Question about Wurlitzer Audio Players & Recorders
Carnegie i know nothing about my carnegie but when it was given to me it was working most of the time it started going wrong when i turned it off and next day i would put it on and it would play if i kept trying and then it would work all day.then last night it stoped playing so i have taken out the card plate to see what was happening and the cd is not spinning so the arm comes back and puts the disc back . please help as i would love to get it working.as the sound is the best
  • 1 more comment
  • marygeraghty Dec 07, 2008
    cd.ok all clean and lens clean
    thanks for your help where is the transistor?
    would like to thank all 3 experts for there help will try them out and get back to you
    Sergeant:
    Champion:
  • 201 Answers
Hi There, its sounds to me your Lens is failing. You can try to clean it but be gentle. Remove the pasitc latch over your lens, unplug it first. Check to see the lens should be nice and shiny like a diamond if you see dust on it thats your problem. Clean with a clean ear cleaner "cotton on a stick" use Metholated spirits. Clean gentle make circler motion dont press to hard. If problem still not solve you will need to replace the lens.
Hope you come right
Thank You
Posted on Dec 07, 2008
  • 51 Answers
The problem may be with the transistor. Plase try replacing the transistor. Hope this works.
Thank you.
    Genius:
  • 1,239 Answers
HI
IT IS THE Laser spindle motor. Make sure to get one with the same length shaft - will cost $3 or $4 max and a bit of soldering after removing the drive unit.Or if you can't find one, a new complete laser assembly will have a new spindle motor already fitted - price depends on model of laser.
  • ABHISHEK.C
    ABHISHEK.C Dec 07, 2008
    Although there are many things that could cause this problem, there are three that are the most common.
    They are... Bad laser, dirty laser lense, or bad spin motor. You have already removed the top cover, but be careful never to power up the unit with the laser lense exposed, or you will be performing home laser eye surgery on yourself with very bad results!
    When you close the CD drawer, listen carefully to make sure the loading motor stops...if the belt is slipping, the mech never gets the "drawer closed" signal, and the disk will not spin. If the drawer is closing ok, listen for a faint "ticking" sound, this is the laser lense going up & down trying to focus on the disk. If you hear that sound, but the disk doesn't spin, try gently spinning the disk clockwise with your finger.. if it starts to spin & finds the directory, then the spin motor has developed a dead spot, and the unit may work fine several times until it lands in that same spot again. If that is the case, the spin motor must be replaced. To clean the laser lense, you will need some rubbing achohol & cotton swabs. Make sure it is at least 70% USP not the dollar store suff, (50% water). I'm not familiar with your model, but likely you will have to remove a cover that holds the clamping ***'y that is usually a round piece with a magnet inside that clamps the disk to the spin motor. Saturate the swab with alchohol, and touch the lense..the alchohol should cover the lense forming one big drop, then VERY gently move the drop around with the same end of the swab to loosen any debris.
    Then take a dry swab or the dry end if double ended swab, and touch it to the lense. The alchohol, (and hopefully the dirt),should instantly sponge up into the dry swab, then assemble and try unit. If all this fails, the laser has likely failed, and must be replaced & aligned by a competant repair shop.
    Genius:
  • 1,550 Answers
  • That particular disc may be dirty, scratched, or defective . Try with other disc .
  • Chance of dirty or damaged objective lens.
  • Also you need to check for any bad connections or defective ribbon cable to optical pickup.
Watch date changes between 1:45 am and 2:00 am
turn it 12 hours forwards or 12 hours backwards that will correct it to the right date change
Jan 12, 2013 | Watches
Engine won't turn over but all acc work
cables still a issue. replace cable ends..
Dec 23, 2012 | 2004 Pontiac Montana
My hp pavilion desktop computer says monitor going to sleep when i turn it on
Sorry to say, but your computer needs a complete installation of an OS. Windows updating causes several changes to important system files and nothing should be done at the time of INSTALLING THE UPDATES.
Norton was working at that moment, as you say, and besides, it was optimizing the computer which means that both the Update and the optimization may have worked on the same system files and the files may be corrupted now.
So, you should have a installation of OS as the System Repair didn't work.
Regards, Mrityunjay.
Jun 20, 2012 | HP Pavilion Desktop with AMD Phenom X4...
TEC 472 Error message- SG: 139, 0010, 064
This is syntax error, the coorect is SG;0139,0010,064....
May 09, 2009 | Toshiba TEC B-472 Thermal Label Printer
91 volvo stalls at anytime
TRY ANOTHER FUEL PUMP AND FUEL FILTHER THESE PUMPS ARE FUNNY ON VOLVOS HAD SAME PROBLEM ON 850 TURBO AND SURE ENOUGG IT WAS THE PUMP
Apr 11, 2009 | 1991 Volvo 940
At shower time in the morning the hot water varies from cold on one day medium on another and hot on any given day. What's wrong?
Do you share your hot water with anyone? Is anyone washing dishes, laundry, etc before you shower? How old is your hot water heater? If it has filled with sediment, your hot water is limited. Try turning up the heat control valve on the hot water heater, only go up one notch today, then if not enough another the next day. Be cautious of scaulding hot water after turning it up.
Apr 10, 2009 | Water Heaters
96 jeep cherokee sport starting problems
Try the wiring harness that attches to your ignition switch. Check for burn marks. also if it is auto check ur inhibiter switch located at the bottom of shifter under console
May 26, 2008 | 1996 Jeep Cherokee
HP Pavilion Dv2000
be sure that the ram is in tight, if it is try new ram
May 02, 2008 | HP Pavilion zt1170 Notebook
23 people viewed this question
Top Wurlitzer Audio Players & Recorders Experts
John Robertson
John Robertson
Level 1 Expert
jasbo
jasbo
Donald Chadwick
Donald Chadwick
Level 1 Expert
Are you a Wurlitzer Audio Player and Recorder Expert? Answer questions, earn points and help others
