Question about IBM NetVista M42 PC Desktop
Jumper settings on 8307-48U mainboard
Doesn't IBM have documentation on jumper settings for service techs? If this is the case, none of my customers will ever buy IBM's in the future. I can go to Intel's website, ASUS's website, FIC's, Micronics, Compaq or HP (a little tough) and immediately download drivers and documentation. I need the jumper and Front Panel pinouts for this mainboard ASAP, anyone who can help I will greatly appreciate it. Thank you.
  • macspeedy Feb 10, 2008
    i also have an 8307 and i cant find the settings anywhere either please e mail me if you get anywhere davidpdn@hotmail.co.uk
    President:
  • 2,961 Answers
Have you loked at this page, apologies if no good, but there is a setup manual http://www-307.ibm.com/pc/support/site.wss/document.do?sitestyle=lenovo&lndocid=MIGR-42970
Posted on Feb 12, 2007
  • andrew pester
    andrew pester Feb 12, 2007
    Check this for other manuals
    http://www-307.ibm.com/pc/support/site.w...
Ga8i915pmd motherboard jumper settings
Hello try to find the manual here at gigabyte:
http://www.gigabyte.com/support-downloads/download-center.aspx?kw=GA-8I915PM-D&ck=
By typing in the right mainboard number.
Your mainboard is an INTEL based card.
The jumper settings is basicaly the same to almost all mainboard
Jul 17, 2012 | Computers & Internet
Video controller ( vga compatible ) required
Here is an official link for downloading the on board VGA drivers for MSI 865GVM3-V for windows xp operating system. In case thisd is not you op. system you can use this link to choose another one. Note that Windows 7 are not supported, if this is your case you have to try the compatibility option.
In case of a problem or clarification or further details needed, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Aug 15, 2011 | MSI 865GVM3-V Motherboard
Tengo una pc ibm pentium 3, esta bloqueada desde la bios y no se como desbloquearla. he averiguado que quitando la bateria de la mainboard por un lapso de tiempo este pasword se quita, y que tambien...
To reset the BIOS read the information from this link.
In case of your laptop the easiest method would be using software from Hiren's Boot CD as it's pretty hard to open it up and reach for the CMOS battery or the jumper.
Oct 30, 2010 | IBM (25P3294) Motherboard
How do I change pass word in bios setting?
hi
On some motherboards, the battery is soldered to the motherboard, making it difficult to remove. If this is the case, you have another alternative. Somewhere on the motherboard you should find a jumper that will clear the BIOS password. If you have the motherboard documentation, you will know where that jumper is. If not, the jumper may be labeled on the motherboard. If you are not fortunate enough for either of these to be the case, you may be able to guess which jumper is the correct jumper. This jumper is usually standing alone near the battery. If you cannot locate this jumper, you might short both of the points where the battery connects to the motherboard.
If all else fails, you may have to clear the BIOS password by resetting the RTC (Real Time Clock) IC (Integrated Circuit) on your motherboard.
Many RTC's require an external battery. If your RTC is one of this type, you can clear the BIOS password just by unsocketing the RTC and reseating it.
May 25, 2010 | IBM Computers & Internet
Need to bypass or hack the bios password for IBM X41 PC Desktop
okay guys i found i new way to reset the pass with only a screwdriver …
will try to make a site with a tutorial to reset the tmp chip .. i think it works on every ibm notebook
here is a picture from an IBM X41 tablet i reseted the pass today
http://ug1.kw.cx/ug/0257/1549/123784929_full,r,470×470.jpg
you have to put the screwdriver between the 2 pins to contact them .. and now power on ya machine and go to the bios … you will receive a message with an security chip error or something like that
this chip was on the bottom of the mainboard … i think the T Notebooks (T40 , 42 , 43 , R50, R51 have the chip under the touchpad
will share this here for ya guys
i trade with used computers so you have to try many thigs to delete passwords ^^
The same way to delet passwords on DELL (D610, D600, and many more)
greetz Adrian
Mar 27, 2009 | IBM NetVista X41 PC Desktop
Swap two hard drives
Indeed you can. Make sure the jumper settings are identical for the swap, and as long as the replacement one has windows xp running on it you should be fine.
Mar 04, 2009 | IBM ThinkPad T22 2647 Notebook
Maxtor hard drive model 54098h8 where do I put jumper for main drive
on the model 54098h8 this is a IDE drive and was in service in the mid 2000 era. most drives warranty expired by 2003.
the jumper postion is for J50 which is MASTER with jumper ON and SLAVE OFF See photo below or look on this link
http://www.seagate.com/staticfiles/maxtor/en_us/documentation/manuals/d540x-4k_guide.pdf
All material contained herein Copyright © 1999 Maxtor Corporation.Contents and specifications subject to change ®
without notice.DiamondMax™, MaxBlast™ Plus and MaxFax™ are trademarks of Maxtor
this is a photo of the master from the PDF
May 07, 2008 | Maxtor Hard Drive
Re:Bios jumper
Your computer is an IBM Netvista 8311.
This link shows ibm netvista 8311 motherboard diagram
www-307.ibm.com/pc/support/site.wss/document....
The cmos reset jumper it is indicated on nr.10, alternatevely when you cannot find reset jumper on a motherboard you can pull out and put back motherboard battery
Best regards
Mar 17, 2008 | IBM NetVista PC Desktop
Wont boot fully
Try resetting the system BIOS.
There are three ways to do this, depending on the mainboard style.
Check for a jumper near the mainboard battery.
If there is one, and it is a three pin style, move the jumper from the side it is on to the other side, then turn the power on (generally it will spin up, but nothing will happen), and then back off. Replace the jumper as it was originally and boot the system.
If there is a two pin jumper, remove the jumper, turn the computer on (again, it will probably not do anything), then turn the computer off and replace the jumper and reboot.
If there is no jumper, remove the battery, turn the system on, then off, then replace the battery and reboot.
Feb 14, 2008 | IBM eServer xSeries 346
IBM NetVista M42 PC Desktop Logo
740 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Steve Allison
Steve Allison
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
