Question about HP Compaq Business Notebook NX9010
My compaq 6710b laptop keep on losing date
My Compaq 6710b laptop on losing date i have updated the BIOS and repalced the CMOS battery but seem to be behaving the same. Plz Help
    Scholar:
  • 37 Answers
It could be multiple things. I cannot post the full guide here because it is too long for the characters allowed in the post but the link to it is here. http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=110&prodSeriesId=3356620&prodTypeId=321957&prodSeriesId=3356620&objectID=c00047347
iI know it is for a differen t make and or model but it is all the same, it is usually one of these problems. I have used this page to help with multiple different computers and it has alwaysed fixed the problem.  hope this helps
Posted on Dec 05, 2008
Remove hp compaq 6710b bios key to enter bios setup
You can try removing the CMOS battery for a few hours.
Dec 18, 2012 | Acer Aspire One D260 Netbook
Hi, I have an HP Compaq Laptop 6710B which
Usually this is cause by a defective battery. Replacing the battery should fix if.
Thanks Tonm
Aug 07, 2011 | HP Compaq 6710b Notebook
I have compaq evo n1000c laptop. recently I have changed the cmos battery and now its not booting. do I need to update the bios.? how can I resolve the issue?
If you just replaced the CMOS battery, when you took the battery out it lost all of its BIOS settings. You will need to go back into the BIOS and set the time and date as well as all of the other settings that you require. If you do not know all of the settings you can find the option to set it to the default settings. This will usually work to boot the computer.
Be sure to email me back if you have any more questions orif you need any assistance with this solution. Thank you
May 02, 2011 | Compaq Evo N1000C Notebook
How can i break up the Password of BIOS my LaPTOP Compaq 6710b I have purchased used Laptop
Its not possible to break BIOS password in case of a laptop, you have to go to HP service center for this. You can do this in desktop very easily by just taking out the CMOS battery and then reinserting it.
You can DO the same in your laptop also to remove the password but its highly risk cos once you opened your laptop your warranty will break if your system is under period. SO i wont suggest you to do it by yourself, better go to service center..
Nov 11, 2010 | HP Compaq 6710b Notebook
HP Compaq nc6400 won't keep any BIOS settings
HP Compaq nc6400,,is the bios pin on correct jumpers?
https://support.hp.com/rs-en/document/c00363478
Dec 30, 2017 | HP Compaq nc6400 Notebook
Can anyone help me on how to reset the Bios password to default on an HP Compaq 6710b Laptop? I have an HP Compaq 6710b Laptop. It is booting but it cant go beyond bios boot and i cant enter setup as it is...
A. By Using the Motherboard Jumper:
In most motherboards CMOS battery is soldered, which makes it difficult to remove the battery. In this case we use another method.
Almost all motherboards contain a jumper that can clear all CMOS settings along with the BIOS password. The location of this jumper varies depending upon the motherboard brand. You should read your motherboard manual to check its location. If you don't have the manual then look for the jumpers near the CMOS battery. Most of the manufacturer label the jumper as CLR, CLEAR, CLEAR CMOS, etc.
When you find the jumper, look carefully. There will be 3 pins and the jumper will be joining the center pin to either left or right pin. What you need to do, is remove the jumper and join the center pin to the opposite pin. e.g. if the jumper joins center pin to left pin, then remove it and join center pin to right pin. Now wait for a few seconds and then again remove the jumper and join the center pin to left pin.
Make sure to turn the PC off before opening the cabinet and resetting the jumper.
B. By Using Software:
I have found that BIOS/CMOS Password Recovery Tool is the most effective.:
BIOS/CMOS Password Recovery Tool is a program that works instantly to remove any lost or forgotten BIOS/CMOS password. Simply boot your PC to DOS and execute the program, and get access to forgotten BIOS/CMOS passwords in just seconds
BIOS/CMOS Password Recovery Tool Service: http://www.biospasswordrecovery.com/
Oct 16, 2009 | HP Smart Buy Notebook
Clearing cmos
The BIOS battery maybe under one of the panels on the bottom of the laptop or under the keyboard.
To reset the BIOS ack to the default settings, go into the BIOS configuration and look at the various configurations, usually there is a setting to load the Default settings, then save and exit, and this would not change the Date & Time setting.
The other way to set the BIOS default setting is to remove the BIOS battery (it is probably a lithium 3volt button battery), wait 1/2 hour and replace the battery, the go into the BIOS configuration and set the Date & Time setting etc.
Jul 04, 2009 | Compaq Computers & Internet
Compaq presario c 500 won't turn on
Hi there
First of all the bios battery has run out, this is why its not keeping date and time.
Secondly the system memory has developed a fault, take the memory out and clean the slots and contacts, you will find the memory under a small panel underneath the laptop, laptop memory looks like this >> 8e91ce7.jpg When cleaned re-seat the memory and try booting the machine up, if it does all good!!
You will however have to take the laptop to a PC repair shop to have the bios battery changed as this means that the laptop has to be dissembled to get to the battery.
To keep the date and time keep the AC power jack plugged in.
Good luck and thanks for using Fixya!!
Feb 23, 2009 | Compaq Presario 700 470024-192 Notebook
HP Compaq Business Notebook NX9010 Logo
119 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
