I have a endless summer propane patio heater that hasn't been used in over a year. Self ignition has fresh battery, full tank of propane, cannot get the pilot to light. I know spider webs can effect port for pilot...is there any liquid spray that might assist cleaning off corrosion?? Joe
  • draagynmj Dec 06, 2008
    I received a reply regarding an endless summer patio heater that hadn't been used in a year. Ignitor works, but pilot won't come on. I received a reply that there are a number of liquid sprays which might solve the problem, but no reference to any particular product.
    I appreciate the help and a more specific answer.
    Sergeant:
  • 276 Answers
  • 10,594 Answers
Try WD-40 liquid spray to clean corrosion and contacts.
Here
is picture of spray and UK store.
Posted on Dec 05, 2008
    Sergeant:
  • 217 Answers
Yes.there are many such liquid spray to clean the issue completely.
Do you place the propane tank in the heater base
The gas tank should sit inside the housing on top of the base. There is usually a cut out section to allow access to switch on/off the tank. Always best to switch the tank off when not in use. If you need some more info found this site very useful patio heater gas.
Nov 28, 2011 | Endless Summer 1501 Patio Heater
I have a full tank of propane - my pilot light is sparking but it will not light? Any ideas on what to check? Thank you, Korby
Korby, I think you meant, your ignitor is sparking and you're not getting gas to the pilot. Since you have a full tank of propane, I can rule out that the tank is empty. However, I believe the tank or at least the tank valve is playing a role in this.
Turn the tank valve completely OFF and disconnect the hose from the tank. Wait 5 minutes and reconnect the hose to the tank. Turn the tank valve ON VERY, VERY SLOWLY (Slow Motion, slow) until the valve is fully open. Then light the pilot as you normally would. If the pilot lights, you solved the problem. If it didn't, either the pilot light is clogged and needs to be cleaned or the heater's hose/regulator assembly needs to be replaced.
Endless Summer Patio Heaters are made by Blue Rhino. So, if you need parts, that's where you can get them. Hope this helps you troubleshoot and solve the problem. Please let me know. Thanks.
May 09, 2011 | Endless Summer 153100 Open Flame Patio...
I need to convert a Endless Summer Blue Rhino patio heater Mod. No. 233010 from naturalm gas to propane , what do i need
You would need new pilot and main burner orifices. You would also have to ask the dealer/manufacturer if the valve on the propane heater will work with propane. It may not because the propane tank will have to be connected to the heater using an LP hose and regulator. You would then need to take apart the heater to install the new orifices. Considering the cost of a new heater that is set up for LP, I do not believe the conversion to be practical.
Feb 24, 2011 | Blue Rhino Uniflame - 233010 - Endless...
Endless summer 62900
if it is converted to lpg if not no
Jul 14, 2010 | Endless Summer 62900 Open Flame Patio...
Endless Summer Patio Heaters won't stay lit
Hi ColdinSF,
You need to remove the covers from the unit and blow out the gas lines with compressed air. If you can remove the gas lines blow out the lines and what they connect to like the pilot light and main feed line to the burner. Usually they gunk up with use and just need to be blown out with compressed air to clear the lines again. Maybe you have some dirt or foreign object from your gas tank which has clogged the line. Also check the igniter electric lines as well and make sure everything is connected properly. Especially make sure you tighten the gas lines you remove. Hope this helps.
Regards
Bryan
Oct 19, 2007 | Endless Summer gwt501a Open Flame Patio...
Heating & Cooling Logo
26 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
