If i turn egnition straight on it comes on straight away but if i let some of the other warning lights go out it doesnt
SOURCE: ECU engine management warning light
There is a problem, it needs to go to a factory service center, it can be any one of multiple reasons that turns this light on.
SOURCE: engine warning light has come on
you need to have the trouble codes checked with a obd2 code reader.
it could be the throttle postion sensor if the car would not accelerate but there is no way to tell for sure until you see what trouble code the vehicle is throwing. most auto parts stores will check them for free. hope this helps
SOURCE: 2003 Volvo S60 AWD warning brake failure light
Check the fuse and the wirings.
I’m happy to assist further over the phone at https://www.6ya.com/expert/ramy_d9e7ebea3891f482
Hi, I had the same problem. it is the imoboliser, it reads a code in your key while starting. you need to get the code in the key reprogramed. if that wont work you will need to get a new ignition barrel. Audi dealer will reprogram your key.
SOURCE: what causes the engine management warning light to
The CHECK ENGINE warning lamp comes on when the engine ECU recieves incorrect data . When it gets information outside of its perameters, it suspects a fault and illuminates the warning lamp.
To see what fault is shown you will need to use an OBD 2 code reader or go to the local Kia dealer to plug in and check.
If you do not notice any problems with the engine, then its possible it may only be a GLICH in the system, either way , test , check and erase the fault.
Hope this helps
