASER SHOT LBP-2900 Printer
EPSON Photo 1400 paper feed and ink replacement problem
Asit is only a couple of months old seek a replacement under guarantee/warranty.
Jun 29, 2010 | Epson Stylus 1400 InkJet Photo Printer
Lights are flashing on printer and it will not print . the voice says there is a problem with the printer. I did the alignment process but the voice keeps saying there is a problem. I took both cartridges...
There 3 light on the printer that able to indicate to user when problem occur. Which is the light u mean here?
1st button light blink rapidly = the printer may be out of paper, so load more paper and press the 1st button itself to continue. Or may be paper jam is occur, so clear the paper jam and press the 1st button light itself to continue.
If 1st button light blink slowly = mean the cartridge carriers are stuck, so raise the scanner unit and remove any object blocking the path of the cartridge carrier, make sure the cartridge are closed and installed properly, then lift the scanner unit, gently push the scanner support towards the cartridge carriers, and carefully lower the scanner unit until it is completely closed. After that press the 1st button itself to continue.
If 2nd LED light blinking = the color cartridge need to be replaced soon.
If 2nd LED light is ON = the color cartridge need to be replaced immediately.
If 3rd LED light blinking = the black cartridge need to be replaced soon.
If 3rd LED light is ON = the black cartridge need to be replaced immediately.
YBC (/\)
Sep 28, 2009 | Lexmark X2500 All-In-One Printer
Paper light blinking, paper tray full, won't print
hi,
i recently bought a second hand hl-5140 and when switched on had the fault you have described - on checking machine over i found a small piece of torn paper stuck in the paperpath. after clearing, the printer worked fine.check over for paper again as mine was only a very small peice.
hope this has been of help.
pete
Sep 04, 2009 | Brother HL 5140 Laser Printer
My HP PSC 2355 tells me there is a paper jam
Request you to get it check with the engineer personally or their might be a piece of paper stucked somewhere in the corner. I tried the same and was fixed
Jul 02, 2009 | HP PSC 2355 All-In-One InkJet Printer
Error
Make sure there is not a piece of misfed paper in there. This happened to me and it took a while before I figured it out. Open the upper top and try to remove the toner. If it is stuck, more than likely there is a piece of paper stuck in there. Hope that helps.
Aug 16, 2008 | Brother HL 2140 Laser Printer
Paper jam
There could be a tiny piece of paper blocking the paper path or sensor. See if you can find any.
Jun 30, 2008 | HP LaserJet 1200 Printer
HP Laserjet 1022
on the back side thers are two papers sensors inside the printer,they get stucked,normally they should come back
Jan 23, 2008 | HP LaserJet 1022 Printer
55 people viewed this question
jasbo
jasbo
